macbook A1708 - BMU replacement
  • Prott
    • May 2022
    • 154
    • Czechia
    just a quick sanity check question before I blow myself up.
    Is it ok to transplant a working BMU from a dead A1708 battery to a working battery with a dead (not recognized) BMU? Assuming I will be very careful not to short anything out while doing it.
    I am just worried the BMU retains some battery specific data that will either kill the new battery or make it behave like an old one (the amount of charging cycles, etc.).
  • mon2
    • 14677
    Re: macbook A1708 - BMU replacement
    In my opinion, this project reminds me of the lyrics of the George Thorogood song - Bad to the Bone..
    The head nurse spoke up
    Said, "Leave this one alone"
    Highly recommend to seek out another known good battery. Amazon ?
    • Prott
      • May 2022
      • 154
      • Czechia
      Ok, got it. I had a bad feeling about wasting 3 good cells, but a house fire is probably not worth it.
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • boosti45
        Macbook pro logic board replacement parts quesion
        by boosti45
        i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
        08-21-2024, 05:23 AM
      • mferna14
        MacBook Air A2681 battery problem after Screen Replacement
        by mferna14
        Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
        12-06-2024, 08:10 PM
      • PITERPENY
        Macbook A1707 820-00928 battery replacement
        by PITERPENY
        brought in a working MacBook for battery replacement (swelled up). After replacing the battery it stopped turning on. tried connecting the old battery without changes. consumption with the battery connected and without the battery is the same 5v\0.200a on all 4 ports. replacing 9239 did not help
        04-20-2025, 03:22 PM
      • EpicFix
        MacBook Pro A1708 820-00840 stuck @ 5V, no power, no charging
        by EpicFix
        Hey guys, I need a little help here. I have a MacBook Pro A1708 820-00840 stuck @ 5V. Started off affecting just one port but now it's affecting both. Both CD3215 ics were replaced but the issue remains. One port does a loop and the other stays at a constant 5V. Both CD3215 have 3V incoming. I checked for PP3V3_G3H @ R3000, C3100 and C3108, R3001, C3200 and C3208. The weird thing is though that the ammeter shows the current draw (5V @ 0.5A) coming out from the port as opposed to it going in. Any ideas on helping me fix this?
        04-08-2025, 09:55 AM
