Msi model ms-16Q21 voltage 3.3 and 5 lost
  • Sal63
    • Apr 2022
    • IraqSTS
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Msi model ms-16Q21 voltage 3.3 and 5 lost
    With such a detailed description of the fault, everyone will rush to help you.
    • reformatt
      • Feb 2020
      • 1468
      Please Bro
      • rediii
        h???, spurrrn
        • Mar 2018
        • 499
        • somewhere in europe
        check enable signals on the 3 v/5 v-ic. check for short on coils, check ldo lines...
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • Fernon@Repair
          Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
          by Fernon@Repair
          i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
          VCCIO voltage ok
          VCCSA Voltage OK
          VCCPLL Voltage OK
          Ram Voltage ok
          RamVTT OK
          VPP 2.5 OK
          But No Core Voltage
          and i want to this vrm ic datasheet or pinout (ISL69269)
          anyone have this ic pinout voltages?...
          06-25-2025, 07:19 AM
          Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
          I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
          The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
          Now...
          06-09-2024, 10:57 AM
          ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
          3+1 Voltage Regulator for IMVP-7/VR12 CPUs
          Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
          core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
          configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
          serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
          Based on Intersil's Robust Ripple Regulator...
          11-05-2024, 03:24 PM
        • ruletero
          Acer a515-43 low battery charge voltage
          by ruletero
          Hi
          Acer A515-43
          LA-H801P
          Fail: Does not charge battery, has low voltaje on connector.
          Laptop didn't want to turn on, only charge led blinked.
          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
          10-24-2022, 02:31 PM
