Create MEAnalyzer executable from Github Python Scripts
  • cyngo
    • Jun 2015
    • 219
    • Indonesia
    Re: Create MEAnalyzer executable from Github Python Scripts
    very nice info .thanks very much.
    • cyngo
      • Jun 2015
      • 219
      • Indonesia
      Originally posted by mOri
      i tried the steps you described but got an error
      use "Console Based", it work for me
      • dariusgc
        • May 2020
        • 45
        • Lithuania
        Big Thanks, reformatt! and yea it works with "Console Based" option.
        • firulilla
          • Jun 2014
          • 64
          • spain
          Hi, I was getting the error FileNotFoundError [WinError 2] The system cannot find the specified file, you just have to deactivate the antivirus and it will make the exe
          I put console based and in setting I created a folder and I made the exe to that folder, I hope this helps someone
          I did it with the latest version MEAnalyzer-1.304.4-r338
          thanks reformatt for sharing,,sorry my english​
          • Ramonay
            • Jan 2024
            • 8
            • philippines
            thank you
            • abobek zum
              • Jan 2024
              • Poland
              #26
              Nice. Good job!
              • MicroSMD Lab
                • Sep 2018
                • 145
                • Trinidad and Tobago
                #27
                Many thanks, "console based" worked for me and the .dat file from the github download is necessary for the .exe
                • inconito
                  • Nov 2020
                  • 7
                  • algerie
                  #28
                  Thanks, "console based" worked for me . I did it with the latest version MEAnalyzer-r352
                  • sourcebf
                    • Jul 2016
                    • 433
                    • N/A
                    #29
                    don't use "Select Windows Based", select the other option. this worked for me
                    thanks a lot for the trick, it works for me too
                    • trunguntilyou
                      • Aug 2022
                      • 367
                      • Vietnam
                      #30
                      When I execute it, it gives me the error:
                      C:\Windows\System32>py -m auto_py_to_exe
                      46648 ERROR: An error occurred while packaging
                      Traceback (most recent call last):
                      File "C:\Users\quynh\AppData\Local\Programs\Python\Python313\Lib\site-packages\auto_py_to_exe\packaging.py", line 132, in package
                      run_pyinstaller(pyinstaller_args[1:])
                      File "C:\Users\quynh\AppData\Local\Programs\Python\Python313\Lib\site-packages\PyInstaller\__main__.py", line 166, in run
                      check_unsafe_privileges()
                      File "C:\Users\quynh\AppData\Local\Programs\Python\Python313\Lib\site-packages\PyInstaller\__main__.py", line 313, in check_unsafe_privileges
                      raise SystemExit(
                      ...<3 lines>...
                      SystemExit: Error: Do not run pyinstaller from C:\Windows\System32. cd to where your code is and run pyinstaller from there. Hint: You can open a terminal where your code is by going to the parent folder in Windows file explorer and typing cmd into the address bar.​
                      • arif3203
                        • Feb 2021
                        • 58
                        • Banyumas
                        #31
                        not work eror .Dat
                        • reformatt
                          • Feb 2020
                          • 1549
                          Originally posted by arif3203
                          not work eror .Dat
                          Click Open Output Folder and copy MEA.exe to your MEAnalyzer directory.
                          • arif3203
                            • Feb 2021
                            • 58
                            • Banyumas
                            #33
                            Thank you working sir
                            • reessi
                              • Jan 2016
                              • 334
                              • uk
                              #34
                              Hello, When I run the resulting Exe, it loads and I enter the file location:
                              C:\3.bin
                              After that I get the errors shown in the pic...
                              Can anyone help please?
                              Cheers
                              • reformatt
                                • Feb 2020
                                • 1549
                                Does it happen with drag and drop? Have you tried other .bin files? Can't reproduce it on my end.
                                • reessi
                                  • Jan 2016
                                  • 334
                                  • uk
                                  #36
                                  Yes same error or a different one attached.
                                  If I load a bios with out the Intel Engine then it correctly states no intel engine found,
                                  Drag and drop is the same..
                                  Do you think I compiled it wrong?
                                  I followed the instructions to the letter..
                                  I did get an error stating something about a path is not loaded, I could load it if I wanted in yellow but the compiling continued.. I'll post a screen shot shortly.
                                  Is there a pre-compiled one I can download to try..
                                  Cheers.
                                  • reessi
                                    • Jan 2016
                                    • 334
                                    • uk
                                    #37
                                    Just curious why it is released as source code only and not as an exe? Is there a way to run it with out compiling?
                                    Cheers
                                      • 22276
                                      Cheers
                                      This should answer why https://winraid.level1techs.com/t/me...sion/30876/338
                                      https://winraid.level1techs.com/t/in...-15/30719/5923
                                      • reformatt
                                        • Feb 2020
                                        • 1549
                                        Sent him the latest exe via PM, so as not to clutter up the forum.
                                        • reessi
                                          • Jan 2016
                                          • 334
                                          • uk
                                          #40
                                          Yes it worked the one you sent me so I must have compiled it wrong!
                                          Many thanks.​
                                            ME Firmware Cleaning Guide
                                            by SMDFlea
                                            Here`s a quick ME Firmware cleaning guide.
                                            The guide is basic,its main goal is to show you how to use intel FIT,its highly recommended that you all follow the guide posted at win-raid
                                            (The attached FIT version is 11, if your ME Firmware (FW) is not 11.0.*.* follow the win-raid guide. Use the tools version for your ME FW, for example: ME System Tools v9.1 For systems running ME v9.0 - v9.1)
                                            A video,software (intel FIT) and practice bios are all included. I`ll post a better video and more advanced guide at a later date.
                                            1. Open the...
                                            09-09-2020, 09:10 AM
                                            Tiny Hexer macro scripts
                                            by SMDFlea
                                            Tiny Hexer Scripts
                                            Copy DMI info easily with Hex editing software and Macro script
                                            https://www.badcaps.net/forum/showthread.php?p=1214739
                                            Tiny Hexer - https://www.softpedia.com/get/Others...ny-hexer.shtml
                                            Post your Tiny Hexer scripts in this thread, no bios requests or any other questions , just scripts that everyone can use for any bios with the same *DMI off-sets. Posting a thank you is ok though,if you find what everyone posts useful.
                                            The scripts can be named anything you want but the bios naming must be the same as they are...
                                            04-08-2023, 04:31 PM
                                          • pretendjury84
                                            Decrypt Keychain file
                                            by pretendjury84
                                            Sorry if this is posted in the wrong section.
                                            I need to decrypt a .keychain file. The methods listed on github (https://github.com/n0fate/chainbreaker) unfortunately dont seem to work. Im getting stuck on the first bit,
                                            1. Navigate to the directory containing the file setup.py
                                            2. Enter the command (from terminal): $ python setup.py bdist_wheel -d dist. This creates a wheel file (extension: .whl) in the /dist folder.
                                            qashifmasud@Qashifs-MacBook-Pro chainbreaker-master % python setup.py bdist_wheel -d dist
                                            zsh: command not found: python
                                            qashifmasud@Qashifs-MacBook-Pro...
                                            10-12-2024, 02:31 AM
                                          • bschwand
                                            ASUS N550JK laptop reboots after 30 minute, BIOS extracted invalid...
                                            by bschwand
                                            as subject line says, I have a laptop that reboots after 30 minutes. Investigation leads me to believe that is due to intel ME as it happens everytime after 30 minute from boot, it just turns off, no overheating, nothing weird.
                                            I found a lot of information about cleaning ME like this https://winraid.level1techs.com/t/gu...lization/31277 and this https://github.com/corna/me_cleaner
                                            Anyway, first step is to dump the bios. I found the Winbond W25Q64FV chip on the motherboard, dumped it with flashrom over...
                                            05-22-2024, 02:48 AM
                                          • brimley
                                            Extract BIOS from legacy DELL 1764 flash.exe
                                            by brimley
                                            Hi All,
                                            I just bought an old Dell Inspiron 1764 to put Linux on, but
                                            before doing that I thought I'd update the BIOS from windows using
                                            DELL's suggested file FLASHME_v103_Win_1194_4M_1764A13.exe.
                                            (https://www.dell.com/support/home/en...n-1764/drivers)
                                            This failed and bricked my laptop and this model doesn't seem to have any usb boot type recovery options.
                                            So now I'm trying to flash it myself using a CH341A BIOS USB Programmer
                                            but can't find any way to get the BIOS image out of the exe file....
                                            01-11-2022, 05:32 PM
