Decrypt Keychain file
  • pretendjury84
    • Oct 2024
    Sorry if this is posted in the wrong section.
    I need to decrypt a .keychain file. The methods listed on github (https://github.com/n0fate/chainbreaker) unfortunately dont seem to work. Im getting stuck on the first bit,
    1. Navigate to the directory containing the file setup.py
    2. Enter the command (from terminal): $ python setup.py bdist_wheel -d dist. This creates a wheel file (extension: .whl) in the /dist folder.
    qashifmasud@Qashifs-MacBook-Pro chainbreaker-master % python setup.py bdist_wheel -d dist
    zsh: command not found: python
    qashifmasud@Qashifs-MacBook-Pro chainbreaker-master % which python3
    /usr/bin/python3
    Im running Monterey which l think has deprecated python 2 so l tried the other method for python3, https://github.com/rixvet/chainbreak...ster/README.md
    This method im getting, even though its meant to be written for python3
    zsh: ./chainbreaker.py: bad interpreter: /usr/bin/python: no such file or directory
    Im abit clueless on this stuff so help would be appreciated, thank you!
  • m1ch43lzm
    by m1ch43lzm
    Hi everyone
    09-06-2025, 05:47 PM
  • Forest79
    by Forest79
    07-23-2023, 07:39 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • hazem3636
    need Bios Bin file Dell server 220
    by hazem3636
    hi everyone
    i need dump file for dell server r220
    i have download Flash BIOS executable file but i dont know how to conver it to Bin file
    i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
    if anyone has this method please need his supporting .
    all the best
    EXE file is attched and Original Bin file from the Bios Chip is attached also
    and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
    11-05-2022, 06:20 AM
  • Sebastian Codrean
    BIOS file for ASUS F542UN laptop
    by Sebastian Codrean
    Hello to all of you! I need help with a BIOS file.
    The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
    So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
    02-20-2025, 10:25 AM
