Asus fx506lu-hn160t shorted GPU CHIP?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Hello.
    Have this Asus fx506lu-hn160t that came with one shorted dual mosfet of 5 in GPU main phase. After this, two of side mosfets are overheating and no video. I try to replace mosfets between them to eliminate bad mosfet but still burn two side mosfets. Without any mosfet no voltage to gpu
    Is this gpu burned or driver ic is bad and i need to replace them.
    with 5 mosfets i get voltage 0.9V on GPU so it should not be shorted
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Asus fx506lu-hn160t shorted GPU CHIP?
    i even replace driver between them. But nothing changed.
    • sikocan
      • Oct 2019
      • 344
      Is the GPU resistance 0.7ohms?
      • rediii
        h???, spurrrn
        • Mar 2018
        • 501
        • somewhere in europe
        good chance that the gpu is toast even there is vcore...
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • BMCappelletti
          Asus Chromebox CN62 - wrong chip put on BIOS reader
          by BMCappelletti
          Long story short:
          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
          - gave the computer to his son a couple years later
          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
          (seems like the story was not that short)
          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
          01-08-2025, 07:27 PM
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
        • rddube
          Asus C423N not turning on because of shorted SilmPort Chip ANX3429 ?
          by rddube
          Need some advice from my Badcaps friends!
          I have this Asus C423N laptop that doesn't turn on, voltage from the power supply doesn't seem to get to the laptop.
          I checked the power rails and one of them was showing 14 ohms, so I injected voltage on that rail and the SilmPort Chip ANX3429 gets abnormally hot.
          So my reflex would be to change that chip, but I am unsure if it is a chip with firmware on it or just a power controller type chip? Can anyone help?
          Photo of actual chip uploaded.
          Many...
          06-30-2023, 11:24 AM
        • Biessea
          ASUS Sabertooth 990FX REV.2 bios chip problems, probably socket shorted?
          by Biessea
          Hi there,
          I'm a technician and a computer/retro computer lover.
          I just bought a great Sabertooth motherboard (I really love the colours and the ASUS military scheme) to install a nice FX-8320 from AMD and make a gaming computer with a Geforce GTX 970.
          For the first time I had problems with the system, but I solved and then correctly booting, I installed Windows 10 and then I started to overclock the system. I reached a stable configuration of 4,8GHZ with 1,475v.
          Then I saved fan configuration, and other parameters, and saved to the overclock profile...
          03-01-2022, 03:57 AM
