hp dv6700 screen flickering
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    I'm working on an HP dv6700 laptop, and the screen is flickering. It'll flicker on and off about 3-5 times a second. When it's on, it's a bit garbled. When I plug in an external monitor, it will display fine, with no flickering and not garbled.
    I was thinking it was the inverter board so I replaced that. It didn't help at all.
    It does have Nvidia graphics, and I know these can cause problems. Would this be a symptom of that, or is there something else with the display I need to look at?
    I have an original HP dv6000 with a bad graphics chip that I can pull parts off of if need be. The inverter board was identical, and the LCD looks to be compatible.
    A man convinced against his will is of the same opinion still.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: hp dv6700 screen flickering
    Sounds like you possibly narrowed it down to the LCD on the HP dv6700 itself?
    --- begin sig file ---
    --- end sig file ---
    • acstech
      GrumpyModerator
      • Jul 2007
      • 1432
      Well that's what I was thinking. The problem was that, IIRC, the failure mode of those Nvidia graphics chips was to come unsoldered from the board. I don't know if that would allow the external monitor to work, and the internal one to have an intermittent connection due to the chip unsoldering itself.
      It just seems like the signal to the LCD is bad, not the LCD itself.
      • yyonline
        • Jul 2009
        • 692
        Could also be the connector/ribbon cable that goes from the motherboard/video card to the back of the LCD monitor. It's likely cheaper than a new LCD panel, so that's where I would start. They get flexed all the time from opening and closing the laptop, so it's not at all uncommon for those cables to short or have intermittent connections.
        Every case of Nvidia GPU failure I've seen effected all attached displays, internal or external.
        Be careful swapping ribbon cables between models and screens. They don't always have enough conductors to support all resolutions (hardware screen resolution, separate from the desktop resolution). For instance, a WXGA+ (1440x900) cable can send signal to a WXGA (1280x800) screen. However, a WXGA cable cannot always send signal to a WXGA+ screen. The higher resolution cables have more wires in them. If you stick to the same resolution models for replacement parts, you should be fine.
        • port27374
          • Sep 2010
          • 7
          Hi
          Have seen this several times before here are the usual suspects:
          *Bad LCD Matrix (can be eliminated by trying a different screen/External Monitor will imply but not eliminate)
          *Bad LCD to mobo cable (can be implicated if the problem does not occur on external, but can only usually be eliminated by swapping out with a known good cable)
          *Bad inverter (can be eliminated by swapping with a known good inverter, try reflowing the inverter if need be, nothing to lose(make sure you are comfortable with hot air gun before trying)
          *Bad GPU solder joints (more than likely is what is causing the issue, you can be pretty certain that it is a bad GPU if you can replicate the screen garble onto an external, or you cannot obtain external monitor output at all).
          Good luck!
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Hp pavilion dv series. Nuff said
            • meanderer
              • Jul 2010
              • 50
              bad gpu problems doesn't fail like that... the way people diagnose a bad GPU (that some people would call for reflow) was that it WON'T work with external monitor.
              I would put the suspect on the CCFL, panel, or the connectors. After securing the connectors I would test the CCFL with a known good inverter first. Then the panel (oh no...)
              • mockingbird
                • Dec 2008
                • 5484
                Take the thing apart and toss out the motherboard. Keep everything else. It would be cool if an OEM would make replacement motherboards with GM4500 or similar for the DV6000 and DV2000 series but that won't happen in a million years.
                Again, how nVidia escaped this class action (Who else has with a near 100% product failure rate, with the same problem over many years) is beyond me. Any other company would be bankrupt by now.
                • Ado02
                  Lenovo Thinkpad X1 Gen 10 - Flickering Screen
                  by Ado02
                  We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
                  The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
                  12-16-2024, 02:33 PM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • survivalbloke
                  HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
                  by survivalbloke
                  SN: 8CG0213H8W
                  ProdID 3C311UA
                  This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
                  05-08-2025, 12:21 PM
                • smic717394
                  by smic717394
                  07-25-2024, 10:16 AM
                • RetroComputingGrotto
                  LG 42LN540V LED Backlight Flickering After Replacement When Connecting The Screen
                  by RetroComputingGrotto
                  This TV has been on the wall in our reception area for around 10 years and the other day the backlight failed. You could see a feint picture so we knew the screen was OK. I took the TV apart to get to the failed backlight and inject voltage in to each half of the LED strips to identify which ones had failed and 4 needed replacing. I ordered a set off of Amazon and they arrived the next day.
                  On fitting the new LED strips I plugged in the TV was blinded by the light!!
                  It was only when I partially put it all back together (including the screen) that...
                  10-23-2024, 04:17 AM
