Zephyrus G14 no power/charging diagnostic
  • bogosort
    • May 2022
    • 78
    I am trying to diagnose this GA401IV laptop and found that the VOUT (pin 3) on the PU8301 step-down converter has a short to ground. Pin 1 on PCO8301 as well (has continuity to ground). Is the PL8301 coil faulty or is it the PU8301 that is bad?
    Thank you
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: Zephyrus G14 no power/charging diagnostic
    Hi inductor will almost never fail so it is the mosfet or capacitor
    When the highside mosfet fail better replace lowside and the driver ic too if it is dr mosfet just that.
    Hopefully it is just the mosfet and is cpu or gpu good.
    Good luck
    • Thomasraud
      Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
      by Thomasraud
      i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
      QUOTED
      -It works on charger (without battery connected-only charger)
      -It works on battery (without charger connected-only battery)
      -& it also works when plugged in battery & charger, but it's not charging the battery
      //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
      and..
      QUOTE
      The IC cannot maintain the input current level
      06-28-2022, 06:47 PM
    • Scoff
      HP Probook 470 G4 - Power and Charging Problem
      by Scoff
      Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
      Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
      07-03-2023, 09:28 AM
    • SluggerB
      Help with trying to fix phone that is not charging (Pics inside)
      by SluggerB
      I have two TCL A30 phones.
      Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
      New Phone: Works fine, bought as a donor board to try and repair Old Phone
      My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
      08-12-2024, 08:11 AM
    • DaLZy
      Extremely Strange Issues with charging and battery on Zephyrus G14(GA401)
      by DaLZy
      I have recently come into possession of a G14 that cannot detect or charge it's battery. Initially both windows and the bios agreed that the battery was on "0%" but the laptop was able to run without AC power. I was able to get the laptop to detect the true charge of the battery(26%) in windows for a moment but it wouldn't charge or update the percentage when the battery drained. I attempted a few more EC resets and battery reconnections and now the battery shows at 0% in bios and 100% in windows. Additionally the machine is extremely laggy when plugged into AC. When on ac power in the...
      01-27-2025, 12:38 AM
      Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
      Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
      various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
      Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
      trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
      what is wrong with your PC in just seconds. It saves you time and money.
      Our new and improved design...
      11-01-2024, 06:29 AM
