Extremely Strange Issues with charging and battery on Zephyrus G14(GA401)
  • DaLZy
    • Jan 2025
    • 5
    • fdghdfgh
    I have recently come into possession of a G14 that cannot detect or charge it's battery. Initially both windows and the bios agreed that the battery was on "0%" but the laptop was able to run without AC power. I was able to get the laptop to detect the true charge of the battery(26%) in windows for a moment but it wouldn't charge or update the percentage when the battery drained. I attempted a few more EC resets and battery reconnections and now the battery shows at 0% in bios and 100% in windows. Additionally the machine is extremely laggy when plugged into AC. When on ac power in the bios the moving icons freeze every few seconds and input is extremely delayed. In windows the laptop is super slow unless I unplug it. Battery voltage and stuff isn't detected in hwinfo64.
    I suspect it's a cooked ec+charge controller but I don't know how to diagnose that since I'm new to this stuff. I need some pointers. I also can't get any components in until febuary due to chinese new year.
  • pc_okay
    • May 2022
    • 243
    • FRANCE
    Is the laptop slow too without battery? (Just charger plugged in)
    Do you try with another working charger (with right amp) and maybe another battery.
    You may try this first before messing with motheboard.
    ps: Look at cpu frequency in task manager when lapyop is running slow.
    • DaLZy
      • Jan 2025
      • 5
      • fdghdfgh
      The first thing I tried was a new battery, didn't fix anything.
      I don't have another barrel type charger, but type-c pd charging also doesn't work. I can try rigging up something with a 20v power supply and a barrel jack if I find one around the house.
      Yes, looking in task manager the CPU is stuck at 400mHZ when plugged in. I haven't tried running with the battery unplugged but I suspect it won't change anything since it came to me with the battery unplugged and the previous owner described the same issues.
      I suspect the last owner might have fallen victim to the metal latch when removing the battery and shorted out something on the board. Quite likely since he wasn't technically apt and replaced all the thermal pads/putty with thermal paste leading to no contact with the cooler...
      • mon2
        • 14652
        Locate the 2 x DCin mosfets @ PQ8901 and PQ8902.
        Remove all power. Meter in resistance mode.
        Measure the resistance across the mosfet pins:
        source (1-2-3) & drain (5-6-7-8)
        source (1-2-3) & gate (4)
        gate (4) & drain (5-6-7-8)
        Post each measurement. Repeat for PQ8902. Testing for a low resistance on each mosfet which means the mosfet is defective. Each measurement should be hundreds of k ohms or higher if the mosfet is ok.
        • pc_okay
          • May 2022
          • 243
          • FRANCE
          Okay perfect.
          Ater checking Mon mesurement, just check for missing component around battery connector.
          Last time i see that, one guy teared out one little coil on the battery DATA line with his screwdriver. (i guess!)
          So data line was open, and laptop was working on battery, but can't charge and remaining %% was crazy.
          good luck !
          • DaLZy
            • Jan 2025
            • 5
            • fdghdfgh
            pq8901:
            s to d: 4.06 megaohm
            s to g: 4.83 megaohm
            g to d: 5.18 megaohm
            pq8902:
            s to d: 2.78 megaohm
            g to d: 8.14 megaohm
            seems like fets are ok? they are 2 different models
            I had a look at the row of resistors pc_okay pointed out. Looks like they have already been tampered with by someone before me but all resistors are there.
            The 2 resistors that were replaced read 2.7kohm, rest read 36kohm. But according to schematic they should all be 51kohm?
            Edit: the two 2.7kohm resistors seem to be related to charger and battery temp sensing? this could be a explanation of strange behavior on charger, although it still doesn't explain why battery percentage isn't detected...
            • mon2
              • 14652
              If the power adapter is under rated, the CPU speed will be throttled and the battery will not charge.
              • DaLZy
                • Jan 2025
                • 5
                • fdghdfgh
                I am using the original 180w charger. I think the incorrect resistances may be causing the laptop to sense a abnormal battery connector and charge port temperature and throttle and stop charging.
                • pc_okay
                  • May 2022
                  • 243
                  • FRANCE
                  If CPU throttle, please check PROCHOT# you need it to be high.
                  And more important (like you said) resistances i mentioned in post 5 are conneced to temperature sensor, thermistor look at PU9001, connected to resistance, connected to thermistor...
                  That can explain your throttle, replace this resistor with good ones.
                  You may see the charging problem after if it's not fixed.
                  • MakNCheese
                    • Jun 2025
                    • 11
                    I have the same laptop and am facing a similar issue. Were you able to fix it?
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • Julian Bailey
                      HP ProBook 445 G8 Battery not charging
                      by Julian Bailey
                      Hi all
                      We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                      The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                      I have gone around the board with a MM and cant find anything
                      Windows shows the battery fine,...
                      10-11-2024, 10:34 AM
                    • piernov
                      Laptop battery charging circuit
                      by piernov
                      1. Some theory
                      1.1. Introduction
                      Almost every laptop has a charging circuit of some sort, that does a few things:
                      • Manages switching between AC adapter and battery power
                      • Manages battery charging and generates power rail to charge battery
                      There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
                      • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
                      • Narrow VDC (NVDC)
                      Texas instrument has a nice overview of these technologies with some more details at https:...
                      11-15-2020, 01:31 PM
                    • kodox
                      ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
                      by kodox
                      since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
                      the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
                      what i've done:
                      - flashing...
                      12-29-2024, 02:49 AM
                    • Shinju
                      Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                      by Shinju
                      Hey All!
                      Long time forum member here with a problematic laptop issue!
                      I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                      The laptop would not power on with the new battery installed without the power supply being plugged in.
                      When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                      TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                      10-20-2021, 04:58 PM
