Macbook A1466 No power
  • dclass-pro
    • Dec 2022
    • 157
    • Italy
    Hi guys, I have this A1466 macbook that doesn't start, the fan doesn't turn and it doesn't absorb anything, or rather... it absorbs 0.03A then every 5/6 seconds it absorbs about 130mA and then 0.. the 5V generates it only for an instant .
    If I connect the power supply from bango the magsafe comes on with orange color (without battery connected),
    PP3V42_G3H = 3v42
    PM_BATLOW_L =3.31V
    PPBUS_G3H = 8.59V
    PM_SLP_S5_L = 0V and increases every 4/5Sec but only for an instant
    I also tried to change the SMC but the result is the same... do you have any ideas?
  • mon2
    • Dec 2019
    • 14667
    Re: Macbook A1466 No power
    On the coil that generates the 5v spike, measure the resistance to ground (with no power on the logic board).
    There may be a shorted cap on that rail.
    • dclass-pro
      • Dec 2022
      • 157
      • Italy
      no short circuit there are about 1.2Kohm
      • mon2
        • Dec 2019
        • 14667
        Remove all power -> meter in resistance mode -> measure the resistance to ground of
        PPBUS_G3H
        • dclass-pro
          • Dec 2022
          • 157
          • Italy
          have 6Mohm
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            board code 820-00165 ?
            volt on L7560
            volt on L7430.... spie to 5 volt once ? twice? never ?
            how many omh on R7320 (black on ground red on R7320 200 omh scale.
            good cpu is around 026. lower then 016 can become dead cpu shortly.
            • dclass-pro
              • Dec 2022
              • 157
              • Italy
              volt su L7560 = 3,3V
              volt su L7430.... spie a 5 volt in loop
              R7320= 20ohm
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                L7430 how many times spike ? 1, 2 or more then 2 ?
                more then 2 check u6100 bios volts.
                cpu heated up with hot air ? if so bad action. (never heat cpu or smc)
                edit: if spike 1-2 times report volt of u8180
                edit2: if 2017 cpu can get low as 15.6 omh.
                • dclass-pro
                  • Dec 2022
                  • 157
                  • Italy
                  on L7430 more than 2 times
                  on u6100 on pin 8 i have 3,3V
                  I have never warmed up the CPU, I have changed the SMC with a new one but nothing has changed
                  on u8180 i have a very fast peak of 2/3V
                  • dellxps15
                    • Feb 2014
                    • 1598
                    • italy
                    u8180 peak on wich pins ? pin 5 should be 3,3 stable.
                    • dclass-pro
                      • Dec 2022
                      • 157
                      • Italy
                      yes on pin 5 have 3v3v and pin 1 have peak
                      • dellxps15
                        • Feb 2014
                        • 1598
                        • italy
                        diode mode on pin 1 of u8180 ?
                        pin 1,2,4 should be 1320 in diode, while pin 5 is 450. pin 3 is gnd.
                        • dclass-pro
                          • Dec 2022
                          • 157
                          • Italy
                          in diode mode with red lead to ground and black lead to pin:
                          1=544
                          4=344
                          5=450
                          i have a motherboard here the same and i have the same values
                          • dellxps15
                            • Feb 2014
                            • 1598
                            • italy
                            check value R1462. check R8178 volts pin 1-2.
                            check also r1460 r1461
                            • dclass-pro
                              • Dec 2022
                              • 157
                              • Italy
                              R1462=100k
                              R8178 = 100ohm and in volts I have the peak of about 2/3v fast every 4 sec
                              R1460=100K
                              R1461=100K
                              • dellxps15
                                • Feb 2014
                                • 1598
                                • italy
                                volt on r8177 pin 1 ? check if stable or oscillate.
                                • dclass-pro
                                  • Dec 2022
                                  • 157
                                  • Italy
                                  oscillate
                                  • dellxps15
                                    • Feb 2014
                                    • 1598
                                    • italy
                                    check diode mode on that resistor pin. then page 13 of schematic check all left volt of incoming pins like: PM_SYSRST_L, PM_PCH_SYS_PWROK, PM_PCH_PWROK and so on. check if stable volts.
                                    • dclass-pro
                                      • Dec 2022
                                      • 157
                                      • Italy
                                      r8177 in diode mode to gnd have 464
                                      PM_SYSRST_L oscillate
                                      PM_PCH_SYS_PWROK oscillate
                                      PM_PCH_PWROK oscillate
                                      PM_PWRBTN_L 3,42 fixed
                                      SMC_ADAPTER_EN 3,42 fixed
                                      PM_BATLOW_L 3.31V fixed
                                      • mon2
                                        • Dec 2019
                                        • 14667
                                        Review this thread and update us with your progress:
                                        https://boards.rossmanngroup.com/thr...an-spin.58148/
                                        • SarcasticOP
                                          General question about MacBook power rails for repair.
                                          by SarcasticOP
                                          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                          • PPBUS_G3H (12.6V-12.8V)
                                            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                          • PP3V42_G3H (3.42V)
                                            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                          • PPVRTC_G3H (3.3V)
                                            • This
                                          12-12-2024, 05:50 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • ahmarzo
                                          MacBook Air a1466 no power
                                          by ahmarzo
                                          Have a MacBook Air a 1466 with part no 820-00165-a having no power and no light on magsafe adapter pp3v42 is 3.3v when I short r5100 near ic u5000 the light turns on and mac gives display . everything is working good but the keyboard and touchpad doesn't work.
                                          Should I change the ic u5000 please guide me...
                                          10-18-2025, 10:34 AM
