Macbook air 2020 (820-01958) with water damage not turning on
  • MKesenheimer
    • Jan 2023
    • 5
    • <s>KNAsldkn</s>
    Dear all,
    I have a Macbook Air 2020 13” (820-01958) with water marks around U8700, C7665 and U2800 in front of me. The laptop is not turning on but the CPU is getting warm after a while.
    I am trying to figure out which component is potentially dead. For that I made the following measurements:
    Voltages on T2 chip rails:
    PP1v8_SLPS2R = 1.80V
    PP1v8_AWAKE = 1.80V
    PP1V8_SLPS2R_PMUVDDGPIO = 1.80V
    PP1v1_SLPS2R = 1.10V
    PP0v8_SLPS2R = 0.80V
    PP0v82_SLPDDR = 0.82V
    PP3v3_AWAKE = 3.28V
    PPVDDCPUSRAM_AWAKE = 0.80V
    PP0v9_SLPDDR = 0.90V
    PP1v1_SLPDDR = 1.10V
    PP1v2_AWAKE = 1.20V
    PPVDDCPU_AWAKE = 0.53V
    Voltages for boot process:
    PP3v_G3H = 2.99V
    PP5v_G3S = 5.07V
    PP3v3_G3S = 3.28V
    PP1v8_G3S = 1.80V
    BridgeOs boot:
    PP1v8_VCCQIO_SSD0 = 1.80V
    PP0v9_SSD = 0.90V
    PPVCC_NAND_SSD0 = 2.52V
    CPU PCH:
    PP3v3_S5 = 3.28V
    PP1v8_PRIM_PCH = 1.81V
    S5 and S4:
    PM_SLP_S4_L = 3.28V (steady)
    PM_SLP_S5_L = 3.28V (steady)
    PP1v8_S3 = 1.81V
    PP1v1_S3 = 1.10V
    PP0v6_S3 = 0.61V
    S3 and S0:
    PM_SLP_S3_L = 3.28V (steady)
    PM_SLP_S0_L = 3.28V (steady)
    PPVCCIN_AUX_PCH = 1.80V
    PP1v05_PCH_CPU = 1.03V (steady)
    PP1V1_S0SW_CPU_VCCPLL_OC = 1.10V
    PP1v8_S0SW_CPU = 1.81V
    PPVCC_S0_CPU = 0.01V
    Diode mode measurements
    PP1v8_SLPS2R = 1.133
    PP1v8_AWAKE = 0.911
    PP1V8_SLPS2R_PMUVDDGPIO = 1.541
    PP1v1_SLPS2R = 0.459
    PP0v8_SLPS2R = 0.906
    PP0v82_SLPDDR = 0.026
    PP3v3_AWAKE = 1.350
    PPVDDCPUSRAM_AWAKE = 0.333
    PP0v9_SLPDDR = 0.038
    PP1v1_SLPDDR = 0.359
    PP1v2_AWAKE = 0.517
    PPVDDCPU_AWAKE = 0.009
    PP1v1_S3 = 0.279
    PPVCC_S0_CPU = 0.00
    The measurements that seem odd to me are marked red.
    I also noticed a frequent clicking sound (around 30Hz) that may come from an inductor in the area around the CPU. But I am not sure where it exactly comes from.
    In a different thread I read that this clicking sound may come from a defective CPU, however, the S3 power rail for the CPU (PP1v1_S3) and PP1v05_PCH_CPU seem ok.
    The system status LED also glows dimly white.
    I have done alle measurements with a logic board that had all peripherals completely unplugged.
    Is it safe to assume that the CPU is indeed dead or should I continue my search? How can I reassure that the CPU is dead? What would be the next logical step to continue?
    Many thanks,
    Matthias
  • mon2
    • 14660
    Re: Macbook air 2020 (820-01958) with water damage not turning on
    Measure the resistance to ground of the cpu power rail. Appears to be a shorted CPU.
    • MKesenheimer
      • Jan 2023
      • 5
      • <s>KNAsldkn</s>
      Resistances to ground of the CPU power rails are:
      PPVCC_S0_CPU = 0Ω / 0V (in diode mode)
      PP1V1_S3 = 320Ω / 0.28V
      PP1V8_S0SW_CPU = 1.18kΩ / 0.82V
      PP1V05_S0_CPU_VCCST = 550Ω /0.41V
      PP1V05_S0_VCCSTG = 492Ω / 0.19V
      PP1P05_S0_CPU_VCCPLL = 333Ω / 0.33V
      * Edit *
      ALL_SYS_PWRGD = oscillating around 1.5V with 34Hz
      CPU_VR_EN = oscillating around 0.8V with 34Hz
      VCORE voltages = 5.0V
      • mon2
        • 14660
        To me, it looks like a dead CPU but one extra step you can take to confirm is to lift up one leg of each of the multiphase power rail coils.
        Read in full before proceeding...
        That is, lift up one leg of L7210, L7220, L7230.
        After doing this, measure the resistance to ground again of the same power rail that powers the CPU.
        Now, if you continue to see the 0 ohm to ground resistance, the CPU is for sure shorted. Otherwise, one of the power supply devices is at fault.
        This could be U7210, U7220 or U7230.
        Wait on other comments but the above is a worthwhile effort to confirm the short condition.
        Alternatively, if you inject 1 volt (not higher) @ 2A-5A onto this shorted rail - who heats up? Remove the heatsink to confirm.
        Is it the cpu ? If yes, the CPU is shorted.
        • MKesenheimer
          • Jan 2023
          • 5
          • <s>KNAsldkn</s>
          Alright thank you. I'll wait if someone else has another suggestion. If not, I will try your suggestions tomorrow.
          • MKesenheimer
            • Jan 2023
            • 5
            • <s>KNAsldkn</s>
            Ok, so I did what you suggested. The short remained after I removed the inductors. As I injected 1V to the shorted rail, the CPU warmed up.
            Now it's pretty clear that the CPU is damaged.
            Thank you very much for your help.
            • Rickkap
              • Aug 2015
              • 139
              Old thread but i have exactly the same symptoms. Is it possible to swop the CPU/PCH with one that is working or is it tied to the board like the T2??
              • incorrect
                • Nov 2017
                • 22
                • Greece
                Here i am too. PPVCC_S0_CPU to GND 0 ohm.1V injection while the phases coils are removed drops to 0.75V @ 5A. There is a thermal production on or around CPU but i can't say that the CPU becomes hot. tbh nothing that is connected to PPVCC_S0_CPU becomes hot. Even after 5 minutes of 1V injection. any idea? Device had only a small spot of corrosion on R7673 and C7673 just next to U7650.
                • mon2
                  • 14660
                    20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                    I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                    At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                    Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                    04-09-2023, 08:04 PM
                  • Ugur87
                    MacBook Air M4 A3240 Brand New Water Damage no Image
                    by Ugur87
                    I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
                    08-28-2025, 01:09 PM
                  • edugimeno
                    Stagg sms12p audio amp has water damage
                    by edugimeno
                    Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                    I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                    There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                    There is only one signal wire connecting the first boards...
                    05-24-2025, 06:00 AM
                  • RetroComputingGrotto
                    Water Damaged Toshiba 48L1435DB
                    by RetroComputingGrotto
                    I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
                    The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
                    10-07-2024, 08:23 AM
                  • x_orange90_x
                    Samsung UN65AU8000FF fried by water
                    by x_orange90_x
                    I was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
                    10-16-2025, 08:40 PM
