Macbook Pro 15" - A1990 - Chime and keep restarting
  • saisoni20
    • Feb 2022
    • 116
    Hi there,
    I have a MacBook pro A1990 was water damaged. I cleaned and reflow damaged components now I have 20V and MacBook turning on but keep restarting after chime.
    I have changed battery but still same problem.
    Anyone can help me?
  • mon2
    • Dec 2019
    • 14599
    Re: Macbook Pro 15" - A1990 - Chime and keep restarting
    Try a PRAM / SMC reset.
    • saisoni20
      • Feb 2022
      • 116
      tried but same problem
      • mon2
        • Dec 2019
        • 14599
        Do you see the backlight? Apple boot logo?
        Could the OS be corrupt?
        Can you try to boot from an USB thumb drive?
        • saisoni20
          • Feb 2022
          • 116
          Yeah I do have apple logo chime and it restart again
          • ugamazing
            • Jun 2013
            • 171
            • usa
            Try T2 restore; have seen some of these that boot-loop when T2 gets corrupted.
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 674
              Have the same issue, did a T2 restore on one, no water damage. Keeps restarting won’t load unless booting into safe mode. Any ideas?
              sigpic
              MEOWING IN THE IMPOSSIBLE UNIVERSE!
              • javedharun
                • Feb 2016
                • 12
                • india
                Any solution for this plzz report me
                • alfredodinolfo
                  MacBook Pro 2019 (A1990)
                  by alfredodinolfo
                  mb code:820-01827-A;
                  sn:C02Z349ALVDR;
                  i9 32GB Ram 1TB
                  Hi, I found short on one of 6 black nand (total 1TB).
                  i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
                  I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
                  macbook with A2141 configuration run on recovery but don't complete it.​
                  anyone can help me?
                  05-26-2025, 09:27 AM
                • robka
                  MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                  by robka
                  my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                  I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                  The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                  After that the Macbook was dead. It isn't charging anymore.
                  The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                  03-02-2024, 02:58 PM
                • DATATECH85
                  Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
                  by DATATECH85
                  I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
                  The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
                  I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
                  However, I can't work out exactly why I don't have the PPBUS_G3H rail.
                  Here are the values...
                  07-24-2024, 06:34 AM
                • saulini
                  macbook air a1932 no display but can hear the battery chime
                  by saulini
                  Hello guys...
                  I bought MacBook from a garage sale the owner told me that the MacBook was dead and it did not display nothing, at first I thought it was related to a t2 problem so I did the bride OS with my other MacBook I was able to revive it but it did display the apple logo but on the apple configurator the lock symbol was there upon further inspection the MacBook did make the chime sound every time I disconnected the power cable but still it did not show any display also the caps key was able to light up, with nothing else to do i remove the motherboard and found the following...
                  09-08-2023, 09:47 PM
                • survivalbloke
                  Macbook A1398 - no startup chime, no boot, but have fans and CPU warm
                  by survivalbloke
                  Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?
                  06-14-2023, 11:45 AM
