How to Disable GPU on Dell LA-D801P
  • mferna14
    • Jun 2018
    • 1046
    Hi all, getting video graphics errors on this Dell BAL20 LA-D801P Rev: 1.0 motherboard . Confirmed it with external dsplay & result is the same. After a good re-flow of the chip, the lines disappeared & works for 45~90 min without errors & once it heats up the AMD 216-0889018 gives up & then lines appear again. New chip of this year version is available & if available it's reballed & then I do not trust these chips as I had a very bad experience purchasing one for another motherboard, tehy never work!! I was checking forums & YT videos & confirmed that there is a way out of this. Can i Disable the GPU all together & work on it's Intel Graphis chip SR2ZU. According to the SR2ZU spec, it has IntelĀ® HD Graphics 620 built-in. How can I get this working as it's dedicated GPU rather than the defective AMD. Any help will be greatly appreciate. Thanks
  • Bonzas
    • 472
    • Indonesia
    Re: How to Disable GPU on Dell LA-D801P
    Try to remove pjp1101
    • mferna14
      • Jun 2018
      • 1046
      Thanks "martha februarini", I removed the GPU core 2 coil, Removed all the solder from the above mentioned pads points, still video does not come on. Any thing other than this?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Shift resistors for Board_ID2/3 on page9, model id on page 25
        • mferna14
          • Jun 2018
          • 1046
          Thanks "mcplslg123", I was busy 2 days with family. Now back again on track & back to work. I checked both pages 9 & 25. How will I find these resistors??? No Boardview available so it becomes very hard to find the required components. Do you have any idae where will these resistors be on the motherboard. Thanks
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            See, if this helps. Should be quite similar.
            • mferna14
              • Jun 2018
              • 1046
              @mcplslg123 you are a great help., thank you, I will search for these resistors today. Will keep you informed.
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • KABY
                dell 3542 IGPU disable
                by KABY
                hello I'm looking for some answerer about IGPU
                i have dell 3542 with IGPU AND DEDECATE one
                the mane IGPU its not working properly every time i boot up i get some artifacts and laptop turn of and reboot again some time it boot normally for 1 min and the same scenario again artifacts and shutdown
                my question!
                is it possible to disable IGPU and run laptop with DGPU
                or there is any possibility to disable it via bios bin or take off some capacitor or coil like DGPU to disable it completely
                thanks for your accept and answer
                bios bin added and schematic...
                10-06-2023, 05:55 AM
              • MahmoudNasser
                Dell Vostro 5490 disable internal RAM modules
                by MahmoudNasser
                I have a Dell Vostro 5490 that is giving me an LED code indicating "Invalid memory installed."
                The basic voltages are present.
                I want to disable the internal RAM modules. Is it possible to disable them from the BIOS?
                Ram Chip Part Numper: D9WFR --- PartNuber(MT40A1G16KNR-075:E)
                Device Data
                Model Dell Vostro 5490
                CPU:i5-10th
                SN D1LF003
                MP PartNumper:MANTIS CML MB 18778-1
                Bios Chips:W25Q64BV 8m , W25Q128BV 16m...
                07-11-2023, 01:05 PM
              • Akhlz001
                by Akhlz001
                09-20-2025, 07:15 PM
              • PacoGT
                DELL G15 RYZEN EDITION LA-K454P disable gpu
                by PacoGT
                Hi friends, I have a problem with this laptop. It gives me a processor error, but when I measure the processor, it has power, heats up, etc.
                But at first I thought maybe it was the BIOS. I tried reprogramming it, but nothing.
                After that, I measured the graphics card and realized that the graphics card has no power.
                So I lifted the power coils and checked that there is power, but when it reaches the GPU, they go to ground.
                With a thermal camera, I realized that it apparently has a short in a VRAM. After removing the short, it goes to the GPU.
                So my question...
                07-02-2025, 01:57 AM
