VOIP, ATA REN and old analog phones ring voltage booster
  • redwire
    • Dec 2010
    • 3912
    Re: VOIP, ATA REN and old analog phones ring voltage booster
    I see the Zetron generates its own (isolated) 48VDC, for phone-to-phone use (no PBX). Who then generates the ring voltage... I'll just crank my old Northern Electric ringer lol. It must always be off-hook for phone-phone use or something.
    I think in E-E Matrix jumper (pin 3) adds that 150 resistor to -48VDC to (pin 14) R1 , but +48VDC is not connected to anything? Not sure if the Matrix has other traces on the backside.
    Anyhow, I wouldn't expect 48V power from the Zetron, the PBX should only be supplying this.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8344
      Yes, I noticed that the -48 goes through that resistor, but nothing with the +48V. I am not really a phone guy. I figured an end to end line is just a regular stinking ole phone line where the phone number goes to that line. That's it. Not some special phone line numbering system requirement that large companies have.
      When the matrix is set to DID (basically the same thing than taking it out, as no connections are made) You'd think it should work perfect. That's not the case. I've got an old Wescom model 850-03 Ring Generator. In the DID setting the Zetron will put some a load on the ring geni during ring. You can hear it.
      • Fernon@Repair
        Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
        by Fernon@Repair
        i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
        VCCIO voltage ok
        VCCSA Voltage OK
        VCCPLL Voltage OK
        Ram Voltage ok
        RamVTT OK
        VPP 2.5 OK
        But No Core Voltage
        and i want to this vrm ic datasheet or pinout (ISL69269)
        anyone have this ic pinout voltages?...
        06-25-2025, 07:19 AM
      • electron_jj
        Panasonic TH-L42D25A checking the PSU output voltage
        by electron_jj
        Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
        I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
        08-29-2021, 08:13 AM
        Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
        I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
        The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
        Now...
        06-09-2024, 10:57 AM
        ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
        3+1 Voltage Regulator for IMVP-7/VR12 CPUs
        Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
        core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
        configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
        serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
        Based on Intersil's Robust Ripple Regulator...
        11-05-2024, 03:24 PM
      • ruletero
        Acer a515-43 low battery charge voltage
        by ruletero
        Hi
        Acer A515-43
        LA-H801P
        Fail: Does not charge battery, has low voltaje on connector.
        Laptop didn't want to turn on, only charge led blinked.
        I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
        I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
        Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
        10-24-2022, 02:31 PM
