Graco ST MAX II 495 PC PRO , paint spray machine help
  • zen
    • 511
    Hi all
    Customer mentioned that he overloaded this unit by powering with all settings at full .
    Anyone worked on this model before ?
    It's a US made device .
    A schematic would be really helpful , but not holding my breath .
    • 22230
    Re: Graco ST MAX II 495 PC PRO , paint spray machine help
    Originally posted by zen
    Hi all
    I found a repair manual but no pcb schematic. Is there a part number on the pcb
    • zen
      • 511
      16X297 seems to be the PCB number .
      Quite funny when i type it into Google . A repair kit popped up , which is the whole board , at a cost of £370
      • zen
        • 511
        So far found C14,C15,C16 & C17 ( 47MF , 25V ) , poor ESR readings .
        Also D16 , which seems to be O/C , has previously been reworked and/or replaced .
        Messaged customer to find out what the hell is going on .
        • redwire
          • 3912
          C20 looking preggo, D16 pin not soldered, was a gorilla inside trying to fix this?
          • zen
            • 511
            Yes unfortunately
            Customer took it upon himself to replace D16 , so now i need to try & discovered part number of original.
            C20 on my to do list as well .
              • 22230
              There`s some new boards on alibaba https://www.alibaba.com/product-deta...620074426.html ,it doesn`t mention how much the shipping would cost though.
              • zen
                • 511
                Thanks , still battling with this one .
                U7 ( VIPER 12A ) control chip also seems to be faulty .
                D16 is fed from a transformer ,then follows through R17 which is cooked , then to the supply pin 4 ( VDD ) of U7 .
                Only 2 pins of D16 are actually connected , therefore assume it's some sort of fast switching rectifier diode .
                Can anyone help with replacement advice for D16 ,& also value of R17 , which i assume will be quite low .
                • R_J
                  • 9628
                  The component installed at D16 now seems to be a transistor (BCR162) any sot23-3 200ma or higher diode should work. Many circuits use a 1N4148 for this diode, so find a similar SOT23-3 (BAT54, BAT54C)
                  The resistor could be anything low 0~10Ω maybe
                  • zen
                    • 511
                    Thanks RJ , yes that was the customer messing about with it .
                    Was thinking around 10R myself .
                    • redwire
                      • 3912
                      D16 is usually a SOT-23 diode like BAV99, BAS16, MMBD4148 etc. I think BAT54 at 30V is too low. Around 10R looks reasonable for the resistor. C20 must be in bad shape.
                      What fused? A shorted Viper 12 usually blows the top off, and this board has pretty thin pcb traces and looks 4-layer. Many scuffs and nicks on traces/solder mask. Even parts are trashed, R7, U11- could you use a bigger hammer.
                      I'd check with an ohmmeter the path from primary cap to transformer to see if there is an open-circuit. I don't see what fused yet.
                      There's no feedback opto either, so it might not be an isolated supply.
                      Viper 12 datasheet
                      • R_J
                        • 9628
                        The bat54 voltage is a bit low, go for something around 100v
                        • zen
                          • 511
                          Hi Redwire ,the scuffs are due to all the hardened glue i needed to removed so that i could gain access to many of the components .
                          Cheers on the advice for diode type guys , will check to see what i have in stock .
                          • zen
                            • 511
                            All that messing about , then customer pulls repair
                            • redwire
                              • 3912
                              I understand the conformal coating can make the repair extra hell. I use needle probes to poke through for readings, and hot air gun to heat/soften the coating and scrape it off.
                              TBH the board is a piece of junk, nobody puts a MCU ceramic oscillator right next to the SMPS primary. Skinny traces and more glue please.
                              Customer seems to keep trying people to repair it for $0.99 or something. If someone already was in there, I don't take on the repair because it can be such a mess.
                              • zen
                                • 511
                                Thanks for the additional info Redwire .
                                I normally pop board onto my pre heater to loosen the glue , but this was quite hard heat resistant stuff & couldn't poke the meter probes through .
                                Next one i see ,cost will double
                                  • 31300
                                  some conformal coating disolves with white spirit.
                                  • zen
                                    • 511
                                    Great tip STj , will try that next time .
                                      ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                                      This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-12-2024, 03:28 PM
                                    • CG2
                                      Janome DC3050 Sewing Machine Pedal Resistance
                                      by CG2
                                      OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                                      Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                                      04-14-2023, 07:53 AM
                                    • Soulzink
                                      Samsug washing machine. Power supply DC41-00189a board issue
                                      by Soulzink
                                      I am trying to fix a samsung washinmachine power supply main board.
                                      I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                      Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                      The power supply board reference is the following: DC41-00189a
                                      I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                      04-19-2025, 06:26 AM
                                    • unimatrix93
                                      How to stabilize AC voltage to CNC machine
                                      by unimatrix93
                                      Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
                                      I have a CNC machine wired to 3-phase 230V AC.
                                      It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
                                      The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
                                      I contacted the electricity company but they refuse to help me solve this problem.
                                      So I started to look around for some DIY...
                                      03-17-2025, 05:52 AM
                                    • xdever
                                      820-01700 not booting, 4V PP2V5_NAND_SSD0 but 2.5V when the machine is off.
                                      by xdever
                                      I got a 820-01700 of a friend that doesn't turn on. I read that a typical issue with these boards is the TPS62180 generating the NAND voltages, so this is where I started looking. Sure enough, PP2V5_NAND_SSD0 is 4V when the machine tries to turn on (I try to determine this by measuring PP2V5_NAND_SSD1, which is 2.5V as it should in this case. The PP0V9_SSD0 and PP1V8_SSD0 power supplies for the SSD are on at the same time when PP2V5_NAND_SSD0 is 4V). The extremely weird thing is that when the machine is off (PP2V5_NAND_SSD1=0, PP0V9_SSD0=0 and PP1V8_SSD0=0), PP2V5_NAND_SSD0...
                                      01-15-2025, 08:44 PM
