Xbox 360E model:1538 not turning on
  • tsiga
    • Jan 2014
    • 76
    • ott
    Hello everyone!
    I have two same console with same error. Not turning on.
    Model:Xbox 360E model:1538
    The power birck led is lights on amber.- Tested with this methood. Link
    I measured the power button circuit to power panel connector, everithing looks good. local console guru said, southbridge error--> I replaced it with new.. same error.
    Can't find schematic or any document for this error.
    Can somebody help me?
    • 31199
    Re: Xbox 360E model:1538 not turning on
    is the psu giving 12v?
    • tsiga
      • Jan 2014
      • 76
      • ott
      Yes,
      5V stand by is present, and when the psu is on, 12V present based on video
      • lotas
        • Jan 2016
        • 4754
        • Russia
        A common cause in slims (does not turn on) is a problem in the 3.3v DC converter (in 5v - out 3.3v).
        • tsiga
          • Jan 2014
          • 76
          • ott
          Thank you.
          I measured 5V is present the 3.3V just 0.28V
          I not found this tiny voltage regulator name, type or any datasheet.
          Is there any solution to bypass or change to other components?
          I found article in which he mentions, to replace with AMS1117.. it is working?
          • lotas
            • Jan 2016
            • 4754
            • Russia
            Yes, you can put AMS1117 3.3 with a fixed voltage of 3.3v
            "J7(X)" is "RT8057"
            Sometimes they put: "CEY" - That is "TPS62560"
            • tsiga
              • Jan 2014
              • 76
              • ott
              Thank you, so much!
              • tsiga
                • Jan 2014
                • 76
                • ott
                working!
                Thanks!!
                  • Jul 2011
                  • 6065
                  Originally posted by tsiga
                  working!
                  Thanks!!
                  I like your repair this has a very professional look to it
                  One more item that did not end up in the landfill
                  Very nice work
                  • lineslim
                    • May 2024
                    • 5
                    • Sverige
                    I have the same problem (xbox360 does not power on) with the same 1538 board. I checked voltage on the RT8057 and I have 5V on leg 6 and 3.4V on number 1. Any suggestions on what to look for next?
                    I can mention that when I happened to touch the 5 legs component next to the rt8057 with my finger, the fan started spinning for like a second or so.
                    Help on continued trouble shooting is greatly appreciated.
                    • lotas
                      • Jan 2016
                      • 4754
                      • Russia
                      At 6 pin you can't have 5v because this pin is ground.
                      • lineslim
                        • May 2024
                        • 5
                        • Sverige
                        Yes, you are correct, I have 5V on pin 5, not on 6.
                        I hope someone will have a clue to what the problem is. I think it must mean something that the fan jumps into life when touching the adjacent component....
                        • lineslim
                          • May 2024
                          • 5
                          • Sverige
                          Update: I tested with another rf board from a working unit, no change. Green light on the on/off button for 2s after pressing it, then nothing, fan does not spin.
                          • lineslim
                            • May 2024
                            • 5
                            • Sverige
                            Found the problem: broken hdmi port, pins shorted to ground
                            • lotas
                              • Jan 2016
                              • 4754
                              • Russia
                              And this needs to be checked first, as well as the USB ports.
                              • gabri2211
                                Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
                                by gabri2211
                                Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
                                This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
                                This NEXUS connector broke.
                                Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
                                The Xbox has a power supply that provides 12 volts on all outputs, so the power...
                                07-28-2025, 07:13 PM
                              • TMTGTR
                                An Xbox One PSU Odyssey
                                by TMTGTR
                                Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                                =>Background:
                                I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                                06-17-2022, 05:40 PM
                                HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                09-12-2024, 02:00 PM
                              • Stevedb
                                Boardview xbox 360 , xbox fat , xbox one x and xbox one s
                                by Stevedb
                                Hi all
                                I will share the boardviews i found internet from the xbox 360 , xbox fat and xbox one x and xbox one s
                                Pasw netcomchetumal.
                                Enjoy it.
                                Greetings Steve
                                From Belgium...
                                04-04-2023, 12:42 AM
                              • grimacelord
                                Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                                by grimacelord
                                Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                                After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                                I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                                10-24-2024, 12:31 PM
