Multimeter repair brymen 786
  • redwire
    • Dec 2010
    • 3912
    Re: Multimeter repair brymen 786
    I find it's all Brymen fanboys over there, any complaint everyone ignores and goes on how great they are and how Fluke needs to run and hide lol. Dave and others are in a conflict of interest selling them for profit.
    I'm unimpressed by Brymens and think they're disposable- black-topped IC's, no schematics, no North American parts source for them etc.
    This DC power switch, P-ch mosfet Q18 and NPN BJT Q19 with MCU turning on Q19. You can force (override) it on with a say 10k (to +3V) touching Q19 base, see if it powers up. The start-up pulse, not sure what makes that pulse.
    In early builds, the rotary switch was defective. No idea what was changed or was fixed by Brymen. Power would cut out. Like in the video I linked to.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8327
      Originally posted by retiredcaps
      He's already got a repair thread on eevblog with no help. See
      https://www.eevblog.com/forum/repair/repair-brymen-786/
      Oh! That sux… I would have thought it would generate some interest.
        • 31198
        does the mcu have a crystal or resonator?
        • ss45
          • Jun 2019
          • 119
          • Brazil
          Yeah... It was really surprising that I received no reply at all in eevblog.....
          Badcaps forum rocks !
          • ss45
            • Jun 2019
            • 119
            • Brazil
            Thanks for the suggestion
            I have tried that. Blank screen
            • ss45
              • Jun 2019
              • 119
              • Brazil
              #26
              There is crystal on the front side of board,
              Opposite of side where what assumed to be main mcu is soldered on
              • redwire
                • Dec 2010
                • 3912
                With Q19 forced on, I would check if the MCU has power (at 0R R150 pin 3?) and power appearing across big C86 and C59 (other side of board) 33uF 16V tantalum. Next to look at is the clock.
                The DMM IC (BTC M200 034K-0000) has a 4.9152MHz crystal, but I don't see one for the MCU. The crystal region has not so great PC board design, make sure it's clean and no bad connections to it because it's hand-soldered along with the big film cap. The buzzer is also in the way.
                I don't see how the MCU gets it's clock, could be RC or it has a feed from the DMM IC to MCU pin 1 or 2, tricky pcb layout.
                • ss45
                  • Jun 2019
                  • 119
                  • Brazil
                  #28
                  Could be... I don't have any interest to pursue it down the rabbit hole.
                  So I decided to chuck it into junk box.
                  Not going to touch it anymore.
                  Thanks for all the suggestions and inputs
                  • q2q3
                    • Oct 2011
                    #29
                    Hello, you can post the contents of the 24cs04 microcircuit here. It is on a board with buttons.
                    • JeffreyOG
                      • May 2024
                      I've noticed the same trend with Brymen fans. Any critique tends to get overshadowed by praise, and it does seem like there's a bit of a conflict with sellers promoting them.
                      • redwire
                        • Dec 2010
                        • 3912
                        Did you try buy a Brymen multimeter in Canada? As soon as you have a problem, toss it in the garbage - return shipping is too expensive.
                        They are locked out of North American distribution channels. They OEM for Fluke and a few others so I say they are contractually locked out.
                          • 31198
                          eevblog is packed with assholes,
                          you get the same fanboy shit with Fluke even though in the miiltimeter tests the 87 got smoked by the piezo-ignitor instantly and the uni-trend stuff survived it
                          also they (dickheads) complained that a uni-trend clamp meter wasnt safe because it had no fuses!
                          i had to explain to those geniuses that the fuses are only on a meter's current range - THAT DOESNT EXIST ON CLAMP METERS. 🤦‍♂️
                          • redwire
                            • Dec 2010
                            • 3912
                            I considered buying a Brymen multimeter- but instead bought a used Fluke 87.
                            The Brymen's have a fair number of problems and I needed reliability as #1. All my Taiwan multimeters (bench/handheld) are shit - either they blow up easy or some issue with the mechanical, display etc. They just aren't good enough.
                            Having no support in North America is the deciding factor - any repair, calibration, firmware update - ain't gonna happen just bin it.
                            It was work to tear the Fluke apart and clean it up but the thing works rock solid. Piezo-ignitor won't blow one, most Uni-T, ANENG etc. have no MOV's cheap bastards.
                            Thing is both Brymen and Uni-T can OEM build really good stuff - but they don't under their own brand name. It's cheapened on purpose, which is kind of sad. Literally $1 to take them up there but they will not spend.
                            I did not watch the EEV video bashing Fluke and tooting Brymen, in a conflict of interest way. Of course Fluke are grossly overpriced for some time now, a cash cow for Fortive- but they are King of the Hill in a few ways. At least their rotary switch isn't cheap shit.
                              • 31198
                              all my ANENG/Zotek have mov's
                              • redwire
                                • Dec 2010
                                • 3912
                                Not the PTC - is that what you mean? Cheapest DMM's don't use any MOV's. None of ANENG have them AN8008, 870, 301, V8, etc. - no MOV's or proper PCB spacings- so a BBQ lighter kills them easy.
                                But I find the (real) time a DMM gets hit with a many kV spike is from ESD when you walk around with one and the leads touch something, static discharge in winter.
                                Working with HV (over 1kV) these cheap meters are off my bench.
                                UT-61E leaves them out except for Germany, UT-61E+ has three so they finally look decent.
                                Brymen does have tough input protection and safety certs, matching Fluke.
                                Multimeter (DMM) information and reviews
                                • JeffreyOG
                                  • May 2024
                                  I think Brymen multimeters have their flaws – like those black-topped ICs and lack of schematics. Plus, finding parts in North America is a hassle. Regarding the repair, the DC power switch issue with the P-ch MOSFET (Q18) and NPN BJT (Q19) controlled by the MCU is tricky. You can try forcing it on with a 10k resistor to +3V at Q19's base to see if it powers up. The startup pulse is another mystery – not sure what triggers it. I had issues with early builds too, especially with the rotary switch causing power cuts. Brymen claimed to fix it, but who knows? For those still on the hunt for reliable multimeters (found some info here https://www.cef.co.uk/catalogue/cate...nt-multimeters), it's essential to weigh these factors carefully.
                                  • redwire
                                    • Dec 2010
                                    • 3912
                                    In Toronto but linking to UK CEF website? What's with that.
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8327
                                      I am not aware that Brymen has a Canadian nor American dealer. Usually only some Brymen products were available here as a rebranded Greenlee… The Brymen I got, I bought from the EEVblog store. So far so good, I am happy with my Brymen.
                                      • ClockChip
                                        Advice sought - Selector switch knob repair
                                        by ClockChip
                                        Hello Everyone,
                                        I am seeking to repair a knob on an old (circa 1971) Panasonic clock radio (a model RC-6900). The good news is that I have the small, easily lost knob. The bad news is that the knob has come off a slotted post and I need to re-attach it in such a way that I won't have to worry about it coming loose again.
                                        Here is a picture of the bare slotted post (if I have the term right) the knob should be attached to:
                                        As you can see, this is an Old School selector switch, which means it's pretty stiff. Put another way: the knob has to fit...
                                        07-20-2024, 04:52 PM
                                      • madfreak
                                        Which multimeter to choose : BRYMEN BM 869S OR UNIT UT18B PRO ?
                                        by madfreak
                                        Hello, there were probably topics like this, but I need opinions about these 2 multimeters or maybe there is another one on the market worth to buy ? .
                                        I am going to change the multimeter and I do not know if the 2x higher price for Brymen will convert into speed and comfort of a work ...
                                        What would you recommend?
                                        Brymen BM869s or UNIT UT18B pro?
                                        I care about accuracy and security, and the meter will be used for computer hardware.
                                        Thank you very much in advance for your comments and suggestions
                                        04-30-2022, 01:10 AM
                                      • dj8452000
                                        How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                        by dj8452000
                                        I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                        02-18-2025, 08:28 AM
                                      • trex66
                                        Craftsman 82345 Multimeter broke!
                                        by trex66
                                        My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                                        03-04-2025, 04:26 PM
                                      • barathi
                                        Digital Multimeter Brymen 896s Issue
                                        by barathi
                                        Hey Guys,
                                        I've been having a couple of issues with my DMM recently and I've no clue on how to go about fixing it.
                                        1) The DMM doesn't read AC voltages anymore. All I have is OL
                                        2) The temperatures readings are stuck at ~330˚C on both T1 & T2
                                        I looked at the internals and there is no obvious sign of damage. I've not connected my DMM to a high voltage source on a wrong mode (to the best of my knowledge). The fuses are good. The battery is new and in perfect shape.
                                        Being a complete noob, I'm clueless as to what my...
                                        03-02-2021, 11:57 PM
