DMHC DC Motor Controller for Electric Quad
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    Hi, I was given a Funbikes 96 36v 800w Electric Quad.
    Problem is the guy who had it connected the batteries wrong. It has 3 12v batteries in series, but he connected the 3 batteries in a complete circuit (diagram attached to explain, please excuse my drawing lol) and connected them to the quad, and said the motor controller made a fizzing noise and smoked lol.
    Funbikes no longer stock a replacement controller, and I am unable to locate one online with the part number.
    I opened up the controller, and immediately could see some blown caps, so I have replaced all the caps, however it still does not seem to work.
    I am litterally clueless where to even begin with this, so any help and advice greatly appreciated.
  • petehall347
    • Jan 2015
    • 4440
    • United Kingdom
    Re: DMHC DC Motor Controller for Electric Quad
    he most likely connected it backwards .
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8703
      Shorting out the batteries like drawn will protect the controller and should not fry it. The batteries will take the brunt of the damage in this case -- but as petehall347 says, this is not what happened. It was reverse connected, sparks flew, capacitors exploded, silicon melted.
      Likely all semiconductors like the controller succumbed to the backwards voltage. So past the capacitors, the controller probably melted. The switching transistors may have survived, don't know but you may have to replace them too.
      • Bloopeta
        • Jun 2018
        • 526
        • United Kingdom
        The most annoying part is im strugging to plug the controller back up, as was unplugged when I got it, so am having difficulty working out what plugs go where as alot are the same, however the colours of the wires on the controller dont match up to the colours of the wires on the quad :/
        Looking at the board I can see initials where wires are connected, i.e. GND, but struggling to work out what the others mean
        SL
        SB
        GS
        KEY (ignition)
        GND (ground
        But dont know what these are
        SL (3 wires go to this one)
        SB
        GS
        DS
        +5V
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8703
          not enough to go by for someone who's only familiar of the general structure of such control boxes - can assume fat wires goto the motor or battery and thin wires to the throttle and brake controls... past that, you need to scrutinize the board to figure out what goes to what.
          TBH it might be easier to just buy another generic controller and replace the burned one.
          • Bloopeta
            • Jun 2018
            • 526
            • United Kingdom
            I seem to have worked out where the wires all go now.
            I get power to ignition switch, and to forward/reverse/off switch, and the horn works lol.
            But apart from that, I havnt got it to move yet.
            One battery seems pretty shot, im only getting a total of 28v, but would assume it should still work with that but underpowered/slow??
            I have emailed the company who makes the controller to see if they can advise where to get one, but if not I think n new generic one may be the only option if I can get one thats compatible. Just depends on the cost, as may not be viable, especially if need a replacement battery also. Plus, due to contoller problem Im not even sure the motor is good.
            Just seems a shame to scrap it
            • R_J
              • 9608
              There should be a voltage regulator ic on the board, likely that to220 near the caps, If the voltage was reversed and blew the caps it may have damaged the input to the regulator ic and if that is the case it may have protected the rest of the circuit, so check the number on the to220 parts to see if one is indeed a low voltage regulator and check its output voltage
              • petehall347
                • Jan 2015
                • 4440
                • United Kingdom
                charge batteries separately
                • Bloopeta
                  • Jun 2018
                  • 526
                  • United Kingdom
                  I am with a car battery charger, one battery doesnt seen to want to charge past aprox 7 volts, and holds around 5.49v standby
                  • Bloopeta
                    • Jun 2018
                    • 526
                    • United Kingdom
                    Which is that please?
                    • R_J
                      • 9608
                      It might be this one, post the number that is printed on it. Also post the number of that ic next to it, that might help with what voltage the circuit needs. Likely around 5vdc
                      • Bloopeta
                        • Jun 2018
                        • 526
                        • United Kingdom
                        Originally posted by r_j
                        it might be this one, post the number that is printed on it. Also post the number of that ic next to it, that might help with what voltage the circuit needs. Likely around 5vdc
                        lm317t
                        g4091 vw
                        chn 321
                        • petehall347
                          • Jan 2015
                          • 4440
                          • United Kingdom
                          https://uk.farnell.com/stmicroelectr...317/dp/9756027
                          • R_J
                            • 9608
                            Oh Great, an adjustable LM317t, You should be able to check its output voltage between the metal tab and ground
                            • Bloopeta
                              • Jun 2018
                              • 526
                              • United Kingdom
                              Ive ordered one
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8703
                                A "good" AGM SLA will charge back up if discharged completely and recharged right away, you probably have bad or worn out SLA packs and probably need to replace those, too. If you don't recharge right away, you increase the chance of it becoming unrechargeable fairly quickly -- I wonder how long the battery sat discharged.
                                Note that one dead battery can kill the whole pack making the vehicle unusable, especially if the controller detects battery issues. I have a 24V ⅓HP scooter, battery pack is shot. Powers up, no motion despite still being close to 24V. It droops below 24V for a moment when the motor starts and the controller will stop trying to power the motor before the voltage goes any lower.
                                • Bloopeta
                                  • Jun 2018
                                  • 526
                                  • United Kingdom
                                  I had to remove it from board to read the number, so will just replace now with new one
                                  • Bloopeta
                                    • Jun 2018
                                    • 526
                                    • United Kingdom
                                    Think I best get a new battery, as one is only holding 6v at best.
                                    Not sure how long they were left discharged, but I suspect it was quite a while
                                    • Bloopeta
                                      • Jun 2018
                                      • 526
                                      • United Kingdom
                                      Just to update, it arrived today, installed that, and have a replacement battery for the bad one, and still not working
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8703
                                        Well you'll have to go and test each device on the board and see if any are dead. Not enough data here for us to really give any additional suggestions at this point, picture angles are insufficient.
                                        • Astonished
                                          Fixing the Charge Circuit of the Batteries of the DC Motor
                                          by Astonished
                                          Hi friends of electronics
                                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                          Please help me fix this circuit.
                                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                                          01-28-2025, 06:24 AM
                                        • redwire
                                          Exploding motor cap on Ryobi electric pressure washers - product recall
                                          by redwire
                                          Exploding motor cap on Ryobi electric pressure washers.
                                          Recall is for 764,000 units and 16,000 sold in Canada.
                                          "TTI Outdoor Power Equipment has received 135 reports of capacitors overheating, including 41 reports of explosions, resulting in 32 injuries and/or fractures to the fingers, hands, face, and eyes."
                                          Broken bones? Shrapnel In your face? Never reach for the on-off switch, just run away!
                                          Found this pic on Reddit, cap looks like a plastic housing electrolytic? with big rubber bung at the end.
                                          Safety vent too expensive! DELETE DELETE
                                          08-31-2025, 11:03 AM
                                        • carrzkiss
                                          Cyberpower cps1500avr not charging batteries
                                          by carrzkiss
                                          Hello, all.
                                          Cyberpower Battery Backup Unit.
                                          I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                          When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                          In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                          Checking the voltage, it was down to 22v.
                                          I quickly removed everything...
                                          06-15-2024, 02:10 PM
                                        • SolomonMan
                                          Electric Motor Question....
                                          by SolomonMan
                                          All,
                                          Yesterday in the morning the fan was fine. Its approximately 10 years old. Its one of those high Velocity types.
                                          In the afternoon I noticed it was not running any longer.
                                          During the investigation, I confirmed the wiring, confirmed the 3 way switch is fine, the Capacitor measures the correct Microfarads. So I went to the Motor;
                                          No smell of burnt and it spins very easily. I started to measured the continuity between the 6 wires.
                                          I have included a diagram from a YouTube video I found but basically the wiring is identical. The only exception...
                                          10-29-2023, 08:02 AM
                                        • cjard
                                          A motor controller is a power supply, right?
                                          by cjard
                                          Hoping someone here will be able to provide a few pointers with this. I've got a motor controller board for a device that moves a caravan. A DC motor on each wheel is supplied with 12v DC or -12V DC depending on whether the remote control is pushed in "forward" or "backward" mode. The control is arranged by having 2 relays per motor that, at rest, are all connected to the negative.. If the motor is to go forwards, then relay 1 activates meaning the motor sees "positive negative" on its terminals 1 and 2. If the motor is to go backwards then relay 2 activates meaning...
                                          10-14-2020, 01:24 PM
