DMHC DC Motor Controller for Electric Quad
  • Bloopeta
    • Jun 2018
    • 526
    Re: DMHC DC Motor Controller for Electric Quad
    Originally posted by eccerr0r
    Well you'll have to go and test each device on the board and see if any are dead. Not enough data here for us to really give any additional suggestions at this point, picture angles are insufficient.
    Ive just ordered a replacement controller, seems alot quicker in the long run as taking a week at a time for components to arrive
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8702
      Yep, agreed, imagine if you took my advice from my post a week ago today no offense intended, but sometimes these things take a boatload of damage when reverse connected. Would be nice if all electronics had protection or designed for accidental reversal, but it would increase price a lot.
      • Bloopeta
        • Jun 2018
        • 526
        Would have been alot quicker lol
          • Jul 2011
          • 6069
          Hopefully the controller that you are buying is very well marked so this mistake will not happen again but if you find that it not marked very well please take the time to mark the wire leads correctly and easily seen to lower the risk of hooking it wrong ( or all the wires are the same exact color which is also a nightmare to deal with I would use different color heat sink tubing for the battery connectors preferably red and black )
          I have had to do this myself quite a few times because the device was not marked correctly or was not marked at all
          I have even seen circuit boards with no ledger on it at and you had trace the circuit to know how to connect it up correctly this can be a nightmare to do
          • Astonished
            Fixing the Charge Circuit of the Batteries of the DC Motor
            by Astonished
            Hi friends of electronics
            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
            Please help me fix this circuit.
            (the datasheet of the IC: https://pdf.datasheet.live/28...
            01-28-2025, 06:24 AM
          • redwire
            Exploding motor cap on Ryobi electric pressure washers - product recall
            by redwire
            Exploding motor cap on Ryobi electric pressure washers.
            Recall is for 764,000 units and 16,000 sold in Canada.
            "TTI Outdoor Power Equipment has received 135 reports of capacitors overheating, including 41 reports of explosions, resulting in 32 injuries and/or fractures to the fingers, hands, face, and eyes."
            Broken bones? Shrapnel In your face? Never reach for the on-off switch, just run away!
            Found this pic on Reddit, cap looks like a plastic housing electrolytic? with big rubber bung at the end.
            Safety vent too expensive! DELETE DELETE
            08-31-2025, 11:03 AM
          • carrzkiss
            Cyberpower cps1500avr not charging batteries
            by carrzkiss
            Hello, all.
            Cyberpower Battery Backup Unit.
            I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
            When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
            In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
            Checking the voltage, it was down to 22v.
            I quickly removed everything...
            06-15-2024, 02:10 PM
          • SolomonMan
            Electric Motor Question....
            by SolomonMan
            All,
            Yesterday in the morning the fan was fine. Its approximately 10 years old. Its one of those high Velocity types.
            In the afternoon I noticed it was not running any longer.
            During the investigation, I confirmed the wiring, confirmed the 3 way switch is fine, the Capacitor measures the correct Microfarads. So I went to the Motor;
            No smell of burnt and it spins very easily. I started to measured the continuity between the 6 wires.
            I have included a diagram from a YouTube video I found but basically the wiring is identical. The only exception...
            10-29-2023, 08:02 AM
          • cjard
            A motor controller is a power supply, right?
            by cjard
            Hoping someone here will be able to provide a few pointers with this. I've got a motor controller board for a device that moves a caravan. A DC motor on each wheel is supplied with 12v DC or -12V DC depending on whether the remote control is pushed in "forward" or "backward" mode. The control is arranged by having 2 relays per motor that, at rest, are all connected to the negative.. If the motor is to go forwards, then relay 1 activates meaning the motor sees "positive negative" on its terminals 1 and 2. If the motor is to go backwards then relay 2 activates meaning...
            10-14-2020, 01:24 PM
