Motor control board repair
  • cyclones
    • 69
    I have a motor control board I am trying to repair. I've been told the motor is fine, but the control board will only make the motor go one direction but not the other. Power comes in through a linear transformer and then a rectifier bridge and then filter caps. No schematics for the board. Relays on the board are 24V so I started by setting my bench PSU to 24V and injecting voltage. There are several LEDs. All but one LED lights up. There are test points labelled +15V, 0V and -15V. When checking voltage potential between +15V and 0V, I get a perfect 15V. For -15V to 0V, my meter shows approximately +1.15V. There are two voltage regulators with large heat sinks on the board. One gets warm, and the other is room temp. I think i will check for input to the cold voltage regulator next, but I'm trying to figure out why I'm getting the +1.15V reading on the -15V.
    • Jul 2011
    • 6027
    Re: Motor control board
    Post a picture of this device so we can see how this is made so we might be able to figure out what might be going on
    • cyclones
      • 69
      Here's a picture. There's a second board on the bottom that's almost entirely diodes and transistors. I checked all those with a meter and they seem good. I'll get a picture of the bottom board if needed.
      • R_J
        • Jun 2012
        • 9533
        What are the numbers on the regulator ic's? especially the negative one. Doe the transformer only have 2 wires supplying the board or is it center taped?
        you might want to indicate which one gets warm, is it the positive one or the negative one?
        If you don't have a balanced circuit +15 and -15, you could see some positive voltage on the negative supply.
        • cyclones
          • 69
          The two regulators which have heat sinks both have the following on them:
          on the board they are labelled AVR1 and AVR2.
          on the IC packages themselves, there is
          3125p
          6n27
          on both. they seem to be identical, but only one is getting warm. The main transformer seems to have multiple taps.
          • R_J
            • Jun 2012
            • 9533
            It's nice top know one is getting warm, it would be nicer to know WHICH ONE? I will guess and say the +15 is getting warm and the -15 is not.
            If both components have the same numbers it is unlikely they are both positive and negative voltage regulators
            Do both regulator ic's have a common ground? have you checked the IN on the -15 ic to see if it has any voltage?
            The transformer secondary is likely center tapped and the center tap goes to ground, and one part of the winding supplies each ~ on the bridge rectifier, then the + of the bridge supplies the positive IN for the +15v regulator and the - of the bridge supplies the negative IN of the -15 volt regulator
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8682
              Odd both regulators are TO-3P and the board silkscreen says out-in(tab)-G which is typical for the negative rail regulator (should be in-G(tab)-out for positive). Make sure the "in" is the right voltage in any case.
              These regulators are probably NOT for the motor but rather for the zillion op amps on the board that may control the motor drivers.
              • redwire
                • Dec 2010
                • 3900
                Either the -15V rail has wimped out and collapsed, or something is overloading the -15V regulator. It's not good for IC's and semi's power if a -ve rail goes +ve. I would put a reverse diode from each of the two rails to GND, to keep working on this.
                The two VREG's look like on the main board two big heatsinks, the IC's are TOP-3 packaged, one says G/IN/OUT.
                The second board has a bunch of dual diodes and transistors, I don't see a voltage regulator in the line up.
                  • Jul 2011
                  • 6027
                  What type of motor does this have and what components are on the second board other than the ones on the heat sink
                  • cyclones
                    • 69
                    I checked tonight in diode test mode between the AVR1 ground to the AVR2 ground and got a diode voltage drop -- about .595 volts.
                    • cyclones
                      • 69
                      What redwire says -- a bunch of dual diodes and transistors.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8682
                        photo of the tracks on the back side of the board? does not seem right that two apparently "GND" ports are not grounded/tied together - unless the company was playing tricks with virtual grounds and using the same BOM device for both rails... Or the silkscreen is wrong and the chips on the heatsink are different, still don't know what they are...
                        • cyclones
                          • 69
                          I'm going to check the linear input transformer by disconnecting it from the board and applying 120VAC to the primary windings and see what all the outputs are. If everything looks good there, I'll connect up the board to 120VAC through an isolation transformer and see what happens. Got to get the supply voltages worked out first before checking anything else.
                          I've gotten more information about the problem. The outputs for one motor work, but not for the other motor. The maintenance guy switched the non-working motor to the contacts for the working motor and the motor worked, so it's probably something in the output, although it might be a problem on the input side too.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8040
                            Another possibility is the +15v is shorted with the -15v rail somewhere.
                            • cyclones
                              • 69
                              I applied 120vac to the primary and here's I measured with green as ground:
                              grey one is 10V
                              blue one is 40V
                              purple is 2.25V
                              yellow is 5V
                              orange is .5V
                              • R_J
                                • Jun 2012
                                • 9533
                                Re: Motor control board repair
                                When you checked for the missing -15 volts, was that using the main transformer with 120vac applied or was it when you used your 24vdc bench power supply?
                                • cyclones
                                  • 69
                                  That was with the power supply. I finally got a chance to try the board in the machine and the input voltage was 107VAC.. not sure why it's 107V because that is just outside the typical 110-120VAC. Either way, in that case the -15V was also missing, and I was still getting about +1V on that rail, so my first task will be to get that figured out and repaired.
                                  • R_J
                                    • Jun 2012
                                    • 9533
                                    107vac is likely that they have 3 phase power supplying the building and they use one phase to supply the board, this is normal.
                                    Locate the source for the -15v, trace the -15volt point back, the ac for this circuit is likely supplied from the transformer and then through a diode or bridge to give a negative voltage.
                                    • cyclones
                                      • 69
                                      It looks like the -15V goes back to SR3 and the voltage regulator that doesn't get warm, AVR2. From looking at the trace lines and from the meter, it seems like the AVR2 is in parallel. SR3 has a + and - and two middle pins that go to the AC input, so it seems like a rectifier bridge, but I don't know what the SR3 designation could mean. Any ideas?
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8682
                                        Black square thing with four pins on the corners, a hole in the center, and a notch cut from one corner is a bridge rectifier. Can't see the designator, need more pictures from different angles so we can tell what you're talking about.
                                        Have to say it's highly irregular to have AVR1 and AVR2 in parallel, then again they being identical parts? What are the part numbers? Why does AVR1 look like it peeled from the heatsink?
                                        oh...so avr1 and avr2 are not parallel as the G pins are not connected, so one of them is being used strangely for bipolar supplies?
                                        Still a mystery what part numbers they are and how they're connected to the rest of the board...
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • Yanleb
                                          LG 60PK550 Logic Control Board EBR63450301
                                          by Yanleb
                                          Hi all, I just want to share the repair of my 60PK550-UA TV set.
                                          The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                                          But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                                          All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                                          C57: 3.30V
                                          C61:...
                                          07-20-2023, 12:38 AM
                                        • Joe24
                                          Maytag Whirlpool Kenmore clothes dryer data bus
                                          by Joe24
                                          Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                                          Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                                          I've been over the board looking for...
                                          01-13-2025, 06:50 PM
                                        • redoxy
                                          Control Board Replacement for 2K display
                                          by redoxy
                                          I am looking at the option of replacing my control/driver board to one with HDMI and/or Display port input on a 2K LED (I think IPS) screen.
                                          The display is Samsung LTM270DL07.
                                          I have tried using the model number to search for a compatible control/driver board but so far my efforts have been futile.
                                          I am looking for inputs on what board could potentially be used for my display.
                                          Attached are pictures of the display label information and connectors (CON30 CON40 only) and pictures of the current control board.
                                          Also attached is a technical...
                                          03-14-2023, 08:52 PM
