I have a motor control board I am trying to repair. I've been told the motor is fine, but the control board will only make the motor go one direction but not the other. Power comes in through a linear transformer and then a rectifier bridge and then filter caps. No schematics for the board. Relays on the board are 24V so I started by setting my bench PSU to 24V and injecting voltage. There are several LEDs. All but one LED lights up. There are test points labelled +15V, 0V and -15V. When checking voltage potential between +15V and 0V, I get a perfect 15V. For -15V to 0V, my meter shows approximately +1.15V. There are two voltage regulators with large heat sinks on the board. One gets warm, and the other is room temp. I think i will check for input to the cold voltage regulator next, but I'm trying to figure out why I'm getting the +1.15V reading on the -15V.
Motor control board repair
Re: Motor control board
Post a picture of this device so we can see how this is made so we might be able to figure out what might be going on -
Here's a picture. There's a second board on the bottom that's almost entirely diodes and transistors. I checked all those with a meter and they seem good. I'll get a picture of the bottom board if needed.Attached Filesif you find these attachements useful please consider making a small donation to the site
What are the numbers on the regulator ic's? especially the negative one. Doe the transformer only have 2 wires supplying the board or is it center taped?
you might want to indicate which one gets warm, is it the positive one or the negative one?There are two voltage regulators with large heat sinks on the board. One gets warm, and the other is room temp
If you don't have a balanced circuit +15 and -15, you could see some positive voltage on the negative supply.Last edited by R_J; 10-31-2021, 03:21 PM.Comment
The two regulators which have heat sinks both have the following on them:What are the numbers on the regulator ic's? especially the negative one. Doe the transformer only have 2 wires supplying the board or is it center taped?
on the board they are labelled AVR1 and AVR2.
on the IC packages themselves, there is
3125p
6n27
on both. they seem to be identical, but only one is getting warm. The main transformer seems to have multiple taps.Attached Filesif you find these attachements useful please consider making a small donation to the site
It's nice top know one is getting warm, it would be nicer to know WHICH ONE? I will guess and say the +15 is getting warm and the -15 is not.
If both components have the same numbers it is unlikely they are both positive and negative voltage regulators
Do both regulator ic's have a common ground? have you checked the IN on the -15 ic to see if it has any voltage?
The transformer secondary is likely center tapped and the center tap goes to ground, and one part of the winding supplies each ~ on the bridge rectifier, then the + of the bridge supplies the positive IN for the +15v regulator and the - of the bridge supplies the negative IN of the -15 volt regulatorLast edited by R_J; 10-31-2021, 04:53 PM.Comment
Odd both regulators are TO-3P and the board silkscreen says out-in(tab)-G which is typical for the negative rail regulator (should be in-G(tab)-out for positive). Make sure the "in" is the right voltage in any case.
These regulators are probably NOT for the motor but rather for the zillion op amps on the board that may control the motor drivers.Comment
Either the -15V rail has wimped out and collapsed, or something is overloading the -15V regulator. It's not good for IC's and semi's power if a -ve rail goes +ve. I would put a reverse diode from each of the two rails to GND, to keep working on this.
The two VREG's look like on the main board two big heatsinks, the IC's are TOP-3 packaged, one says G/IN/OUT.
The second board has a bunch of dual diodes and transistors, I don't see a voltage regulator in the line up.Comment
What type of motor does this have and what components are on the second board other than the ones on the heat sinkComment
photo of the tracks on the back side of the board? does not seem right that two apparently "GND" ports are not grounded/tied together - unless the company was playing tricks with virtual grounds and using the same BOM device for both rails... Or the silkscreen is wrong and the chips on the heatsink are different, still don't know what they are...Comment
I'm going to check the linear input transformer by disconnecting it from the board and applying 120VAC to the primary windings and see what all the outputs are. If everything looks good there, I'll connect up the board to 120VAC through an isolation transformer and see what happens. Got to get the supply voltages worked out first before checking anything else.
I've gotten more information about the problem. The outputs for one motor work, but not for the other motor. The maintenance guy switched the non-working motor to the contacts for the working motor and the motor worked, so it's probably something in the output, although it might be a problem on the input side too.Comment
Another possibility is the +15v is shorted with the -15v rail somewhere.Either the -15V rail has wimped out and collapsed, or something is overloading the -15V regulator. It's not good for IC's and semi's power if a -ve rail goes +ve. I would put a reverse diode from each of the two rails to GND, to keep working on this.
Re: Motor control board repair
That was with the power supply. I finally got a chance to try the board in the machine and the input voltage was 107VAC.. not sure why it's 107V because that is just outside the typical 110-120VAC. Either way, in that case the -15V was also missing, and I was still getting about +1V on that rail, so my first task will be to get that figured out and repaired.Comment
107vac is likely that they have 3 phase power supplying the building and they use one phase to supply the board, this is normal.
Locate the source for the -15v, trace the -15volt point back, the ac for this circuit is likely supplied from the transformer and then through a diode or bridge to give a negative voltage.Comment
It looks like the -15V goes back to SR3 and the voltage regulator that doesn't get warm, AVR2. From looking at the trace lines and from the meter, it seems like the AVR2 is in parallel. SR3 has a + and - and two middle pins that go to the AC input, so it seems like a rectifier bridge, but I don't know what the SR3 designation could mean. Any ideas?107vac is likely that they have 3 phase power supplying the building and they use one phase to supply the board, this is normal.
Black square thing with four pins on the corners, a hole in the center, and a notch cut from one corner is a bridge rectifier. Can't see the designator, need more pictures from different angles so we can tell what you're talking about.
Have to say it's highly irregular to have AVR1 and AVR2 in parallel, then again they being identical parts? What are the part numbers? Why does AVR1 look like it peeled from the heatsink?
oh...so avr1 and avr2 are not parallel as the G pins are not connected, so one of them is being used strangely for bipolar supplies?
Still a mystery what part numbers they are and how they're connected to the rest of the board...Last edited by eccerr0r; 11-12-2021, 12:36 AM.Comment
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
Assuming...7 Photos -
by YanlebHi all, I just want to share the repair of my 60PK550-UA TV set.
The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
C57: 3.30V
C61:...07-20-2023, 12:38 AM -
by Joe24Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
I've been over the board looking for... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
- Loading...
