Caterpillar ECU repair, need N548AB replacement?
This topic has been answered.
Re: Catapillar ECU repair, need N548AB replacement?
a very large percentage in my fix later pile does get fixed at some point. Actually during the shutdown I had all the time I needed to reduce my fix later pile down to zero. Currently this ECU is my only thing in the fix later box! I guess I did pretty good. My problem at the moment is, that I have way too many things going that need to be done before it gets too cold outside. Work is total nuts these days and everybody wants something done or fixed before it's getting cold outside. Oh well... at least I still have a job.Leave a comment:
My fix later pile is the same way but some of the time it does get fix but far more of them become partsLeave a comment:
My "fix later pile" tends to end up being the spare parts pile
Well, I guess that thing goes in my “fix later pile”… for some crappy winter day or another boring lockdown. Thanks anyway guys for all the ideas!Leave a comment:
Just saying, it's just as easy to make fakes and even cheap chinese knockoffs would work as good or even better than the original at much lower cost!Leave a comment:
not fakes, i mean "recycled" / "re-directed" from the official production.
it happens a lot,
smd stuff is on reels of 500-5000,
they dont wait for the reels to run out before swapping them - where do you think the short reels of a few dozen to a few hundred parts go? in the trash? LOL
there is a shopping plaza in shenzen 10 floors high - nothing but component sellers.
i'm sure it's not a coincidence that it's in the same region as all the production companies!Leave a comment:
You know, they probably did sell "surplus" TO247SHT's... easiest device to make fakes of...
but then people noticed they were dead from the get go and refunded all of them...
Wasn't worth it.Leave a comment:
This might be reason that you could not find any information about the part number if it is that it is just a jumper
And
STJ
Might be right that they want you to think that it is not repairableLeave a comment:
it's probably to make it seem unrepairable.
now wouldnt it be funny if you found them in aliexpress - "surplus" from the manufacturing plant!!Leave a comment:
Oh I must have missed that.
It could possibly be designed to draw heat up the pins and dissipate out through the back plate?
I've seen mini heatsinks on a slot A motherboard that were soldered to the board.Leave a comment:
usually, mechanical/assembly reasons
You do realize there are 0 ohm resistors out there, full ceramic resistors that have a single black line on it... why use it when a bare wire works...
Just that when they have multiple SKUs using the same PCB it's easier to replace different parts than retooling the pick and place with jumpers.Leave a comment:
Why make such a device for a dummy short. Much cheaper to put a piece of wire in!Leave a comment:
Or as I postulated early on, it was welded that way to begin with!
If it was a diebond that shorted through a die... it sure would not have separated like that, diebonds are physically weak and the die soldered to the metal would hold on, and you will get the die remnants.
So yes, you got SHorT dummy device here and need to look elsewhere for issues, perhaps that other device that connects to these dummies -- is that shorted?Leave a comment:
The heat sink part is thick and really heavy compared to the top part. I am talking 1.6 gram vs 4.0 grams.O.k. put it this way: the short was between the middle pin 2 and the last pin 3. Something definitely went sour inside on pin 3 and blew through that plastic and shorted out to the heat sink part on pin 2.How thick is the metal portion in the "heatsink" portion?
Not familiar with TO247AC construction since it was meant to be isolating, but a TO220 and TO3P the die is bonded straight to the heatsink pad which is really thick compared to the pin... so it can conduct heat away from the die.
What I'm seeing is that the heatsink pad is ... really thin? Thin enough so that it can actually be torn?
Die should be soldered to the heatsink pad, decapsulation usually damages die bonds. Also centered to reduce thermal resistance...
As much damage as it's taken now, is D-S still shorted?
No kidding... that's why I put it here. A mystery device and a weird circuit. Couldn't pass that.
Maybe I'll put that top part on my belt sander and see what that does.Leave a comment:
oh wait, well at least I'm not the only one who hasn't fully awakened yet... of course it's not going to conduct
The photos are convincing to me now, SHorT.Leave a comment:
It would be interesting to find out what is this device because things are not adding up to exactly what this device isLeave a comment:
Assuming...7 Photos -
by sam_sam_samThis is a new item at Electronic GoldMine that has arrived within the last few weeks
Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
https://theelectronicgoldmine.com/products/g28392
One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...11-24-2024, 01:25 AM -
by TomyleeHi everyone,
Sorry for the person who’s going to read all this !
I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the... -
by corrizeHello, I search this connector (oxydated).
It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
Do you know how to find this connector please ? What is the exact name for find it ?
by zklgfsHi,
I have a Dell Latitude 5590 with motherboard LA-F411P Rev 1.0 that has liquid damage and doesn't turn on anymore when only the charger is plugged in. However, it does turn on when powering it from a battery. I couldn't find schematics for this exact board, but LA-F401P seems to be similar (that post says LA-F411P, but the attached schematics are actually for LA-F401P): https://www.badcaps.net/forum/troubl...oardview-neede... - Loading...
