Fixing a laboratory DSC
    • 31301
    Re: Fixing a laboratory DSC
    lamps in parallel will allow more current.
    lamps in series are pointless unless they are the wrong voltage.
    i mentioned 2 in series because i thought you were going to do it with the 240v side and being canadian your lamps are 120v
    and dont give it 6a or a fault could cause a fire.
    if you disconnect the load from the power supplies then 1a should be more than enough to get them started.
    which is unlikely because we are searching for a fault!
    • vrasp
      • Nov 2019
      • 194
      I had to go back to reading on electricity basics but I think I understand the use of lamp bulbs as a current limiter.
      The part I have a hard time understanding is the number of bulbs to use. If I want to test the device that takes in 6A at 230v, wouldn't the one bulb at 1A be super bright? Then I wouldn't be able to tell if it's bright due to a short or if It's normal.
      Same with the other device that runs at 2A 230v. Wouldn't just one bulb be super bright even if there is no short?
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8716
        Well the example did not indicate what the device under test (DUT) is represented by - it's just generic behavior of the circuit. The DUT could have been either the parallel or single bulb in series. So yes if you hook up two in parallel and treat the singleton one as the DUT you can see that the DUT will need to pass more current and is indicated by such as it'll burn brighter.
        That being said you don't want to allow 6A to go through continuously which is what will happen if you hook up a lot of bulbs in parallel. You only want only one or a few to start off to find "obvious" or critical shorts and then increase them as your confidence that the short has been solved.
          • Jul 2011
          • 6070
          One note KTK-R-1 is a faster blowing than a KTK-1 fuse
          There are cheaper fuses if you do not need 600 volt voltage rating
          I once troubleshooted a machine that was blowing fuses on the controls circuit used the incandescent light
          ( 100 watt ) bulb instead of the the fuse to find the short in this machine if your light bulb is very bright and you only have a one to two amp fuse in this circuit then you definitely have an issue with the this circuit
          • vrasp
            • Nov 2019
            • 194
            Thanks guys. It s much clearer. I think I ll be using that bulb method much more often from now on.
              • Jul 2011
              • 6070
              Here is where you can find a cheaper fuse series
              https://www.amazon.com/Littelfuse-BL.../dp/B07DSPZPX7
              • vrasp
                • Nov 2019
                • 194
                Thanks I ll have a look.
                • magneh
                  Transformer Hahn 230V 20v 6va
                  by magneh
                  Hello all.
                  Not very familiar with transformers and did not find the datasheet for this one.
                  Would these resistance values from Pimary and secondary normal? (check photo in red)
                  Maybe someone with more experience can help me here
                  Appreciate
                  04-25-2025, 03:57 AM
                • learnmore
                  Help choosing replacement transformer for Levoit 600S SMPS
                  by learnmore
                  Hello Community,
                  I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                  Peace
                  LM...
                  11-04-2025, 09:35 AM
                • ohren
                  Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                  by ohren
                  Hello!
                  I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                  Measured voltages with no load:
                  After rectifier diodes
                  12V: 6.17 V
                  5V: 5.67 V
                  Secondary transformer pins AC measurement (really don't know if this says anything)
                  12V: 2-2.5 V
                  5V: 1.04 V
                  I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                  03-18-2023, 10:33 AM
                • mikey5791
                  Is it possible for transformer substitution?
                  by mikey5791
                  Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                  Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                  My questions are
                  1. How do i test to see if the transformer is in good working condition?
                  2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                  Hope you guys understand what i was asking. My intention is...
                  11-03-2022, 02:11 AM
                • dennis_elx33
                  3PHASE STEP-DOWN Transformer in Check
                  by dennis_elx33
                  Hello All,
                  i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                  Problem statement: Power tripped Off
                  Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                  Action Done:
                  1) Replaced the faulty parts with good spare.
                  2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                  12-02-2024, 06:52 AM
