Nintendo Switch no power, charing ok
  • reset1986
    • 308
    • italia
    hi, i have this nintendo switch that does not turn on, the charging circuit is ok, i measure 4.20v at the battery connector, i have already replaced the m92t36 and PI3USB chips, usbc socket and cpu reflow,
    the battery is charged with 4.10 V and I measure about 4 V at the switch power pin,
    the console is always off it does not react to anything, it charges but remains off, do you know what I can control? thank you
  • Cyo
    • Sep 2020
    • 3
    Re: Nintendo Switch no power, charing ok
    Checkout tronixfix on YouTube. He has dealt with switches with this exact issue.
    • vinceroger69
      • Mar 2012
      • 6714
      Maybe worth joining this facebook group if your not already a member some very good switch repair tips have been posted https://www.facebook.com/groups/console.repair.legion
        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 05:30 AM
      • Tomylee
        No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
        by Tomylee
        Sorry for the person who’s going to read all this !
        I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
        While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
        During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
        07-11-2025, 11:52 AM
      • tommy97
        Nintendo Switch Oled - Joy con charging
        by tommy97
        I'm having an issue with a Nintendo Switch OLED that suffered liquid damage. After a full cleanup and replacing the Joy-Con rails and joysticks, everything was working fine for about a week. However, now the Joy-Cons won't charge or connect again.
        I tested with a second set of Joy-Cons, and the issue persists. Measuring the voltage on the connector shows 3.7V instead of 5V, which I believe should be the correct value.
        Any insights or suggestions on what could be causing this?
        03-17-2025, 06:30 AM
      • fab13
        Nintendo Switch lite shuts down after nintendo log and replaced M96T36o
        by fab13
        Hello everyone
        After checking the defective USB-C port and close to a short circuit on the M96T36 chip (8ohm) I have changed both components.
        I specify that there is no other short circuit or heating component(Vu thermal camera)
        First, the problem arises: Error 2101-0001 after the start-up screen ("Nintendo" logo), poor soldering.
        Secondly, I install a new M96T36 and the problem I have is a brief display of the "Nintendo" logo (no short circuit, no sure charge chip, no sure charge port, no sure charge management chip percentage)....
        08-23-2023, 10:54 AM
      • CraigR
        Nintendo switch drown victim help needed
        by CraigR
        Nintendo switch with some water damage came in and I need a picture of components and values on both sided down by the fuel gauge ic. If anybody would have a pic or could help me out it would be greatly appreciated!...
        08-13-2024, 12:22 PM
