Obscure Netac OMD128
  • Logistics
    • Apr 2007
    • 721
    If I recall correctly, I acquired this at a surplus place in my area. I'm trying to figure out what sort of battery it takes. There's a Chinese site that mentions something about 1.2V, but doesn't really explain the battery. I can see it as a USB stick in that it has storage, but the portion, which plays music must be completely, separate internally as it doesn't speak to the computer as a device.
    http://detail.zol.com.cn/46/45854/param.shtml
    Anyone remember these?
    Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
    • 30917
    Re: Obscure Netac OMD128
    i remember a version of those with an lcd.
    it should use an AA cell.
    try holding down different buttons as you plug it in - btw i think you play mp3's from the memory your seeing and the firmware is on a hidden partition.
    • Logistics
      • Apr 2007
      • 721
      The thing is, the battery compartment is larger than a single cell as if it took a proprietary battery. And why the dual contacts at the bottom? I'll put a cell in a picture for comparison sake, when I get home.
        • 30917
        are the 2 contacts connected??
        • Logistics
          • Apr 2007
          • 721
          That's a good question! I'll check.
          • petehall347
            • Jan 2015
            • 4422
            • United Kingdom
            gumstick battery 1.2V, 550mAh, NiMH 6x17x35mm
            • CapLeaker
              Leaking Member
              • 7973
              i remember them too... mine had a single AA in it. But his is different. Can't see the voltage being more than 1.5v...
              • Logistics
                • Apr 2007
                • 721
                Ah! That could very well be it. Thank you! I'll order one up and give it a shot. I actually, have a nimh charger, too.
                • keldeo
                  Obscure Pentium laptop, sudden short?
                  by keldeo
                  I've purchased this weird (and might add appears to have had a fairly rough life) laptop a while ago for $1 at a yard sale. It powered up one time, (saw a POST screen!) Then, never powered again. I've since thrown it in some dark corner, BUT, I've decided to look at it again. First, this seems like a very obscure laptop, mine just has the name "BIT" on it and nothing else. Very similar (same?) can be seen here https://www.vogons.org/viewtopic.php?t=54655.
                  At first, I had gotten the weird mini display on the lower part of the laptop to display a few icons, but if I attempted...
                  01-02-2025, 03:22 AM
                • Biruslapio
                  Samsung's AU series "high quality" panel internally melting
                  by Biruslapio
                  I got this 55 inch AU7X00 TV, it was rebooting and showed no image only a blink of the backlights.
                  I assumed it was either panel or motherboard. Turns out it was the panel, and after applying some tape on the ribbon cable that goes to the left side of the screen, the TV turned on with image, then I suddenly noticed a dark spot and the pixels were turning black on the left edge, I was sad and thought I smashed the screen somewhere, found nothing visually, it looked in perfect condition and if it was there before it would've been noticeable while I was inspecting the TV the first time....
                  07-12-2024, 10:08 AM
                • caspian
                  Why does PCH get shorted internally?
                  by caspian
                  Dear members.
                  I have faced many times various laptops that have PCH with an internal short to GND on the 3.3v rail. I have seen this kind of short both in old and recent laptops.
                  Once I faced this kind of short, I observed that the other components on the mainboard were fine. For example, the 5v and the 3.3v rails were present. Resistance on the 3.3v was low (about 4 ohms) but not zero.
                  Another time I faced this kind of short, I observed that the 3.3v rails was not present due to the short.
                  Another example was described in the following page:
                  https://www....
                  05-12-2022, 04:27 AM
                  LM358 LM358S-13 Datasheet
                  The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
                  Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
                  10-07-2024, 04:12 AM
                • bluto
                  Obscure power supply replacement suggestions
                  by bluto
                  I need recommendations for replacements for this power supply. It is a Seasonic SSF-160U1. It is 160 watt, open frame and has a 24 pin ATX & 4 pin +12v connector. It needs to fit inside of a 1U server chassis (WatchGuard Firebox firewall). The original is discontinued and I need a source of reliable new replacements. Cost is not really a factor, but ideally the replacements should be less than $150-200 each.
                  Any ideas?
                  01-08-2020, 08:34 PM
