Party light no longer bright
  • Rebellelouch
    • Jan 2020
    • 7
    I hate the idea of throwing something like this away if I can fix it and use this opportunity to learn something.
    I have a party light with three leds and a motor that isn't working right. The led are dim. I don't know much about electronics but I have a multimeter and a soldering iron. Thinking maybe a voltage regulator issue?
    Issue is only with the LEDs. motor is turning fine. LEDs light up but very dim. Here are some pics. Any ideas if what to replace?
    I appreciate any help in this. Thanks in advanced!
    • 31150
    Re: Party light no longer bright
    the power supply is probably fine,
    the leds are in series - if one fails it will effect the others.
    it's an old design btw, the newer ones use 5 or 6 leds and a dc motor all in series.
    • Rebellelouch
      • Jan 2020
      • 7
      Hmm.. wonder where I can scavenge a few of these multi colored leds. I'll try that first. That will be easy enough for my skill level. Can I use multimeter to determine which us out?
        • 31150
        read the voltage across each led.
        • Rebellelouch
          • Jan 2020
          • 7
          Yeah.. I don't know what I'm doing.
          I first reflowed solder all around just in case - no improvement
          Took reading off red and black wires and getting something like 22v. Go to first led in series, same reading. Next led around 1v. Then the next led even less. No idea what this means.
          Soldered red and black wires directly to the first led - no improvement
          I notice before during and after all this testing nothing changed in the way the leds are acting. Upon turning on device leds are very dim almost off completely. They seem to brighten up over a short time but only slightly. Not enough to light up the device fully assembled.
          I have to believe it is something on that board. There are two caps a transformer and some other smaller components.
          Help! I just don't want to trash it.
          • R_J
            • 9579
            That is a constant current led power supply. Looks like your problem is that the led's are bad. They seem to be 3v~3.5v 1 watt 350ma gullwing led's
            This is one site that has them I believe, and there are likely a lot more
            https://www.aliexpress.com/item/4000...E&gclsrc=aw.ds
            Or here: https://www.aliexpress.com/item/3281...E&gclsrc=aw.ds
            • Rebellelouch
              • Jan 2020
              • 7
              Thanks for the links. I ordered the leds. Needed 3 and got 30.. oh well.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                LEDs tend to burn out like this: they get dimmer and dimmer until they no longer light up.
                That doesn't necessarily means it's the LEDs fault. While it is possible that the LEDs are cheap quality, it is also possible that they are OK, but whoever designed the driver circuit is over-driving them to get extra brightness/"light output".
                In the case of those cheap 12V flexible LED strips online, it's a little bit of both: the manufacturer often drives the LEDs in those strips right to their maximum ratings. And it doesn't help that the LEDs are cheap quality, so they could never actually sustain their light output ratings that their datasheet states. Case in point: I have a "12V" LED flexible strip that burned out almost completely (very dim LEDs) in just 2 months of 2-3 hours of use per day. Luckily, that strip had 3-in-1 chip LEDs, and only the one connected burned up. The other 2 didn't So I disconnected the burned branch and connected a new one that wasn't used before. But instead of feeding the LED strip 12V like I did before (and mind you, it was 12V to the dot, regulated), I connected them to a 9V power source. With this, the current dropped dramatically (as did the light output of the LEDs).... but I've been using this strip for same amount of time per day for the last 5 years now and my LEDs have not (visibly) lost any brightness.
                So the moral of the story is: don't drive cheap LEDs near their maximum specs, and certainly don't over-drive them to get more light. If you want long life operation, drop the current to 1/3-1/4 and they should last a long time.
                • Rebellelouch
                  • Jan 2020
                  • 7
                  One strange thing to note, I bought it for my kids birthday party and used it just that once for a few hours. Packed it away and was like this the next time I took it out. 1 use and now practically trash.
                  • Rebellelouch
                    • Jan 2020
                    • 7
                    UPDATE: LEDs came yesterday. I installed 3 new ones and they are working at full power!(had to redo it after realizing they had +/- designations and I had two backwards). Thanks for the tips. Saved this guy from the trash can.
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      Nice! Glad to hear it's working properly again.
                      Also, thanks for coming back and reporting on your fix!
                        • Jul 2011
                        • 6057
                        Did you measure the current on this device to see if the LEDs are being over current
                        Because this might have caused this problem in the first place
                        • tmhobadcap
                          Samsung un65h6203af led replacement question
                          by tmhobadcap
                          This tv is with sound but no picture. When light shines on the screen, we can see the image. This is a typical backlight problem. I opened it and found quite a lot of the leds are damaged. But the damaged ones are all shorted. No one is open. Is there a special reason? (From my past experience, both can be happened)
                          When I supply 3V to each of the good leds, the currents range from 105mA to 154mA. From these figures, I think the leds are 3V and about 0.5W. I plan to replace all the damaged leds only (because the price of the led strips is very expensive), but I could not find 3V 0.5W...
                          10-03-2023, 11:37 PM
                        • BlueNitesFire
                          I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
                          by BlueNitesFire
                          So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
                          03-08-2025, 03:49 PM
                          Lithonia Lighting versus Light of America Compact Fluorescent product quality
                          by sam_sam_sam
                          I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                          I also have back when Light of America had these light bulbs available for yard lights
                          The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                          While the Lithonia lighting fixture has all most certain bulb failure
                          So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                          I have only had this light fixture for not more than a year if it...
                          07-02-2023, 03:45 PM
                        • Pipolups
                          Corsair K70 LUX RGB dying LEDs
                          by Pipolups
                          Hi there !
                          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                          10-08-2024, 11:58 AM
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
