Fluke 289 bad supercapacitor replacement repair
  • CapLeaker
    Leaking Member
    • 8146
    Here it goes... we have two Fluke 289, bought one in 2012 and the other in 2013, both are rev. 015 boards. Both supercaps are done for. Take battery out for 3 seconds, put it back in, got date and time error on the display.
    The original supercap was a Panasonic EN series 3.3V 200mF SMD @ 500hrs rated. Digikey #: P14162CT-ND , Manufacturer #: EEC-EN0F204AK . https://www.digikey.com/product-deta...2CT-ND/1937320. Not available anymore.
    Replacement SMD Digikey part #'s:
    ELNA DSK series, 200mF @ 3.3V, exact original size Digikey #: 604-1147-1-ND, Manufacturer #: DSK-3R3H204T614-H2L
    or:
    ELNA DSK series, 220mF @ 3.3V, same diameter, but 3mm tall (will fit too): Digikey #: 604-1020-1-ND, Manufacturer #: DSK-3R3H224U-HL
    I am going to replace them with the 220mF one in both. The original is 1.8mm high, well this one is 3mm high, same diameter. One can fit up to 5mm high in there. Hope this helps someone that sit's in the same boat as I am. There are tons of threads out there and folks took all kinds of different replacements. However, if one likes their replacement cap looking like stock and not having to shim, trim, glue or whatever, these are proper drop in replacements for Fluke 289's with the SMD supercap.
    • 31015
    Re: Fluke 289 bad supercapacitor replacement repair
    many meters have been fucked by that cap leaking!
    • CapLeaker
      Leaking Member
      • 8146
      Unfortunately yes. Which sucks big time, because they aren't really a "cheap" DMM either. I am fortunate, that both caps were not leaking to the board yet making a mess. I suggest strongly to anyone that has a Fluke 287 / 289 to do this test and replace that cap before it is too late. Different revision boards, have different style of supercaps in it too. Also the 189 is affected, but not the 187 series.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Keep in mind these meters have a minimum of 10 years warranty.
        So if anyone is not up to replacing them just send it in to Fluke to have them do it...
        https://www.fluke.com/en-gb/support/warranties
          • 31015
          didnt they fuck around over this?
          i seem to remember a long thread at eevblog about it.
          • retiredcaps
            • Apr 2010
            • 9271
            Yes. See
            https://www.eevblog.com/forum/testge...unt-coin-cell/
            --- begin sig file ---
            --- end sig file ---
            • CapLeaker
              Leaking Member
              • 8146
              There seems to be a mixed bag of results with this issue being fixed under warranty. However since this can be fixed fairly easily and way a faster than sending it into Fluke, I'll just repair it myself.
              • CapLeaker
                Leaking Member
                • 8146
                Got the supercap today, it fits perfect, and the meters are back in business as they suppsed to be.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Nice! But you're supposed to post pictures to make us happy
                  • CapLeaker
                    Leaking Member
                    • 8146
                    Beware you are about to see Fluke porn!
                    I had to take the 289 apart again to make pictures. On a side note: The supercap held the memory for the entire time I had it apart again. So I am happy!
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      Nice!
                      • fabry_85
                        • Jan 2019
                        • Italia
                        HELLO boys!
                        I need your help. :'( :'( :'(
                        I have the tester 289 that as I turn on gives me an "incorrectly connected cables."
                        Could it be the super capacitor?
                        it is damaged. the fluke is 289 and of the year 2008.
                        I found on ebay a PANASONIC GOLDCAP KONDENSATOR Capacitor 0,22F 3,6V 10x5MM[/img].
                        You can help me?
                        Thank you.
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          Check for contamination inside the jacks for the cables.
                          If memory serves me right there is an optical sensor there.
                          So if there is dirt in the ampere jack it will cause this message...
                            • 31015
                            i wonder if putting RTV on the cap would contain it, or if the leak is under pressure??
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Is the electrolyte leak causing damage to other components?
                              Anyway, probably the same answer as whether to use RTV on a regular electrolytic capacitor to prevent leaks, though a supercapacitor does not need to deal with ESR as much if it's just needed to maintain static RAM state.
                              In other words, it leaks because it's under pressure...
                              • redwire
                                • 3907
                                The supercap electrolyte is acidic and it eventually corrodes through the case and causes a lot of damage. Putting RTV over that, uh just a mess for a few dollar part in an expensive multimeter.
                                • redwire
                                  • 3907
                                  For Fluke 289 jack-detect DS2, any top-emitting 0805 IR LED will work, just not too high to hit jack diffuser when you assemble everything.
                                  Original is mentioned as OSRAM SFH 325 FA-3/4-Z series, peaking at 980nm. One guy used 940nm Harvatek HT-170IRAJ works fine.
                                    • 31015
                                    i didnt mean instead of replacement - i meant ON the replacement.
                                    • redwire
                                      • 3907
                                      I see- as an extra seal to protect against future leaks. I'm not sure what the acid is, as silicone sealant dissolves in sulfuric acid and puffs up in nitric and acetic acid. Larger supercaps can take a piss on a PC board. If the cap had a housing or was potted maybe.
                                      • CapLeaker
                                        Leaking Member
                                        • 8146
                                        Did anyone’s replacement cap fail again? Charged up the batteries (takes roughly 2hrs)in my 289 and had to input date and time again. Ugh!
                                        • the_rem
                                          Unknown transformer : how to find a good replacement part ?
                                          by the_rem
                                          Hello guys,
                                          I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                          I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                          04-23-2025, 01:48 AM
                                        • ezenia
                                          PS4 controller left stick potentiometer replacement issue
                                          by ezenia
                                          Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                                          So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                                          I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                                          09-30-2023, 02:19 PM
                                        • quickname
                                          Cyberpower 1500AVR UPS repair
                                          by quickname
                                          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                          Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                                          I decided to verify that the batteries were...
                                          11-12-2023, 09:57 AM
                                        • boosti45
                                          Macbook pro logic board replacement parts quesion
                                          by boosti45
                                          i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                                          08-21-2024, 05:23 AM
                                        • r2digital
                                          klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                                          by r2digital
                                          I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                                          04-18-2024, 03:50 PM
