Like New Nautilus Exercise Bike has Dead Panel
    replied
    Re: Like New Nautilus Exercise Bike has Dead Panel
    Check the resistance between pin1 (left pin) and GND pin that I told you to use to see what resistance you get.
    GH16D is the fixed 3.3V regulator so pin 1 is GND, if it is adjustable type then pin1 will be ADJ, you have 3.3V fixed so pin 1 is GND.
    Hopefully the circuit will not not be damaged when it is fed by >7V instead of 3.3V.
  • vinceroger69
    replied
    sorry my mistake it is the h package thats why i got you too measure the top tab to confirm in the meantime like r_j suggests maybe remove the old part use a 3v supply that way if you have other faulty parts you can place just one order.
  • vestaviascott
    replied
    i would replace this voltage regulator just get the correct package type.h2 package if im correct?
    Just to clarify for the part I need to order, H2 in the diagram below has ground on center pin. However, I'm getting output voltage reading on center pin and the larger oblong connection point on the top of the chip as indicated earlier in reply in post #66. Both those pins are reading 7.2v. The pin one (left pin in my pic in Post #62 above) is reading 0.7v and I'm considering that ground.
    All to say, I believe I need to order the "H package" as indicated in the pic below.
  • vestaviascott
    replied
    Originally posted by R_J
    AZ1117CH-3.3TRG1 Marking GH16D this should be a 3.3 volt regulator
    I've already ordered the part. Here's what I've ordered, if you or anyone can confirm this is the correct part I'd appreciate it (before it ships):
    AZ1117CH-3.3TRG1DICT-ND
    AZ1117CH-3.3TRG1
    Pin one should be connected to ground which would be that checker board pattered trace
    By "Pin 1" you mean the pin on the left as in my pic in Post #62 of RG1 above, correct? That's the one I'm getting 0.7v reading on.
    You could remove the regulator and supply 3 volts to the output trace from a power supply or 3v battery and see if it powers up, likely if you have 7 volts there now, other parts down the line could be damaged.
    "to the output trace" is where on the board in refrerence to the image I posted (Post #62) of RG1 above?
  • vinceroger69
    replied
    Originally posted by vestaviascott
    Exactly. Yes.
    i would replace this voltage regulator just get the correct package type.h package if im correct?
  • R_J
    replied
  • vestaviascott
    replied
    the top oblong tab above those pins do you get 7.2v on that too?
    Exactly. Yes.
  • vinceroger69
    replied
  • vestaviascott
    replied
    dosnt look like ground put your black probe on ground what voltage do you get on the tab?
    0.7v on pin 1
    7.2v (middle pin - Vout) * I measured this several times b/c I was expecting 5v (turns out it should actually be 3.3v)
    8.7v (right pin - Vin)
  • vinceroger69
    replied
  • vestaviascott
    replied
    is it a h or h2 sot 223 package as pin layout is different one the top tab goes too ground the other one dosnt
    GH16D 4266J2
  • vinceroger69
    replied
    is it a h or h2 sot 223 package as pin layout is different one the top tab goes too ground the other one dosnt as its a v out pin
  • vestaviascott
    replied
    Again the 0.7V on that regulator is the output voltage, not GND! Middle pin is GND! It is just that the regulator is bad and dumps the input voltage to GND
    I was just going by this chart in the PDF that was referenced. In these shots, ground is pin 1 left, am I mis-reading? Just trying to learn as I go:
  • CapLeaker
    replied
    Let us know the outcome!
  • vestaviascott
    replied
    Yes, this is correct you need the 3.3V one, GH16D tells you that. I figured that this regulator should get a bit warm... lol. Replace it! Again the 0.7V on that regulator is the output voltage, not GND! Middle pin is GND! It is just that the regulator is bad and dumps the input voltage to GND.
    You need a lot of heat (a good soldering iron or hot air) flux and solder to get this regulator of the PCB.
    The other 2 regulators are 5V
    Thanks. I'll be having these soldered on by a friend who can do it. I'll practice on lesser projects.
  • CapLeaker
    replied
  • vestaviascott
    replied
    You need the 3.3V one.
    OK, can you let me know how I should know whether its 3.3v or not? I was thinking 5volt.
    I'm going to go ahead and order backups for the two 3940M3 chips while I'm at it - I'm already paying $4 bucks for shipping. What voltage are those?
  • vestaviascott
    replied
    Depending on your soldering skills, yes RG2 can be replaced. As for me, I'd have no problem changing that (I do have a hot air rework station). It could be the cause for the dead panel, yes. Could be also that there is more broken. However, fix that what you know is broken first. In this case a new GH16D LDO.
    Here: https://www.digikey.ca/products/en?keywords=AZ1117C
    they have over 20.000 in stock. You need the 3.3V one.
    Thanks! So, this one, correct?
    https://www.digikey.ca/product-detai...ICT-ND/4505206
  • vestaviascott
    replied
    ...The GH16D LDO should have 3.3V output and you have something like 0.8V the rest goes to GND.
    The readings in Post #51 are accurate. Please disregard all prior readings:
    For RG1 (GH16D), voltages are from left to right:
    0.7 (left pin - GND)
    7.2 (middle pin - Vout) * I measured this several times b/c I was expecting 5 V
    8.7 (right pin - Vin)
    The input voltage is sagging a bit due to this. So this LDO is bad. Does this regulator get a bit warm?
    Yes, after about a minute of the device being plugged in, this regulator is extremely hot compared to the others.
  • CapLeaker
    replied
  • KYBOSH
    Samsung UN50TU8000 - Dead Panel Forensic Questions
    by KYBOSH
    I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
    When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
    When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
    Later I checked for shorts on the panel PCB boards but could not find anything.
    When I took a look with the FLIR i noticed the 2 resistors...
    08-10-2024, 08:39 AM
  • NSkyLab
    Vizio D43f-J04 is panel dead?
    by NSkyLab
    TV Model: Vizio D43f-J04
    Main Board: TPD.MT5583.PB751 (60103-00876)
    T-Con: BOE_CC430LV2D_43001 V1.0
    Panel: BOEI430WU1
    The video of the defect is here: https://photos.app.goo.gl/fzfvmUqGXW3c1Nrg9
    This is a dumpster find, don't know if it was hit, there are no visible cracks...
    I though there may be something wrong with the panel voltages.
    Those I managed to find on the T-Con board. Does it seem normal?
    12V: 12.27v
    VCC33: 3.28v
    1.2V: 1.25v
    VGL: -5.87v
    AVDD: 16v
    HAVDD: 7.47v
    VCOM: 7.0v...
    01-29-2023, 08:18 PM
  • howardc64
    LG 49UJ6500 LCD panel lighter band that goes away
    by howardc64
    49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
    Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
    02-19-2023, 12:13 AM
  • triplefour
    SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
    by triplefour
    TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
    tcon is built into mainboard.
    Only one cable goes to panel boards.
    there is a cable from one panel board to the other that links them.
    cost cutting measure that results in us having harder time to diagnose.
    removing the link to the second panel board allows TV to stay on with stable backlight but no image.
    used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
    07-28-2022, 07:59 PM
  • Storyteller12
    QN55Q60R Service Menu Panel Help
    by Storyteller12
    I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
    I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
    I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
    the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
    01-13-2024, 01:57 PM
