Glory ws-21 coin counting and wrapping machine
+ More Options
Posts
  • jsnconcepcion
    • 5
    Hello gentlemen,
    I am in a pickle of trouble, u have the MACHINE listed above and it simply will not initialize on start up. Error codes are as follows ..:
    P OFF
    E911-9 (XX)
    the minute it starts up it automatically tells toy to reset and open and then close top over but same errors show up on display ...i've about exhausted all my avenues and I'm appealing to anyone on the site ...dam near Begging for a ny help i can get...Sincerely...jsnconcepcion
    Much appreciated in advance
    • 30977
    Re: Glory ws-21 coin counting and wrapping machine
    never seen one, but i know coin counters.
    they use optical sensing, check if the lenses are dirty or soldering is bad.
    you will find them near where the coins exit the bowl area.
    • llonen
      • Sep 2014
      • 495
      • hampshire
      Do you have a manual or information about this, since there seems little information other than brochures for this.
      • R_J
        • Jun 2012
        • 9535
        when ever you have mechanical and electronics they need to communicate, the electronics needs to know what state and where the mechanism is. so I would check any switches, optocouplers etc. that are activated by the mechanism.
          Hard to help without seeing the pictures, details info to know what we are dealing with.
          • larryflores
            • Dec 2020
            @jsnconcepcion, did you ever fix this power problem with your Glory WS21?
              ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
              This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-12-2024, 03:28 PM
            • CG2
              Janome DC3050 Sewing Machine Pedal Resistance
              by CG2
              OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
              Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
              04-14-2023, 07:53 AM
            • Soulzink
              Samsug washing machine. Power supply DC41-00189a board issue
              by Soulzink
              I am trying to fix a samsung washinmachine power supply main board.
              I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
              Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
              The power supply board reference is the following: DC41-00189a
              I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
              04-19-2025, 06:26 AM
            • nerdmafia
              Broke off RTC Coin battery pin on HP EliteBook 840 G1 - Operating Systems do not load or install
              by nerdmafia
              Hi first question posting here, but no need to go easy on me!
              I have an HP EliteBook 840 G1 non touchscreen. The symptoms are that: Repairing or reinstalling windows freezes no matter how i try it. Live Ubuntu that works on any other computer also freezes while trying to load it. The RAM sticks and the harddrive work fine in other computers. I broke off the connector by accident, CN4750 and was using the laptop for a while with no coin battery. According to this schematic I found on here, which I THINK is the correct schematic, pins 2, 3, and 4 should short to ground, and they do....
              05-21-2025, 09:39 AM
            • unimatrix93
              How to stabilize AC voltage to CNC machine
              by unimatrix93
              Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
              I have a CNC machine wired to 3-phase 230V AC.
              It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
              The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
              I contacted the electricity company but they refuse to help me solve this problem.
              So I started to look around for some DIY...
              03-17-2025, 05:52 AM
