Sabine Graphi-Q Holy Shorts, Batman!
  • jazzie366
    • May 2016
    • 304
    So my dad has had this Sabine Graphi-Q for years and could never repair it as it's way above his head. Well, I went into it and found two things, the DIGITAL power in rail for the MC3310-KS chips was being dragged from 2.0V to 1.5V. The ANALOG power in rail was being dragged from 5.0V to 0.3V(!). So the chips are shorted. How do I know? Both of them go up to 300 degrees Fahrenheit, after I let them cook for awhile. Plus the inductors on the power rails have melted, not in a way that they're bad, they just have their plastic casings deformed. Still perfectly functional.
    High res zoomable pictures attached. There are 4 components that are circled in one. Red was the 263 degree chips that eventually go to 300. The others are some MC33078 low noise dual op amps. They go up to about 180-190 ish. What I'm wondering is if all 4 chips have gone bad, should I replace them all or should I be looking further? I can't make heads or tails of anything because no schematic and double sided PCB that I think has multiple layers due to the microprocessor/DSP.
    Let me know what you think.
    Popcorn.
    • 31296
    Re: Sabine Graphi-Q Holy Shorts, Batman!
    desolder them and see if the voltages are still being dragged down.
    • jazzie366
      • May 2016
      • 304
      Removed them just now. Thing powers on, except C24 has gone up in smoke. No idea the value at all. Lit up red hot and then went out as the output relays click on. I checked the cap on the other chip for the one that fried, C31, and it measured 5uF. So probably something in the region of 6.3v 4.7uF.
      Not sure where to go from here other than replace that cap with a 4.7uF cap and put a new set of chips in.
      Edit: The Dual op amps still are getting up to 180 degrees. So I assume they are shorted as well. However they are much smaller so that would explain it powering on.
      Also, C31 & 24 are both on the analog power in.
      Popcorn.
        • 31296
        did it get spiked in the past by a bad psu or nearby lightning??
        • jazzie366
          • May 2016
          • 304
          Nope. It was in service years ago and stopped working. My dad is an audio engineer and was using it in his studio. Literally the thing quit while it was being used, Sabine wanted 500$ just to look at it without repair. Fuck that.
          A bunch of chips have failed short and one capacitor has as well, all on the analog power rail. Very weird, going to replace all of them and see if that fixes it. If so, it'll be a nice piece of kit to have working again.
          Also, the power that goes into ALL of his sensitive electronics is filtered by a Monster Power Pro 2500, so there's no chance of any surges hitting the equipment. But there was no surge when the failure occured, it just quit all at once.
          Popcorn.
            • 31296
            you may want to look at the psu for leaky diodes or bad caps incase it caused it.
            • jazzie366
              • May 2016
              • 304
              Update: There was a confession to why it failed. It was sandwiched between two power amps, pure class A, audiophile grade with tubes inside. It was subjected to the 180F heat of both for days on end.
              Also, removing the two 3300's made all the chips in the area stop getting hot. HOWEVER, another problem has arisen. The PSU voltage is too low, the regulator is only putting out 4.5V, when the chips need a minimum of 4.75 to turn on, go figure. Well, I'm going to replace the voltage regulator, as there's not much else in it's way to stop it from powering everything, considering the output of it was put through two filter coils, and then a single 4.7uF 6.3V ceramic cap, as the chips are rated to draw under 1mA under normal operation. So considering these chips were dissipating so much heat it caused the heatsink temp of the regulator to get to 180 degrees, I can happily say that it's likely fucked. New regulator on the way, will check surrounding components, maybe the vref is fucked but I'll see.
              Popcorn.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Yes, replace the regulator, it is most likely damaged. Should work fine then.
                A working TV? How boring!
                • ugamazing
                  Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                  by ugamazing
                  I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                  08-31-2022, 07:34 AM
                • feherhollo
                  WSON8 NEW Bios Chips READ, ERROR, ETC.
                  by feherhollo
                  I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
                  I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
                  For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
                  11-26-2023, 09:33 AM
                • AstutePauciloquent
                  Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                  by AstutePauciloquent
                  Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                  I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                  11-23-2023, 11:02 PM
                • Prott
                  [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                  by Prott
                  Hello dear badcappers!
                  The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                  Backstory:
                  After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                  If there is a way to narrow down which memory module is faulty it would make my life much...
                  06-03-2024, 12:05 PM
                • LukeDavis
                  Is there a list of known dodgy ATI Radeon chips?
                  by LukeDavis
                  Hello again! (People are likely going to get tired of seeing posts from me lol)
                  I'd like to try and compile a list of known bad AMD/ATI Chipsets and graphics processors.
                  While I do not possess the knowledge of some of the brilliant minds on this forum, I can at least mention a few chips I've encountered as being troublesome.
                  1. ATI 216-0752001 (RS880M/RX280M) found inside 2 HP laptops, one I've since deemed screwed, and swapped the board to an intel one, the other HP seems to be less hateful and runs fine.
                  2. ATI Mobility Radeon X1600 and the...
                  02-16-2024, 04:34 PM
