Central lock car key repair
  • Morsus
    • Nov 2016
    • 96
    • Serbia
    Hello folks.
    My neighbor asked me if i can see whats going on with his central lock and alarm car key. He told me he tried to fix it himself but he actually made a mess. So the board contacts are ripped off on some places and I have no idea what should be connected and what shouldn't. I am guessing some of you already knows these small circuits and if you could give me a hint that would be great. So, all of the 4 micro switches work fine. Battery (12V) works too. It's just circuit connection problem I guess. The funny thing around SW3 is actually glue (he used it to fix the switch in the place) and the SW1 had shorter pins so I used wire and solder to lengthen them creating a mess. I will buy new one like tomorrow. Here are the pictures. Thank you all.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Central lock car key
    What *was* wrong with it, and I suspect it was made worse...
    What did it do before, what didn't it do before. What does it do now?
    LED still blinks?
    These tend to be somewhat critical RF circuits and adding crap like glue to the board will affect capacitances and thus affect operation.
    Sometimes there is a reason why to ask a professional before attempting DIY. And likely buying a new one might be cheaper than repairing...
    • Morsus
      • Nov 2016
      • 96
      • Serbia
      Of course the same thing I have said. One of the switches (SW1) was broken, and he replaced it but messed up the board. LED does not blink at all.
        • 31015
        the original fault was corrosion of the tracks from liquid damage.
        • redwire
          • 3907
          I say toss it in the garbage, once the PCB pads are damaged for a pushbutton switch, it will just keep breaking off no matter how much glue.
            • 31015
            no, it's do-able.
            remove the switches,
            cleanup the mess,
            fix the track damage,
            check all the through-hole plating,
            then fit new switches, clean the flux off and test it.
            if it works, put a coating of epoxy over it to hold the switches and keep water off the board.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              I'd say make sure you can get the LED to blink again first (and otherwise work), then deal with jury rigging buttons... no sense fixing a device not worth fixing...
              I'd be a bit worried about water damage on RF devices, especially one that does not appear to be crystal controlled...
              • Morsus
                • Nov 2016
                • 96
                • Serbia
                Originally posted by stj
                no, it's do-able.
                cleanup the mess,
                This is what I had in mind. But I am not really sure about the damaged tracks. I can't really figure out witch ones are damaged and witch ones should not have contact. :/
                eccerr0r: Yes, I would focus on getting the LED to blink.
                  • 31015
                  between the red & black buttons is a fat track, above it is a thin one that is water damaged.
                  you can tell by the dark colour.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    so sw1 is the one that's nearest the IC?
                    What's up with SW3 or I cannot tell what is what because of the angle... is the red switch SW3 or SW4? There is also some novice solder job on the switch nearest D2, what's the story behind that, if only the switch nearest the IC was attempted at replacement?
                    Gawd whoever designed that PCB was not making it easy to repair, then again that was probably their objective. Using that through hole via under the LED to pass power is a fsckup.
                    Well, there is apparently water damage, was it damaged in this manner?
                    • Morsus
                      • Nov 2016
                      • 96
                      • Serbia
                      Oh I see it. Just can't figure out where should the upper (thin) line lead to? Second pin of the SW3? (Image1)
                      Yes
                      It is glue-fixed to the board...yeah yeah I know xD
                      Red one is SW4
                      Not replaced, just glue mess, should be fine :/
                      The replaced SW should be SW1
                      I am not really sure. It could be but the owned would probably notify me about that.
                      • R_J
                        • 9535
                        This trace also needs to be repaired, it supplies the voltage to the common side of the buttons, then the other side of the button goes to a pin on the ic. It looks like they are using 2 diodes as a matrix to get 4 buttons (maybe 2 buttons need to be pressed at the same time to work a function) The diode shown in the diagram would be the led
                        • Morsus
                          • Nov 2016
                          • 96
                          • Serbia
                          Okay I did my best to make it as prettiest as possible xD
                          The big mess at to top actually does not have contact with huge track above it witch Image 2 proves.
                          The problem is that I have no idea where track on the Image 3 leads to. :/
                          Edit: The broken track on Image 3 is actually okay, just protection layer came off and its connected to the D2.
                          Tried it again, no blinking.
                          I added an image 4 where you can see all +12V readings while negative lead is on the battery.
                            • 31015
                            resolder the green inductor, and check the plating where tracks pass through the board to the other side.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Also some stupid checks like whether the IC is getting power, etc... are the voltages on each pin changing when the buttons are pushed...
                              • R_J
                                • 9535
                                The points I marked in yellow should be connected together and have no continuity to ground. The ic pin (1) should be connected to ground
                                The points you marked that have 12 volts supply voltage to the R.F. amp section via that `U' shaped trace (antenna)
                                In image3 I marked a point with a blue arrow, does it connect to one of the diodes (in blue square)
                                I made an image with the one side flipped so the feed-thru's make more sense, I think there may have been a feed-thru where I marked the arrows? That trace might go under that one switch and connect to one of the diodes which might supply the voltage to the ic (I said might)
                                • Morsus
                                  • Nov 2016
                                  • 96
                                  • Serbia
                                  The connection was bad and I soldered it a little bit better so its fine now. ic pin1 is connected to the ground.
                                  Nope, not any of the diodes - any side.
                                  This is correct. There is a connection between the points marked with the arrow.
                                  Should I connect the marked pin on not-existing C6 to the D2 via jumper or something like that?
                                  • R_J
                                    • 9535
                                    I don't know where the line from the c6 location goes, it might just goe to that switch. I was just guessing, the switch at that location would need to be remove to follow where the trace goes, it might go under the switch to a diode it might not.
                                    D1 cathode looks like it connects to 5 of the ic, do you know where the anode is connected? Can you see where D2 is connected? I can't tell from the pictures
                                    I don't know how... but that ic need to get 12 volts on pin 8, and it most likely happens when a button is pushed, and other circuits supply it through a diode, although it could be there all the time but not usually. the ic inputs use internal pull low resistors so to activate the function the button supplies a high (12 volts)
                                    • Morsus
                                      • Nov 2016
                                      • 96
                                      • Serbia
                                      Okay I took it off. Here is the image. Had some trouble soldering it back since the SW pins are so short they can barely get through the half of the board. (less than 1mm)
                                      • Morsus
                                        • Nov 2016
                                        • 96
                                        • Serbia
                                        I have just noticed the 5th pin of the ic should be but isn't connected to the SW1 and I connected it with a jumper, so that is fine now. And also the Q1 pins are shortened like on the picture. Is this good or bad?
                                        Thank you so far.
                                        • envym
                                          MacBook Pro 2018 with Activation Lock
                                          by envym
                                          Hi everyone!
                                          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                          06-27-2025, 08:54 AM
                                        • ArtMov
                                          [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
                                          by ArtMov
                                          Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
                                          1. I made overclocking lock disabled the default in amibcp
                                          2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
                                          03-31-2023, 01:30 PM
                                        • stormanimal83
                                          Nintendo Switch picofly installed cause parental lock how to get Master Key for restoring OFW
                                          by stormanimal83
                                          i bought a use console from ebay fixed it and it has parental lock. seller wasn´t helpful and nintendo either cause they don´t support used devices as they told me per mail. thanks for the bad support here in germany. was totally upset as i read the answer to my mail from 1 week ago.... there was no other way to get rid of that code rather than modding the console cause i didn´t even had the device id as it´s a patched V1 and for getting masterkey on salthax there is the need to type in the device id which was unknown in this case... i did a mistake. after the repair i entered my wlan and...
                                          08-04-2024, 01:47 AM
                                        • mitsu2k
                                          The Real Dangers of conductive glue.
                                          by mitsu2k
                                          I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
                                          Here is an experience I...
                                          04-16-2023, 06:29 PM
                                        • Kiwi Viking
                                          HP Elitebook 855 G8 all of a sudden does not power on. 7 flashes of Caps lock and Number lock prod ID 4X5S2PA#ABG
                                          by Kiwi Viking
                                          HP Elitebook 855 G8
                                          Product ID:4X5S2PA#ABG
                                          Motherboard M53301-601.
                                          Hi Gurus, I am wondering if someone might be able to help. I purchased recently this used computer that otherwise looks in mint condition. I worked for 1 week, until one morning I shut down the computer using the power off commands in windows. There was no warranty. This was purchased for my teenager for use at school.
                                          When I went to start the computer up in the afternoon, all the keys lit, but the computer didn't POST. Then the next thing I tried (pressing the power button) resulted in only the...
                                          03-01-2025, 01:05 AM
