Central lock car key repair
  • R_J
    • Jun 2012
    • 9624
    Re: Central lock car key
    It is still hard to see where the traces go.
    sw3 and sw4 have a common connection at the C6 point
    sw4 goes to D2 (a); sw3 goes to D2 (k) but where do those lines go after that?
    sw1 and sw2 have a common point also which connects to the sw3 & sw4 common point
    sw1 connects to D1 (k) and U1 pin5
    Does sw2 connect to U1 pin 3 or 4? I can't follow it under the ic
    Are D1 and D2 connected to each at their anode or cathodes?
    And last where does U1 pin 8 connect? does it connect to the common point of the switches?
    I still can't see how U1 gets its 12 volts to operate. I suspect it detects a button push then draws current through the led for its vdd voltage which in turn lights the led.
    • R_J
      • Jun 2012
      • 9624
      The transistor should not be shorted, but that is just the rf amplifier, If it is shorted, it can be removed and the ic,led etc should still work. this is the pdf of the transistor.
      Here is a basic diagram for a one button remote
      • Morsus
        • Nov 2016
        • 96
        • Serbia
        If I remove the transistor should I jumper connect the remaining contacts?
        • R_J
          • Jun 2012
          • 9624
          I don't understand, what contacts are you talking about?
          If you remove the transistor You can check and see if itis shorted or if something else on the board is shorted.
          The ic/tranmiter would work without the transistor but the working range would be about a foot if that.
          • envym
            by envym
            Hi everyone!
            06-27-2025, 08:54 AM
          • brock-s
            MSI A520M-A Pro with "U-Key" power-on lock removal
            by brock-s
            I've searched the forums, including review of the "BIOS Guides, Methods, Resources and Tools" section but could not find anything regarding this problem. Additionally, I could not find a thread related to a U-Key lock on an MSI motherboard (or any other brand board for that matter).
            I'm working on an MSI A520M-A Pro (aka MS-7C96 ver1.1) motherboard that displays "Warning!!! Please insert USB key press any key to check." upon power-on. This appears to be caused by a setting in the BIOS for "U-Key" being enabled. The owner states they didn't enter the...
            09-01-2025, 12:35 PM
          • ArtMov
            [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
            by ArtMov
            Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
            1. I made overclocking lock disabled the default in amibcp
            2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
            03-31-2023, 01:30 PM
          • stormanimal83
            Nintendo Switch picofly installed cause parental lock how to get Master Key for restoring OFW
            by stormanimal83
            i bought a use console from ebay fixed it and it has parental lock. seller wasn´t helpful and nintendo either cause they don´t support used devices as they told me per mail. thanks for the bad support here in germany. was totally upset as i read the answer to my mail from 1 week ago.... there was no other way to get rid of that code rather than modding the console cause i didn´t even had the device id as it´s a patched V1 and for getting masterkey on salthax there is the need to type in the device id which was unknown in this case... i did a mistake. after the repair i entered my wlan and...
            08-04-2024, 01:47 AM
          • mitsu2k
            The Real Dangers of conductive glue.
            by mitsu2k
            I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
            Here is an experience I...
            04-16-2023, 06:29 PM
