broken R035 resistor in a PS4 PSU
  • reddemonic
    • Jun 2015
    • 42
    its a PSU for PS4 Slim
    spec for this resistor is: 0.035 Ohms, 3W, 1%, size 1225
    this resistor is broken and burnt. i cant find this resistor to buy locally. can i a small fuse as a replacement?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: broken R035 resistor in a PSU
    It sounds like a current sense resistor at that size, so no you can't swap with a fuse.
    • R_J
      • Jun 2012
      • 9624
      This might help Mouser has this listed but Non-stocked LRF3W-01-R035-FT
      • reddemonic
        • Jun 2015
        • 42
        thanks. only place i found this resistor are on ebay from china.
          • 31291
          before you burn the new one, it sounds like something got shorted out to make it blow!
          • reddemonic
            • Jun 2015
            • 42
            the fuse was dead also. no continuity at all. i cant find anything else broken under microscope. no schematic for this psu and i dont have another know good psu. worth a shot replacing it and see if go on fire again. if cant fix then i just throw in the bin. thanks
            • yesuha
              • Apr 2016
              • 8
              • mexico
              I think it's todo late but nerd to check q6 , ir shorted You nerd to change it
              • jinu_j
                by jinu_j
                Hi
                05-03-2025, 10:51 PM
              • mikey5791
                by mikey5791
                Hi to all forum members,
                12-26-2024, 04:55 AM
              • MidnightRoller
                Can a resistor lose resistance after hot air?
                by MidnightRoller
                I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                02-02-2022, 11:46 PM
              • artvandalai
                What resistor ohm will work better to repair this waterpik?
                by artvandalai
                The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                01-05-2025, 04:10 PM
              • chth96
                Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                by chth96
                I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                Since then, This AC/DC adaptor have been out of order.
                But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                And Is there any possibility that it will suddenly explode as well as to be out...
                12-03-2023, 04:40 AM
