Apex DT250A Digital Converter Box. I have almost no audio
  • ivtec
    • Dec 2008
    • 1967
    I have a Apex DT250A Digital Converter Box. I have almost no audio. If I turn up the volume on the box to max and the volume on the TV to max then I can hear the audio very faintly.
    The picture is great and closed captioning works great.
    To make sure it is not a TV/cable problem I swapped the cables from the DTV converter with that of the DVD player and still no audio. Used the same cable with the DVD player to the same inputs on the TV and I have audio. So it is not the TV or the cable. -
    Here some pic any advice where to check? thanks
  • ivtec
    • Dec 2008
    • 1967
    Re: Apex DT250A Digital Converter Box. I have almost no audio
    Hi guys; i had this Ota converter box in my scrap and the issue is sound is too low ,could it be this Chip be bad D4558?http://www.powermos.com/Uploads/download/D4558-40V SPEC Simplication.pdf
    • petehall347
      • Jan 2015
      • 4439
      • United Kingdom
      it could be that or power supply .best check supply voltages first then trace the signals
      • ivtec
        • Dec 2008
        • 1967
        Thanks mate; the only thing wrong with this box the sound is low, in order to hear sound volume on the box it has to be max and max on the TV also . and the low sound is same on RF Coaxial 0r R L RCA cables , video is fine and all other functions are good.
        • diif
          • Feb 2014
          • 6978
          • England
          What voltage do you get on pin 8 ?
            • 31199
            those 4558's can fail - i'v replaced some in harmon-cardon speakers
            • redwire
              • 3912
              I wonder if it has a muting circuit, I would follow the RCA jack outputs back to the 4558. Have to see pic around Q19.
              • ivtec
                • Dec 2008
                • 1967
                HI folks thanks for helping; ok i tested U4 and Q19 and results are in pic; also i have another Apex same model# and swapped the Power Sup and same result,also the mute is ok,the sound is audible mut has to all the way up on the box and on the TV,thanks again and have a Happy New Year
                • petehall347
                  • Jan 2015
                  • 4439
                  • United Kingdom
                  pin 8 is vcc .
                  • petehall347
                    • Jan 2015
                    • 4439
                    • United Kingdom
                    should be something like 12v at pin 8
                      Are you sure that IC4 (4558 close to the RCA jacks) pin 8 has 0 V? Since you have a second unit, do you get the same reading on the working unit.
                      4558: https://cdn.badcaps-static.com/pdfs/...ba96f903cd.pdf
                      Is pin 4 actually connected circuit GND?
                      • ivtec
                        • Dec 2008
                        • 1967
                        Thanks budm;Ok those measurements were taken with ground from tunner,now i went to take measurements again but now i used pin 4 as ground and pin 8 and i have 4.8 volts DC.
                          How about Q19 measurement with ref to circuit GND?
                          • ivtec
                            • Dec 2008
                            • 1967
                            thanks budm ; tested Q19 with ota antenna connected see pic
                              So Emitter and Base pins shows 0V which means the Transistor is OFF, the Collector shows only 1.3V; need to find out what the Collector is connected to.
                              How about on the working unit, what Voltages do you get compared to this failed unit?
                              • ivtec
                                • Dec 2008
                                • 1967
                                Thanks budm; i already did text voltages on the other box that has the right sound and i don't see anything different,well i think i'm going to leave it alone and keep it for power supp part because i have 2 other boxes but they are Zenith and i like this one better,i only use this type of box to have Ota all over my house through coaxial cable ,thanks for trying to help
                                • samson7point1@yahoo.com
                                  Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                  by samson7point1@yahoo.com
                                  The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                  The player processes the audio signal using two different reference frequencies. The "R"...
                                  04-30-2024, 11:22 AM
                                • i_am_patch
                                  Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                                  by i_am_patch
                                  Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                                  04-30-2024, 08:20 PM
                                • Bektronics
                                  Schematic Digital Audio mixer RCF type M18
                                  by Bektronics
                                  Hello dear audio friends.
                                  I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
                                  The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
                                  I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
                                  Thanks in advance if anyone can help me with this schematic.
                                  Of course, all information about this digital mixer and possibly references...
                                  07-24-2023, 06:40 AM
                                • alltvrepairs
                                  JVC lt-32vah3000 no sign of life apart from Digital Audio Laser port is lit RED
                                  by alltvrepairs
                                  HI,
                                  Have this set that does not respond to remote functions. It is either bricked or main faulty as the power supply is on and mainboard supplies seem present. I have noticed the red light from the digital audio out.
                                  This is an android on a vestel main board 17MB171
                                  Regards,
                                  Darren...
                                  01-31-2025, 09:58 AM
                                • UserXP
                                  Vintage SONY Digital Clock Radio ICF-C12W no audio
                                  by UserXP
                                  Dear all,
                                  I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                  i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                  My question is, do you know of this brand of capacitors and how bad are...
                                  07-21-2025, 08:35 AM
