Nyko Data Bank for ps4 not powering HDD
  • synapse
    • 51
    Hi Guys,
    I have a nyko databank that allows a 3.5" HDD to be used with a PS4.
    The thing has stopped powering up any HDDs (the HDDstill works in a PC)
    I have traced the issue to the 12V power supply. when sitting idle the power jumps all over the place as in this video:
    https://youtu.be/7jh1wkTOnXQ
    You can hear the beep when i switch it on but then the voltage reading goes nuts.
    The 5v comes from the console but plugs into the smaller white connector on the power supply (either to switch it on or just allow the 5v to pass through to the larger connector where both 12v and 5v run up to the sata plug)
    5v seems fine: https://youtu.be/xQZaVRKtNks
    The soldering quality is also not so good with a lot of joints that will at least need a reflow to make me feel happy. It also contains Jwco and Chong Capacitors that I should also replace if I want this thing to live a long time.
    Everything else looks ok, i'm not sure where to start on this one.
    I'm currently a Part-time Computer Systems Engineering student.
    Full time Service Assurance (faults) for a large Telco.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Nyko Data Bank for ps4 not powering HDD
    Well it could be as simple as the caps are gone...
    Try heating it up to 60°C or so and see if it behaves better.
      • 31284
      dont connect it to a drive till it's fixed - unless you want to risk the drive.
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        +1 i could just see the 12v hitting 17v!
        Follow the white rabbit.
        • synapse
          • 51
          Yeah absolutely, haven't connected the HDD since I noticed it not working.
          I was expecting it to be totally dead, not jumping all over the place like that.
          I think I'll start by replacing the caps with something decent (usually Panasonic is easiest for me to get) and i'll rework the bad solder joints and see how it goes.
          • TechGeek
            Computer Geek
            • Jan 2015
            • 2254
            have any old drives that you don't need?
            Permanently Retired Systems:
            Kooky and Kool Systems
            sigpic
            • synapse
              • 51
              Not any old days ones no.... It's ok I'll make sure it's healthy before plugging it back in.
              • synapse
                • 51
                Well a disappointing update.....
                I started off by replacing all the caps with Panasonic ones (what was on there were crap so worth replacing anyway) and re-flowed all the bad soldering.
                and it still does the same thing
                As the 12v only goes haywire once the console is turned on, I'm thinking there is something faulty that runs off the 5v it receives from the console (5v goes into the smaller of the two white connectors)
                I'll have to try and trace it out.
                Anyone else have any tips?
                • TechGeek
                  Computer Geek
                  • Jan 2015
                  • 2254
                  Sounds like something in the console is going haywire...
                  sigpic
                  • synapse
                    • 51
                    it wouldn't be, because that same 5v from the console powers the original 2.5" HDD without any issues.
                      • Jul 2011
                      • 6070
                      What is the part number of the two surface mount ic chips 8 pin ones on the back of the board ?
                      It is hard to tell from the photo but it looks like one the 3 pin surface mount ic chip looks like it is burnt on the low voltage side of board in the photo if this case that would explain the problem your having
                      • synapse
                        • 51
                        Hi Sam,
                        The part numbers on those 8 pin chips are 9435 1622.
                        Yeah that 3 pin ic had some sort of flux or something on it that wiped off. it looks ok to me, i'll upload another pic of that section of the board.
                        I think that may have also been one of the joints I reflowed that didn't look too good.
                        This is pretty much where i'm up to. trying to google the numbers on the IC's but not having much luck so not 100% sure what each pin is.
                        • synapse
                          • 51
                          I think I found the problem.
                          one of those 8pin IC's is shorted. I'll remove it and test to be sure.
                          looks like these mosfets are it: http://au.rs-online.com/web/p/products/6710750/
                          thanks for the tip in the right direction.
                            • Jul 2011
                            • 6070
                            I thought that the way the part was lay out on the board that it might be a MOSFET and if was that might be the place to look at
                            • synapse
                              • 51
                              gah this thing is anoying....
                              yes one of those mosfets was shorted, and no, replacing it still hasn't solved the issue
                                Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-06-2024, 05:30 AM
                              • Natob82
                                Micro Momentary Push Switch?
                                by Natob82
                                Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                12-21-2022, 05:22 AM
                              • grimacelord
                                NEC TurboExpress On/Off Power Switch Replacement Help
                                by grimacelord
                                I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                                I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                                I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                                11-09-2023, 09:49 AM
                              • SluggerB
                                Help making a switch work the opposite way with a relay
                                by SluggerB
                                I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                                I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                                It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                                02-07-2025, 07:57 PM
                                HP EliteBook 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook 800 Specification for Upgrade or Repair
                                This specification for the HP EliteBook 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with...
                                09-06-2024, 06:00 PM
