Odd PS3 USB Hub Problem (power backfeed?)
  • ELItheICEman
    • Sep 2011
    • 25
    I didn't know where else to turn, I could post this on a dedicated PS3 forum but I doubt I would get any good info. If this is the wrong subforum feel free to move it.
    I bought a USB Powered hub on Ebay so I could charge more than one controller with my PS3. The hub works fine for its intended purpose except for one fatal flaw. When I turn off my PS3 the hub should shut off too, instead it stays on for a second and my PS3 makes a horrible warble beepy sound. I have the newest Super Slim model, the hub is a CPS302 (an officially licensed product).
    I thought about making a custom cable with diodes but I didn't want to have issues with voltage drop. I'm thinking if I used a data cable without power wires it may not turn on at all. Any ideas or suggestions?
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: Odd PS3 USB Hub Problem (power backfeed?)
    Is it a powered usb hub?
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • ELItheICEman
      • Sep 2011
      • 25
      Yes it has a ac adapter that provides power to the hub
        • 31199
        why are you using a hub when all you need is a 5v supply and a bunch of usb sockets?
        the only time the controllers need to be connected to a ps3 is to sync them or use them in recovery mode where the wifi/bt interfaces are down.
        • ELItheICEman
          • Sep 2011
          • 25
          True I could charge the controllers another way, I have a 8 amp 5 port USB charger. I guess I wanted to fix the issue in case I started using accessories that require power. The super slim has 2 ports and I keep a thumb drive plugged up at all times for backups.
          It also kind of "grinds my gears" that this is an officially licensed product with such a weird design flaw. Maybe I really am the only person with this issue, I've been googling it and cant find any one else with this problem.
            • 31199
            there is limited power on ps3 ports, i know someone who blew out a port charging his phone on it!
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8327
              maybe try a better made usb hub?
                • 31199
                maybe disconnect the 5v wire in the hub from the ps3 and see if it still works.
                • ELItheICEman
                  • Sep 2011
                  • 25
                  Most USB 2.0 ports can only source 500ma, that's why I bought the externally powered hub.
                  If I have time tonight I want to experiment with a USB cable and see what works. Thanks for the replies
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Yeah, I wonder if this one is fake or mis-labeled... like those 99 cent chinese USB SD card readers, which don't read all cards, and fail like crazy.
                    -Ben
                    Muh-soggy-knee
                      master hoarder
                      • May 2008
                      • 12175
                      It could also be the hub's power adapter that is causing the issues - if it's one of those really cheap low-quality ones, it might have too much AC leakage current on the DC output.
                      Or, it could also be that the hub is back-feeding 5V to the PS3 through the USB 5V line.
                      • theone111
                        by theone111
                        3. Problem: TV shuts down
                        07-22-2024, 10:36 AM
                      • Duranitron
                        Asus x512dk rev 2.1 power on problem
                        by Duranitron
                        When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                        Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                        11-26-2024, 10:22 PM
                      • EazyBone
                        LG OLED55C9PUA power problem
                        by EazyBone
                        Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                        Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                        I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                        The power supply to t con is different story.
                        This...
                        06-23-2023, 07:43 AM
                      • Dr.d
                        Help please..Lenovo ideapad 5 14itl05 power and charging problem
                        by Dr.d
                        I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                        Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                        04-05-2024, 11:48 AM
                        03-31-2024, 02:12 PM
