OBD Scanner Autel AL539 burnt rezistors
  • fricosu007
    • Feb 2016
    • 36
    • romania
    Could someone help me identify the two rezistors burnt inside this AL539 device from Autel, i cannot find any dissembly pictures and there are a lot of these devices, i hope some of you have it 🙌
    https://imgur.com/a/b9fGGGk
  • CapLeaker
    Leaking Member
    • 8351
    One is probably something very low ohm like 0.1 Ohm because it is voltage supply and also acts as a fuse and the other is 49.something Ohm.
    • harp
      • Jun 2022
      • 648
      • Planet Earth
      Try to see as hard as you can get, if the first letter have "latch" like "1"... then very very carefuly and slightly gently whipe up once and see if it revial any more information. Be sure that burned paint is very fragile so on any attempt to clean it may go off. I will use first light brush with ipa, and future with more and more force. It may be 1R00 or R100 on it. The second resistor is 49R9 marking.
      • harp
        • Jun 2022
        • 648
        • Planet Earth
        Point
          • 31281
          sooooo.........
          why did it burn?
          • Agent24
            I see dead caps
            • Oct 2007
            • 5085
            • New Zealand
            Originally posted by stj
            sooooo.........
            why did it burn?
            Plugged into the OBD connector wrong?
            -David VanHorn
            • petehall347
              • Jan 2015
              • 4448
              • United Kingdom
              sooooo.........
              why did it burn?
              maybe set up for amps then connected across car battery
              • fricosu007
                • Feb 2016
                • 36
                • romania
                sooooo.........
                why did it burn?
                I got it like that …
                • electomech-fixer
                  First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                  by electomech-fixer
                  I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                  I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                  09-15-2025, 01:42 AM
                • waigy
                  What are these components that detect paper in a fax scanner
                  by waigy
                  PROBLEM SOLVED
                  I DIDN'T REALISE MY SMALLEST SOLDERING TIP COULD JUST FIT BETWEEN THESE COMPONENTS.
                  I MANAGED TO REMOVE THEM WITH NO DAMAGE TO THE BOARD AND I HAVE MY INTENDED END RESULT.
                  On a Possio PM70 portable fax machine which has a scanner that detects when you push a piece of paper into the scanner slot.
                  It is these two small (3mm long) components that detect the paper and start the scanner feed motor which pulls the paper into the scanner.
                  (These are on the circuit board for the keypad and not the main board)
                  I want to disable these as...
                  05-21-2023, 12:50 AM
                • dicky96
                  Zotac GTX 260 burnt component - can anyone identify?
                  by dicky96
                  Hi guys
                  This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
                  This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
                  Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
                  I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
                  The good phase...
                  12-01-2021, 01:02 PM
                • swimllamaswim
                  Precision 5550 LA-J191P No Power, Burnt ISL9538
                  by swimllamaswim
                  I picked up this Precision 5550 to fix up recently, and found that the ISL9538 chip was burnt on pin 14 (CSIN). The two left side Type C ports negotiate at 20v, and the right side one only negotiates at 5v. I also found the EMI protection diode, DT35, was burnt on that side. I pulled the ISL9538 off, checked for any other obvious shorts, repaired the pad, and put a new one on. Now, I still do not get power, and there is a rapid clicking sound from somewhere on the board that I can't pinpoint.
                  Here are the voltages measured at that chip:
                  To note, DCIN at Pin 17 is low,...
                  09-21-2025, 12:26 PM
                • mferna14
                  Apple MacBook Pro A2338 820-02773-A AON Rail burnt
                  by mferna14
                  Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
                  06-25-2025, 11:26 AM
