PS5 after PSU burn wont start
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3635
    • slovakia
    Hello.
    HAve this PS5 that have burned control ic in PSU. After replace i get only one beep when start button press. I found 1.3 ohm on HDMI encoder so i remove it and short gone.
    On my PSU show 0.006A and when start button is presed it goes to 0.027A and goes back down. Looks like i have all standby voltages except 1.8V from dialog ic. no short on that rail. i try to inject it but still the same.
    is worth try to replace this dialog ic ?
  • ttmi100x
    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
    by ttmi100x
    Greetings everyone,
    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
    Upon closer inspection...
    07-31-2024, 06:36 PM
  • howardc64
    Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
    by howardc64
    Eventually discovered a burn mark near lower corner of LCD. Here is a summary
    • Backlight on, no image
    • Disconnect right buffer board (view from front), left side display comes on
    • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
    • Buffer board is pretty simple
    Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
    07-11-2025, 04:04 PM
  • Tom41
    AOC U27G3X strange burn-in
    by Tom41
    I have an AOC U27G3X 4K gaming monitor that I use both as a TV and for gaming on a Nintendo Switch 2 console. Recently, something very strange has been happening to it. After playing a game that has an on-screen timer for a few minutes, the last digit of the timer (the one rapidly flickering from 0 to 9) appears to burn in on the monitor. Going to a different source or power cycling the monitor does not help; there is a constant flickering area on the screen where that digit was.
    It seems strange that only that digit would burn in, and NOT the other digits that are changing less frequently....
    10-23-2025, 04:33 AM
  • irepair559
    ps4 1215 model Changed port and encoder still no video?
    by irepair559
    hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
    Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
    ps4 seems to boot fine blue light then solid...
    01-01-2023, 12:41 AM
  • An-klamm
    Ps4 slim WLOD not HDMI encoder IC
    by An-klamm
    Hello!
    I bought 3x PS4 slim in the hope that I can repair all three so I can sell two and have one for free.
    All three had the error that no picture is outputed but the LED lights up white.
    I have already replaced the HDMI encoder IC and one PS4 is working straight away.
    It seems to be a different error with the others.
    I have measured everything that I can measure in the installed state. There are 5V, 5.1V, 2.4V, 3.6V, 1V, 2V. I can't see any differences between the working PS4 and the defective ones.
    I have measured the HDMI port and all PINs have approximately...
    03-30-2024, 03:57 AM
