PS5 EDM-031 Cap values
  • Puuhis79
    • Nov 2020
    • 27
    • Finland
    working on Ps5, EDM-031. There are two caps shorted other side of southbridge,could someone check values of these from the pic (marked)
  • Puuhis79
    • Nov 2020
    • 27
    • Finland
    I soldered back those inductors, and replaced those to caps 100nF, lets see how it works
    • Puuhis79
      • Nov 2020
      • 27
      • Finland
      Still it doesnt turn on, all voltages are present, and strange thing when 12v is connected to standby. Then it takes 280mA and hangs 10s or so something is still not working correctly... but I hooked UART and checked error codes...80810001, this could be Wifi module..lets try to replace it
      • Puuhis79
        • Nov 2020
        • 27
        • Finland
        Wifi module removed, I took the shield of, and few caps are shorted, so this could prevent PS5 to start....
        • SuperAman
          • Dec 2018
          • 121
          Yes shorted wifi chip can prevent it from powering on. Does it power on without chip installed?
            • 31607
            multiple bad caps?
            what happened to this machine?
            • Puuhis79
              • Nov 2020
              • 27
              • Finland
              Still working with this, I replaced WIFI chip, but still no permanent fix...
              • RSKostya
                • Oct 2021
                • Russia
                Hello, does any one knew nominal value of this RES?
                • proxneo
                  Recapping Sony ICF-SW55 - verifying cap values
                  by proxneo
                  Dear reader
                  I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                  At the moment, I have selected replacements based on the following list of values:
                  3 x 470uF 10VDC
                  3 x 4.7uF 35VDC
                  4 x 47uF 50VDC
                  8 x 22uF 6.3 VDC
                  1 x 220uF 6.3VDC
                  5 x 100uF 6.3VDC
                  Which...
                  06-21-2023, 12:38 AM
                • rashidjafar
                  Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
                  by rashidjafar
                  I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
                  Values for :-
                  PC43 : Capacitor [3x1.5mm]
                  PL7 : Inductor [2x1mm]
                  PC39 : Capacitor [1x0.5mm]
                  Any ideas would be appreciated.
                  I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
                  08-07-2025, 05:10 PM
                • Kobok
                  Different (lower) resistor values on PCB?
                  by Kobok
                  Dear Alls,
                  For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
                  09-19-2022, 07:30 AM
                • skdsp
                  Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
                  by skdsp
                  I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
                  Attached is the photo.
                  Thank you!
                  09-27-2025, 09:05 PM
                • Maniackk
                  Reader PocketBook InkPad 3 – identification of a black component marked 'CT' on the microUSB line
                  by Maniackk
                  Device: PocketBook InkPad 3
                  Mainboard: XRZ_E091_PB740-VTTOA-V1.1 / 2017-10-12
                  I'm replacing the broken microUSB connector on this e-reader, and during inspection after desoldering, I noticed a loose black SMD component marked "CT". One of them was torn off along with the pad, while the other one (marked in the photo) is still in place.
                  I would appreciate help identifying this component.
                  Measuring the loose component with a multimeter gives 5.84 MΩ in both directions, while the one still on the board shows no measurable...
                  05-16-2025, 08:53 AM
