PS5 EDM-031 Cap values
+ More Options
Posts
  • Puuhis79
    • Nov 2020
    • 27
    • Finland
    working on Ps5, EDM-031. There are two caps shorted other side of southbridge,could someone check values of these from the pic (marked)
  • Puuhis79
    • Nov 2020
    • 27
    • Finland
    I soldered back those inductors, and replaced those to caps 100nF, lets see how it works
    • Puuhis79
      • Nov 2020
      • 27
      • Finland
      Still it doesnt turn on, all voltages are present, and strange thing when 12v is connected to standby. Then it takes 280mA and hangs 10s or so something is still not working correctly... but I hooked UART and checked error codes...80810001, this could be Wifi module..lets try to replace it
      • Puuhis79
        • Nov 2020
        • 27
        • Finland
        Wifi module removed, I took the shield of, and few caps are shorted, so this could prevent PS5 to start....
        • SuperAman
          • Dec 2018
          • 119
          Yes shorted wifi chip can prevent it from powering on. Does it power on without chip installed?
            • 31015
            multiple bad caps?
            what happened to this machine?
            • Puuhis79
              • Nov 2020
              • 27
              • Finland
              Still working with this, I replaced WIFI chip, but still no permanent fix...
              • RSKostya
                • Oct 2021
                • Russia
                Hello, does any one knew nominal value of this RES?
                • proxneo
                  Recapping Sony ICF-SW55 - verifying cap values
                  by proxneo
                  Dear reader
                  I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                  At the moment, I have selected replacements based on the following list of values:
                  3 x 470uF 10VDC
                  3 x 4.7uF 35VDC
                  4 x 47uF 50VDC
                  8 x 22uF 6.3 VDC
                  1 x 220uF 6.3VDC
                  5 x 100uF 6.3VDC
                  Which...
                  06-21-2023, 12:38 AM
                • Kobok
                  Different (lower) resistor values on PCB?
                  by Kobok
                  Dear Alls,
                  For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
                  09-19-2022, 07:30 AM
                • Maniackk
                  Reader PocketBook InkPad 3 – identification of a black component marked 'CT' on the microUSB line
                  by Maniackk
                  Device: PocketBook InkPad 3
                  Mainboard: XRZ_E091_PB740-VTTOA-V1.1 / 2017-10-12
                  I'm replacing the broken microUSB connector on this e-reader, and during inspection after desoldering, I noticed a loose black SMD component marked "CT". One of them was torn off along with the pad, while the other one (marked in the photo) is still in place.
                  I would appreciate help identifying this component.
                  Measuring the loose component with a multimeter gives 5.84 MΩ in both directions, while the one still on the board shows no measurable...
                  05-16-2025, 08:53 AM
                • DeXXter
                  HP VICTUS 16-d0500la Some Values
                  by DeXXter
                  Here some measurements on HP Victus 16-d0500la, it might help someone, the values are on diode mode->mV and some lower ones on Resistance->Ω.
                  This specific laptop has an Intel i5 11400h + RTX 3050TI, the values are from a working laptop....
                  03-13-2025, 03:16 AM
                • Francesc V.
                  Diode marked as "E57".........not able to find it by reference
                  by Francesc V.
                  Hi:
                  I have what it might seem a zener diode. It's marked as E57, but I haven't found any reference that might match my observations.
                  I've took one from the same circuit and tested isolated with the power supply and a 1k resistor. with 10V, the possible zener stays at 6.6V.
                  It seems a SOD123 package. It measures (2.6mm x 1.6 mm).
                  Any idea? it's a 6.6V zener?
                  06-14-2025, 09:56 AM
