Xbox One X Psu
  • Viktor Árvai
    • May 2024
    • 32
    • hungary
    Hi !
    I have followed the short and removed 2 mosfets and the short seems to be gone from the backside of the board totally.
    i would like to ask how can i search these mosfets i cannot find it in google from the number what is on it is 50S280CE .
    on the picture its the two in the black rectangle.
      • 31296
      here
      • Viktor Árvai
        • May 2024
        • 32
        • hungary
        Thank you ill try get my hands on one and report back if its good.
        • gcrezz
          GameConsoleRezz
          • Jul 2024
          • 14
          If the high side is shorting out but you still have 12v on the low, I would suspect a shorted PWM IC, since that is really the only thing that would be linking the high side to low side and would explain the blown rectifier. I often find that isolating the fault on a PSU can be one hell of a rabbit hole. A lot of replacing components, test, something else blows, etc. My advice would be to buy a replacement unless this is purely for practice or learning.
          • Viktor Árvai
            • May 2024
            • 32
            • hungary
            Hi i have an update Q102 and Q101 had finally came , replaced first mesurements are fine every where i just have a missing R7 its a 6.8mohm smd resistor as far as i can tell but i have seen online there are diffrente wattage is given for these , i would like to know which watteg i should use than i can power it on.
            Thank you !
            • Viktor Árvai
              • May 2024
              • 32
              • hungary
              #26
              Update I have assembled the psu tested it , it plugs in as normal without tripping the breaker , but there is no 12 volt, the big cap has 320 volt after pluged in . i have found a small diode that reads wrong i will change that and we will see.
              • WTFRules!
                • Feb 2023
                • 35
                • Argentina
                #27
                Hi, I know this thread is old, but I´ve a PSU modelo "1815" from XBOX ONE X where the U2 IC blown and I can´t get the code of it, I can read it only ends with "0022T", if anyone have one at hand to get me the code would be awesome. Thanks in advance!
                • Viktor Árvai
                  • May 2024
                  • 32
                  • hungary
                  #28
                  Hi ! On my psu u2 is SH3P0022T T805 102 ZXD 17371 its a bin 16 leg ic.
                  Hope this helps!
                  • WTFRules!
                    • Feb 2023
                    • 35
                    • Argentina
                    #29
                    Hope this helps!
                    Oh man! Thank you very much!
                    You rock!
                      • 31296
                      which led me to this interesting page
                      https://www.chargerlab.com/teardown-...xbox-series-s/
                      • corrize
                        A funny fuse story – Lumix LX100 II
                        by corrize
                        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                        10-19-2023, 09:58 AM
                        Surface Mount Fuses Fundamentals Datasheet
                        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                        10-07-2024, 06:07 AM
                        HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                        This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                        09-12-2024, 02:00 PM
                      • flibidy
                        Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                        by flibidy
                        I have here a Magnum IA.100 which belongs to my parents.
                        The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                        Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                        What Ive done........
                        01-01-2025, 01:26 PM
                      • Stevedb
                        Boardview xbox 360 , xbox fat , xbox one x and xbox one s
                        by Stevedb
                        Hi all
                        I will share the boardviews i found internet from the xbox 360 , xbox fat and xbox one x and xbox one s
                        Pasw netcomchetumal.
                        Enjoy it.
                        Greetings Steve
                        From Belgium...
                        04-04-2023, 12:42 AM
