Hilti Battery B22 4.0 blink green but not responding
  • bohaboha
    • Nov 2012
    • 983
    • sweden
    The HILTI CPC battery flashes green but no tool starts or works. when testing the battery has 19.2v what could be the problem with them because I have three similar ones but there is nothing written on them all the patches are removed in the first B22 /4.0 with 19.2v the second one B22 /5.2 with 21.8v the third B22 /4.0 with18.3v are all three destroyed ? a bit difficult to believe have also tried other Hilti tools the same thing if someone who can help very grateful
    • 31019
    what voltage are they supposed to be?
    did you try putting a load on them like some lamps?
    you need to get into them and meter the individual cells
    • bohaboha
      • Nov 2012
      • 983
      • sweden
      Hi stj i do not know but i read they suppose to be around 22v .i did not try anything cause i do not know about batteries
      hope someone here can give a direction like you are doing thank you
        • 31019
        sam_sam_sam will help
        • bohaboha
          • Nov 2012
          • 983
          • sweden
          yes hope sam_sam_sam will read this ​
          • bohaboha
            • Nov 2012
            • 983
            • sweden
            Have opened the battery, there are 6 cell and one through encapsulated BMS that you can not do anything on that cells are quite unbalanced, 3 cell with 3.2v the others are at 2.7v ,2.4v and 2.5v it is a bit strange that they are so low, I don't think it is enough to balance them except have to see what is not right
              • 31019
              thats just an effect of age/lots of cycles.
              the board is not really a BMS, it's more of a protection/anti-fire device.
              try charging all the cells to the same level individually using jump-wires and maybe a tp4057 based charge module if you dont have something clever like a B6
              • bohaboha
                • Nov 2012
                • 983
                • sweden
                Yes it can be age and many cycles. but i am a bit a suspicious about "BMS" because i heard and read that a good drill battery should have a good active balance function on the BMS and wat you say let me think a bit.no i do not have a B6 but i have a single 1850 charger that i can use with jump-wires and multimeter to control the process
                one question how high v level can i charge them? if you like to have a better idea about this read this :https://www.eevblog.com/forum/repair...59/#msg5309959
                  • 31019
                  just fully charge each cell with the charger - it will be about 4.3v without a load
                  • bohaboha
                    • Nov 2012
                    • 983
                    • sweden
                    where are you sam_sam_sam
                    • Maxim GRI-welder
                      • Feb 2025
                      • Russia
                      Originally posted by bohaboha
                      The HILTI CPC battery flashes green but no tool starts or works. .....
                      ... a bit difficult to believe have also tried other Hilti tools the same thing if someone who can help very grateful
                      The first thing you need to do is open the battery case.🙂
                      Then check the voltage on all cells. If they are not equal to each other, then rebalance with some device (such as imax) or manually on each cell to a single voltage.
                      Then you need to disconnect the protection board and clean the contacts that connect it to the cells. I would advise then, when reattaching the board, either solder these contacts or weld them with spot welding.
                      After that comes the most important point. Most likely, you will have one LED on the indicator blinking the same way as before, and native charging will not charge the battery.
                      Next (don't be surprised) You need to wet your finger and touch it in such a way that it connects the positive contact at the battery outlet and the contact to the right of it.
                      After that, the indicator will start showing the voltage to which the battery is charged. I talked about it (though in Russian) in this video:
                      https://youtu.be/TVYLEUM5D6w?t=10m51s
                      • Maxim GRI-welder
                        • Feb 2025
                        • Russia
                        • bohaboha
                          • Nov 2012
                          • 983
                          • sweden
                          -thank you very much i just put everything to the side but now i ll look at it again after i see your video
                          • Bowline
                            by Bowline
                            06-11-2025, 10:13 AM
                          • mkdj
                            ASUS X571 no power : battery issue?
                            by mkdj
                            Mark and model: ASUS X571
                            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                            Tests already made:
                            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                            - I have removed...
                            07-14-2025, 09:16 AM
                          • techfreak9356
                            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                            by techfreak9356
                            I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                            09-14-2023, 11:10 PM
                            NVDC charger configuration...
                            11-05-2024, 03:28 PM
                          • ferah831208
                            Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                            by ferah831208
                            Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                            03-18-2025, 01:18 AM
