Gardena lawnmowerrobot mainboard, short out battery
  • Stigsolbjerg
    • Mar 2020
    • 33
    • Danmark
    hi again
    this time its a mainboard from a mowerrobot, when i connect battery it shorts it, so the bms shuts down battery.
    when take the mm in beepmode and measure from the positive to the negative battery terminal on the board it beeps shortly like 0,25 sec, and when i reverse the probes it beeps again shortly 0,25 sec.
    when i mesure on the cap thats missing in pic nr 2, the bottom solderpath goes to the negative, the upper one is 1,2 ohm to negative is this a short?
    hope Capleaker is still around
  • DriversScrew
    • Dec 2021
    • 32
    Could be a short. Depends on how accurate your multimeter is.
    I would try to inject a low voltage and search for shorted components getting hot on the pcb. A thermal camera would be helpful.
    • petehall347
      • Jan 2015
      • 4450
      • United Kingdom
      the beep is capacitors charging up
      • Stigsolbjerg
        • Mar 2020
        • 33
        • Danmark
        Hi again had a Quick look today at the print. 10 Big resistor below the 4 pin plug for the batteri, its the one with 10M written on it, is it right that it is 0,01 ohm? Can not find a true match on the internet.
        • petehall347
          • Jan 2015
          • 4450
          • United Kingdom
          10 MEG . what does it measure ?
          • Stigsolbjerg
            • Mar 2020
            • 33
            • Danmark
            Think it was 0,12 ohm
            • petehall347
              • Jan 2015
              • 4450
              • United Kingdom
              must mean 10 milliohm 0.01 Ω​.. confusing with the capital M Megohm
              • Stigsolbjerg
                • Mar 2020
                • 33
                • Danmark
                It is measuring 10,1 milli ohm.
                think i must try this voltage injection thing. I have this rd6006 switch mode psu. Any recomadation for settings?
                • petehall347
                  • Jan 2015
                  • 4450
                  • United Kingdom
                  have you tested the battery ?
                  • Stigsolbjerg
                    • Mar 2020
                    • 33
                    • Danmark
                    No, just the voltage it is 18 volt. When i connect it, it is 0,8 volt, it gives a little spark when i connect it
                    • petehall347
                      • Jan 2015
                      • 4450
                      • United Kingdom
                      battery is maybe dead then by the looks of it . see if it will power something else .
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • mkdj
                        ASUS X571 no power : battery issue?
                        by mkdj
                        Mark and model: ASUS X571
                        Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                        Tests already made:
                        - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                        - I have removed...
                        07-14-2025, 09:16 AM
                      • budwich
                        Lithium 12v tool battery charger... no negative connection?
                        by budwich
                        I have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the...
                        03-18-2025, 09:12 AM
                      • techfreak9356
                        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                        by techfreak9356
                        I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                        09-14-2023, 11:10 PM
                      • jkucukov
                        Asus ZenBook 13 UX333F External Short - Fast Battery Drain - Need Help
                        by jkucukov
                        I'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
                        During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show...
                        02-05-2025, 09:27 PM
