Gardena lawnmowerrobot mainboard, short out battery
  • Stigsolbjerg
    • Mar 2020
    • 33
    • Danmark
    hi again
    this time its a mainboard from a mowerrobot, when i connect battery it shorts it, so the bms shuts down battery.
    when take the mm in beepmode and measure from the positive to the negative battery terminal on the board it beeps shortly like 0,25 sec, and when i reverse the probes it beeps again shortly 0,25 sec.
    when i mesure on the cap thats missing in pic nr 2, the bottom solderpath goes to the negative, the upper one is 1,2 ohm to negative is this a short?
    hope Capleaker is still around
  • DriversScrew
    • Dec 2021
    • 29
    Could be a short. Depends on how accurate your multimeter is.
    I would try to inject a low voltage and search for shorted components getting hot on the pcb. A thermal camera would be helpful.
    • petehall347
      • Jan 2015
      • 4439
      the beep is capacitors charging up
      • Stigsolbjerg
        • Mar 2020
        • 33
        • Danmark
        Hi again had a Quick look today at the print. 10 Big resistor below the 4 pin plug for the batteri, its the one with 10M written on it, is it right that it is 0,01 ohm? Can not find a true match on the internet.
        • petehall347
          • Jan 2015
          • 4439
          10 MEG . what does it measure ?
          • Stigsolbjerg
            • Mar 2020
            • 33
            • Danmark
            Think it was 0,12 ohm
            • petehall347
              • Jan 2015
              • 4439
              must mean 10 milliohm 0.01 Ω​.. confusing with the capital M Megohm
              • Stigsolbjerg
                • Mar 2020
                • 33
                • Danmark
                It is measuring 10,1 milli ohm.
                think i must try this voltage injection thing. I have this rd6006 switch mode psu. Any recomadation for settings?
                • petehall347
                  • Jan 2015
                  • 4439
                  have you tested the battery ?
                  • Stigsolbjerg
                    • Mar 2020
                    • 33
                    • Danmark
                    No, just the voltage it is 18 volt. When i connect it, it is 0,8 volt, it gives a little spark when i connect it
                    • petehall347
                      • Jan 2015
                      • 4439
                      battery is maybe dead then by the looks of it . see if it will power something else .
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • mkdj
                        by mkdj
                        Mark and model: ASUS X571
                        Tests already made:
                        - I have removed...
                        07-14-2025, 09:16 AM
                      • budwich
                        Lithium 12v tool battery charger... no negative connection?
                        by budwich
                        I have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the...
                        03-18-2025, 09:12 AM
                      • techfreak9356
                        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                        by techfreak9356
                        09-14-2023, 11:10 PM
                      • ZixuTech
                        Lenovo Ideapad 700-15ISK shuts down shortly after it starts. Works on battery
                        by ZixuTech
                        Hi Guys, a weird case here.
                        This laptop came with damaged hinges, but no liquid signs.
                        It will loop between battery charging/not charging/charging/... Now the original battery is completely drained it won't turn on with it. The orange light keeps blinking nonstop.
                        I have replaced the battery with a newly charged battery and it turns on but doesn't charge. The orange charging light blinks three times indicating charging issues.
                        I have replaced bq24780S battery charging chip, no difference.
                        With a connected new battery,...
                        04-03-2022, 04:03 AM
