PS4 pro BLOD broken component
  • LouisLP
    • Sep 2021
    • 5
    • France
    Hi, I have bought a non working PS4 pro. The seller said that the PS4 was working, he changed thermal paste and now BLOD for 5-10sec.
    While inspecting the board (NVA-001) I found this component that was damaged (see photos).
    I was wondering if someone knows what component it is…
  • LouisLP
    • Sep 2021
    • 5
    • France
    Found it : 20k ohms resistor. Replaced it and now the ps4 is working !
    • chth96
      Is it possible bridging tiny broken trace
      by chth96
      When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
      cutting tiny trace.
      This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
      Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
      But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
      12-03-2022, 11:32 PM
    • Wompatti-
      Ps5 edm-020 3sec BLOD
      by Wompatti-
      I have a ps5 with blue light flashing about three seconds when I press the power button and then it turns of. Second press, only beeb but nothing else. Third press, 3sec blod etc...
      BUT the weird part is if I unplug the power cord and put it back, the console will start without pressing the power button and give that 3sec blod.
      UART shows error code 80800024 and nothing else. There are no cracks on the apu. No shorts on the board that I can find. All standby rails are present and all power on rail will show up for that 3second period. I've tested with two different psu and reflashed...
      Today, 11:44 AM
    • ArchangelGabriel
      Aorus 17G YD laptop, broken display, could not switch to external monitor
      by ArchangelGabriel
      Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
      11-23-2023, 03:55 AM
    • corrize
      Resonator - quartz broken - how to find the same (same frequency) ?
      by corrize
      Hello, I have a Fujifilm hybrid camera with an issue : the time don't run. I set 12:00 and 3 min later, the same : 12:00
      I saw an obvious root cause : a broken quartz (resonator). But with the box broken, I can't read the marking code. Probably : 464… or A64…
      I found on the web a picture of the same camera board but with marking code very different. Probably : A7…5N
      I'm searching another one for compare…
      Do you have an idea or another way for find the frequency of this resonator please ?
      (I did not found the manufacturer of this component ? And I did not found the...
      03-27-2025, 09:20 PM
    • emeskay
      Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
      by emeskay
      We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
      08-06-2024, 07:13 AM
