Ps5 edm-020 3sec BLOD
  • Wompatti-
    • Jul 2025
    • Suomi
    I have a ps5 with blue light flashing about three seconds when I press the power button and then it turns of. Second press, only beeb but nothing else. Third press, 3sec blod etc...
    BUT the weird part is if I unplug the power cord and put it back, the console will start without pressing the power button and give that 3sec blod.
    UART shows error code 80800024 and nothing else. There are no cracks on the apu. No shorts on the board that I can find. All standby rails are present and all power on rail will show up for that 3second period. I've tested with two different psu and reflashed the bios.
    Any idea what could cause the ps5 to turn on just by connecting the power cable?
  • Woodsworth
    PS3 CECHC03 60GB YLOD Troubleshooting
    by Woodsworth
    I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
    START
    Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
    03-19-2024, 07:58 AM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • mattpd
    PS5 EDM-031 - Pulsing BLOD - SSD NAND chips never heat up
    by mattpd
    PS5 died in the middle of a game and never would boot again. Pulsing BLOD stays on forever but never boots.
    No LM damage. UART gives a generic "APU not responding" error.
    Under thermal camera, the SSD NAND chips stay stone cold. The controller warms, but not the NAND. I have a good 2.5v and 1.8v around the NANDs...
    I don't have a ton of PS5 experience, but I assume that the NAND would need to warm at least a little bit in order to boot...
    So to those with experience, would you expect at least a little heat from the NAND during...
    09-02-2025, 09:42 AM
  • BMCappelletti
    Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
    by BMCappelletti
    Hi everyone.
    Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
    Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
    Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
    02-18-2025, 12:22 PM
  • Puuhis79
    Ps5 edm-40 blod
    by Puuhis79
    Ps5 came with only beeps nothing else, i hook up uart -> ram bank4 error (hynix chip) ordered same type, replaced chip with bga station, now gives fan spin and blod 1s
    and uart gives 80801F12 code… tried to look up the code but no succes. Atleast message for ram bank4 is gone
    11-09-2024, 07:08 AM
