playstation 5 console that won't play COD
  • kjchatman
    • Dec 2012
    • 213
    • united states
    i've got other games that play fine but CALL OF DUTY MW2 always crashes in the menu and it never plays. I even tried installing it on an m.2 drive and i've factory reset the device and replaced the thermal paste... Could this be bad ram?
  • kjchatman
    • Dec 2012
    • 213
    • united states
    i replaced the hynix gddr with samsung from a spare board. It still crashes on COD menu. the game never starts but other games play flawlessly. I think i'll do a factory reset with the new ram memory
    • kjchatman
      • Dec 2012
      • 213
      • united states
      after replacing the ssd controller i noticed that it gives the 3 beeps and then cuts off. i'm thinking that it's a heatpipe issue. some games make the console run hotter and maybe that's why only some play and some do not
      • kjchatman
        playstation 5 crashes and cuts off while trying to playback a dvd movie
        by kjchatman
        the disc drive works perfectly because i can install games with it and it can read the movies.I can never get it to playback a movie disc. it goes to a black screen and sometimes a green screen then the console shuts down. It does it every single time i try to play a movie. The games also do the same thing If I don't start them up immediately after the console boots up. I've tried factory resets and replacing the ssd controller and the southbridge but nothing has resolved the issue
        11-11-2024, 06:52 PM
      • Gigabyte_PL
        PS4 PRO - black screen, white light
        by Gigabyte_PL
        I have problem with my Playstation 4 PRO. After a long break, I turned on the console and tried to play game. Game started, but after a minute it froze the console and crashed to the main menu. I tried running another game and the same problem.
        Error returned: CE-34878-0 (I changed HDD)
        I updated the software in the console. I unplugged the console, put it aside for a week and now I want to turn it on but there is no image. The console lights up white, there is communication via HDMI with the monitor - but only a black screen (but it detects the...
        01-04-2024, 05:46 AM
      • gabri2211
        Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
        by gabri2211
        Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
        This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
        This NEXUS connector broke.
        Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
        The Xbox has a power supply that provides 12 volts on all outputs, so the power...
        07-28-2025, 07:13 PM
      • Technomancer
        PS One (SCPH-101) disc reading issue
        by Technomancer
        Hello folks,
        I have an SCPH-101 console with a bit of a strange issue. The unit doesn't want to read discs. Now that in itself isn't all that strange as the lasers in these things often go bad. What is strange, however, is that when I take the laser assembly from this unit and put it in a known working console, it works just fine. Also, when I try the laser assembly from the working unit in this broken one, the disc spins and the laser moves up and down but doesn't really do much else.
        One thing I noticed is that it doesn't want to read even audio CDs until I turn the...
        11-29-2021, 01:43 PM
      • Fast Alpha
        I need to get a Fat PS2 Playstation 2 Controller Port Cable SCPH-3003
        by Fast Alpha
        Hi I have a PlayStation 2 games console and the controller port cable, on models beginning with SCPH-3​003.
        I included a picture of the model below. What replacement can I get from Parnell, it should be a ribbon cable?...
        03-19-2024, 06:29 PM
