Protect NVR device with PoE
  • Adenitz
    • Jan 2021
    • 122
    • Congo
    Hello, I have a setup with NVR 16 Canais H.265 1080p HD PoE+ - TRENDnet TV-NVR416 that is using 10 cameras, some are outdoors. What would be the best way to protect NVR device from power surges? All ports are PoE so the NVR supply power to the cameras. NVR is pretty expensive so I would like to protect it somehow. Should I use some kind of switch that needs to be connected to the cameras, so it could "take a hit" if there is a power surge. Thank you!
  • diif
    • Feb 2014
    • 6978
    • England
    You protect the power to the NVR, where the surge would enter.
      • 31246
      find out the voltage on the POE.
      then solder big MOV's (varisters) inside the equipment at the sockets on both ends
      you need the trip voltage to be maybe double the operating voltage and the lower the capacitance the faster they can react usually.
      i'll be surprised if they dont already have something in them even if it's zener diodes
      • Adenitz
        • Jan 2021
        • 122
        • Congo
        Hello and thank you for your answers.
        diif The power (230 VAC) input is unlikely place the surge woud enter. This already on APC 750 VAC UPS device. The place to enter is via ethernet cables tthat lead to cameras. The cameras are PoE which means each port of NVR supply 48 VDC.
        stj It has TVS protection. In fact I already had a situation where TVS diode got shorted. I don't want to open device to solder anything, I thoutght it would be better if there is a cheaper device like PoE switch in front of the NVR device, so I was searching for a device in that direction. I have found individual network protection devices such as this one but I would have to buy at least 10 of them.
          • 31246
          those filters would help - keep them close to the devices
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8340
            It all depends on what we are dealing with here. Maybe you don't need any, maybe the whole install is wrong and instead of CAT5e there should have been shielded CAT6 being used. How long are the runs, is there lot of lightning, is there a metal roof or siding, how good is your grounding system of the house, is the house in an urban environment or sitting alone top on a hill and the list goes on…
            • diif
              • Feb 2014
              • 6978
              • England
              How are you anticipating the surge to enter the ethernet cables?
              They are in conduit ?
              • Adenitz
                • Jan 2021
                • 122
                • Congo
                Hello, sorry for the late response.
                UTP cables from CCTV are in the same metal cable tray as power cable for outside lights. they are separated about 10 cm from each other, but I cannot avoid that because it is the only place where CCTV camera cables are entering house.
                In the past there was a situation where the fuse for the outside light was blown and after that TVS protection diode diode on NVR inside the house was short circuited to the ground. So I concluded that this was how surge created in the lights got transferred by induction to the UTP cable.
                Anyway, I'll try to replace regular UTP cables with at least F/UTP cables.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  10cm gap, I can't see it entering rhat way but you should be using STP if you do.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8340
                    Not only that, but there is something wrong with your earth ground. If something is properly earth grounded, it is very rare that a fuse blows etc. You'd have to fix that first, before the STP cables. Check that metal cable tray, wiring etc. because that probably acts as an antenna for lightning.
                    • nobbnobb1
                      Upgrading Whole Home Surge Protector MOVs (Eaton CHSPT2SURGE)
                      by nobbnobb1
                      I have a whole home surge protector (Eaton CHSPT2SURGE). This is the lower end model as compared to the CHSPT2ULTRA. When I took it apart, I noticed it's basically the same PCB as the higher end model, just missing the extra MOVs for higher capacity. Coincidentally, I have a pack of brand new Bourns 20D241K MOVs laying around:
                      https://www.digikey.ca/en/products/d...0D241K/2799098
                      The only thing I noticed is that these Bourns MOVs are not thermally protected with a fuse. I'm wondering if it's safe to just simply install these extra MOVs for extra capacity,...
                      06-04-2025, 08:40 AM
                    • CdDvdFlash
                      Hitachi HTA-DD3W AV Receiver Error Code -Protect-
                      by CdDvdFlash
                      I have a Hitachi HTA-DD3W AV receiver and when I got it I tested it working fine with speakers but it needed a clean inside because it had signs of moisture in it but it was fully dry with bits of wood chips, I guess this was left in a shed so I fully disassembled it and cleaned it with isopropyl alcohol very carefully, some de-soldering was also needed but now its very clean, luckily there was no rust on any components and all the capacitors are fine with no bulging. When I turn it on I hear a relay switch on then a few seconds later another relay switches on or off and the display has a "-PROTECT-"...
                      07-10-2023, 06:05 AM
                    • xTomtom
                      Treadmill hit with power surge
                      by xTomtom
                      Recently I acquired a treadmill that was hit by a power surge (I assume). On the control board, there was a varistor that was blown apart and two traces that were partially blown out. I replaced the varistor (to my knowledge it is a matching one) and wired back where the traces were with some 22 awg solid copper wire. When I went to power it on, still nothing. On a quick inspection with my meter, I was getting incoming voltage on the AC in terminal.
                      The board is a MC2100LS-30 treadmill controller.
                      Visibly, there are no other problems....
                      05-09-2023, 08:06 PM
                    • x16
                      Lenovo Thinkpad T14 gen 1: Unlock MEC: in protect mode
                      by x16
                      i have Lenovo Thinkpad T14 gen 1 20S1 / SN: PF2M0XAG.
                      I moved resistor like every time and read MEC chip with SVOD4. I unlocked 3 other mainboards successfully but this one could not read. SVOD 4 Software says: "MECxxxx series in protect mode, work mass erase only". Like in screenshot.
                      What can i do?...
                      11-14-2024, 01:31 PM
                    • Bubbsy 2002
                      Kiddie smoke alarm (120v with 9v battery backup) experienced 180v power surge (Newfoundland Power company).
                      by Bubbsy 2002
                      Hi to all, I was diagnosing 2 smoke detectors that experienced power surge. I opened one up and found a weird fuse/resistor, which now has open circuit. I can't find this part.
                      Forgot to mention they both light up and I believe the test function works, but when I put smoke to them no alarm!
                      Any help in this regard would be greatly appreciated.
                      Thanks,...
                      01-02-2024, 09:11 AM
