PS3 PSU (APS-231) Voltage mod
  • m111920
    • Nov 2013
    • 49
    • Croatia
    #41
    Re: PS3 PSU (APS-231) Voltage mod
    it' difficult to trace it, voltages stays same all all times on pins 10 and 11 and that's weird.
    • domas
      News Hater
      • May 2013
      • 323
      • Denmark
      #42
      also at the time of triggering OVP?
      And by tracing i mean look for pcb tracks leading to the 12V output
      • m111920
        • Nov 2013
        • 49
        • Croatia
        #43
        Yes.
        I know what you mean. There are no tracks leading to 12v output as it's on other side of PSU, primary and secundary sides are only connected by optocouplers, this unit is totally different than ATX PSU's.
        I find this too difficult, so i quit for now, I must return soldering iron and multimeter to my friend.
        • domas
          News Hater
          • May 2013
          • 323
          • Denmark
          #44
          ok. nice that at least you could crank it up to 14V. Please let us know if you continue to work on it
          • m111920
            • Nov 2013
            • 49
            • Croatia
            #45
            I already knew the solution, just solder a peice of wire at bottom of relay which is controlling everything except 5vsb, it should work, but that involves high risk as there won't be any kind of protection, no more OVP nor OCP. I would need extra cooling and measuring equipment so I can see what's safe and what isn't.
            • beebenutz
              • Sep 2014
              • United States of America
              #46
              Hello, I have read this and other forums in order to assist me in modifying an aps-226 PS3 power supply for use as a cheap 18v power supply for lipo battery charging. I purchased a high power battery charger which is quite power hungry. It will allow for 12v-18v DC inlet voltage and requires a minimum of 60amps DC to output full charging capabilities. I decided to wire two of the aps-226 power supplies in parallel for a possible output of 64amps at hopefully ~18v. I first followed this article and found that connecting a 100k ohm 15turn potentiometer to pin #2 and #3 of the "L287" , described earlier in this article, will allow for an adjustable voltage of up to about 13.4v DC. At ~13.4v DC the OVP circuit will trip shutting down the power supply for about one minute. I have now found that by modifying the input voltage of of the optocoupler for the OVP circuit with resistors in order to adjust the max voltage of the OVP. If you look at the back side of the aps-226 PCB you will find one of the optocouplers labeled "12v OVP". If you lift the two pins one the secondary side of the PCB and solder two resistors of equal value between the PCB and optocoupler pins you can trick the OVP circuit to think it has less voltage than what truley exists. I ended up using an 1/8watt 260kohm resistor to achieve the voltage I needed. Be sure to upgrade all 16v capacitors to 25v to avoid smoking them. If needing above 16v be sure to also replace all three of the 2.2ohm 2watt resistors on output rail with 2.2ohm 5watt.
              Hope this helps somebody, good day
              • Kert
                • Jun 2016
                • finland
                #47
                I have also this psu lying around. And I would like to use it with my hobby charger (input voltage 11-24v).
                If I change the psu-s output caps and resistors, then what would be the safe max voltage for this psu?
                24v would be ideal to get max power out of my charger, but i guess it is too much for a 12v power supply?
                And second question: if I increase the output voltage, then what about amps?
                How to calculate max amperage after voltage increase?
                Thanks!
                • psrkallez06
                  • Jul 2016
                  • Sweden
                  #48
                  I also want to make a similar mod but with a ATX power supply instead of a PS3 one, going to open a new thread soon about it!
                  • electron_jj
                    Panasonic TH-L42D25A checking the PSU output voltage
                    by electron_jj
                    Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                    I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                    08-29-2021, 08:13 AM
                    Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                    I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                    The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                    Now...
                    06-09-2024, 10:57 AM
                    ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                    3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                    Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                    core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                    configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                    serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                    Based on Intersil's Robust Ripple Regulator...
                    11-05-2024, 03:24 PM
                  • ruletero
                    Acer a515-43 low battery charge voltage
                    by ruletero
                    Hi
                    Acer A515-43
                    LA-H801P
                    Fail: Does not charge battery, has low voltaje on connector.
                    Laptop didn't want to turn on, only charge led blinked.
                    I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                    I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                    Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                    10-24-2022, 02:31 PM
                    Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
                    I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
                    https://www.ebay.com/itm/116497313155?var=416785404161
                    Here are some of the description from the eBay seller
                    The main parameters:
                    1. Product name: High-power non-isolated DC boost module power supply.
                    2. Product model: 100A2000W.
                    3. Input voltage: DC12V-60V.
                    4. Input current: 100A (maximum)....
                    05-18-2025, 09:45 AM
