National Optronics Horizon III Lens Edging Machine
  • woodyfl
    • Dec 2011
    • 17
    This is from a light industrial machine used in the manufacturing of eyeglass lenses. The manufacturer no longer supports this machine but it lasts a long time and is well designed. It is operated by a "black box" that costs $3K to $5K to replace which contains all the boards which they only used to sell as a package and would not replace individual boards. So I opened the back box and found some totally obliterated components.
    A closer view of the problem I found. Does the CR9 Component also look suspect?
    Here is a good board from another machine.
    Could replacing the resistors fix the board? Or is there something that caused them to burn them so badly it will just do it again to the new ones? The fuse was good on the board that I found.
    Thanks in advance I am just dabbling in this and I am not a technician
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: National Optronics Horizon III Lens Edging Machine
    those are inductors.check the diodes to the right first.
    • japlytic
      • Oct 2005
      • 2086
      It's a bit silly for the manufacturer to require replacement of all of the boards.
      • APOPAP
        Panasonic National NV-M3 VHS Camera shuts down after some seconds
        by APOPAP
        Hello everybody,
        First post here. I have been reading posts here for some time now, but today I made my first account and post.
        The same question is also posted on another site, here it is:
        Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
        I tried connecting it to a Computer PSU (12.7v) but I get battery error...
        08-25-2025, 10:12 AM
      • madvinoth
        mi NoteBook Horizon Edition 14 A3_CML 19800-1 bios
        by madvinoth
        need working bios file
        mi NoteBook Horizon Edition 14 A3_CML 19800-1 bios bin file
        07-15-2025, 07:06 AM
      • warsztat
        Trademi Horizon, freeze after start.
        by warsztat
        Hi, trademil Horizon freeze after start like video, i try reset (3sek push stop), remove and I put new ones capaticors 3,3V line digital and analog line.
        The device in service mode passes all tests, except for the display test, where it hangs. The display in service mode during engine testing, etc. seems to behave correctly, it shows values, the engine is working, I can adjust its speed but only in service mode, in normal operation after pressing start the machine freezes
        All the multiplexers that support the display seem to be working. It's like the processor...
        03-06-2025, 07:33 AM
      • ZOrd_Z
        Bang & Olufsen Beovision Horizon always in standby.
        by ZOrd_Z
        I every one!!
        I have a Bang & Olufsen Beovision Horizon that is always in standby mode ( green light on ).
        Main board is 715g7132-m0h-000-005k. Corrupted firmware? I have all the ok voltages in psu.
        Any idea?
        Thank's...
        12-12-2024, 11:44 AM
      • bryanX
        Control board for treadmill Horizon Omega II
        by bryanX
        Hi guys!
        Firstly, I will apologize if my topic is in the wrong section, please move it if necessary.
        I want to repair one treadmill from the brand Horizon the model is Omega II. Practically, the motor power control board has suffered one damage.One mosfet has blown and I suppose by doing that, the short circuit has damaged a couple of diodes, one zener diode and two transistors. I hope that is all. I will find out when I will put them all back on board. I have dismantled and cleaned the rotor of the DC motor, tested it, and it seems to be working properly. I suppose it was water...
        03-05-2024, 01:11 PM
