Bang & Olufsen Beovision Horizon always in standby.
  • ZOrd_Z
    • Jul 2013
    • 80
    • Portugal
    I every one!!
    I have a Bang & Olufsen Beovision Horizon that is always in standby mode ( green light on ).
    Main board is 715g7132-m0h-000-005k. Corrupted firmware? I have all the ok voltages in psu.
    Any idea?
    Thank's...
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    You are going to have a real hard time finding support for a B&O TV.
    They are rare, very expensive and ppl who can afford them dont bother getting them fixed.
    They just buy another one!
    Im happy to help tackle it with you (albeit remotely) if you are serious about fixing it with us.
    • ZOrd_Z
      • Jul 2013
      • 80
      • Portugal
      Thank's. Now trying to get some ideas from B&O themselves. I'll post feed back...
      • ZOrd_Z
        • Jul 2013
        • 80
        • Portugal
        They are not willing help....
        • KYBOSH
          • Oct 2011
          • 581
          • Unknown
          If you can read the EEPROM and upload it to lotas he maybe able to spot the problem if indeed there is one with it.
          • HIGHIQ
            • Dec 2023
            • Türkiye
            I every one!!
            Any idea?
            Thank's...
            Hello, if you can read the original emmc memory of your device with jtag and share a copy (user, boot1, boot2, extcsd), I can help you.
            • tvguy12012012120
              by tvguy12012012120
              02-07-2025, 05:13 PM
            • fharris1977
              Vizio D50u-D1 Dead Set No Standby
              by fharris1977
              Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
              12-28-2023, 10:25 AM
            • Crystaleyes
              Samsung BN44-00259A standby question
              by Crystaleyes
              Hi all.
              I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
              SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
              Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
              The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
              08-11-2023, 05:15 AM
            • psssst
              Yamaha TSX 120 Standby Problem
              by psssst
              Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
              03-01-2024, 07:25 AM
            • ChristianBr01
              LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
              by ChristianBr01
              I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
              The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
              What I already found is that the 12.8V are not an the connector to the main board connector to the power...
              04-23-2025, 01:48 AM
